devo 7e deviation 4.0.0 - 2 switch patch problem
01 Jan 2014 14:55 #17636 by southtirol32
happy new year!!
i have try to patch deviation 4.0.0 (deviation building station) whit the 2 way patch for devo7e 7e_buts.patch.txt whit errors result..., its possible that not support 4.0.0 ?!,
you can help me?!
very nice job, the build is great!!
01 Jan 2014 15:08 - 01 Jan 2014 15:09 #17641 by PhracturedBlue
Replied by PhracturedBlue on topic devo 7e deviation 4.0.0 - 2 switch patch problem
there were several files that moved around, and thatis probably the issue.
in your patch file replace common_devo with common/devo everywhere and it'll probably apply again.
Last edit: 01 Jan 2014 15:09 by PhracturedBlue.
01 Jan 2014 17:19 #17648 by southtirol32
Replied by southtirol32 on topic devo 7e deviation 4.0.0 - 2 switch patch problem
hi, the problem is the patch, i send a screenshoot
Attachment DeviationBuildStation.png not found
  • rbe2012
  • rbe2012's Avatar
01 Jan 2014 18:09 #17659 by rbe2012
I think we need a new patch... maybe I will find some time tomorrow...
01 Jan 2014 18:33 - 01 Jan 2014 18:33 #17661 by blackmoon
Replied by blackmoon on topic devo 7e deviation 4.0.0 - 2 switch patch problem
ho please pretty please and a two 3-positions switches patch to, to bring joy and happiness for the new year to come :D
Last edit: 01 Jan 2014 18:33 by blackmoon.
01 Jan 2014 19:50 - 01 Jan 2014 19:51 #17671 by kreidler
The old patches from here: www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e always stuck on the last lines of tx_buttons.c which can be easily corrected manually.
I applied the 2-two switch and the 1-three switch patches without any problems. There might be problem with your patch file.
Please find attached both patches as they are working on my system with the addition that the switches are working in the emu also.
Last edit: 01 Jan 2014 19:51 by kreidler.
01 Jan 2014 21:25 #17684 by southtirol32
hi kreidler
emu patch?!what is this?? i search a 2 way patch for the devo 7e to compiling whit the deviation build station, the emu patch don´t go..
01 Jan 2014 22:07 #17685 by kreidler
I do not know if the VM of the Build station is somehow limited. The attached patch works and adds also the functionality to the emulator even if you do not use it.
Maybe sbstnp as the developer can clarify.
01 Jan 2014 22:39 - 01 Jan 2014 22:41 #17687 by HappyHarry
Replied by HappyHarry on topic devo 7e deviation 4.0.0 - 2 switch patch problem
here is a modified version of the 1 3way switch patch, this patches to the current code without errors
Last edit: 01 Jan 2014 22:41 by HappyHarry.
02 Jan 2014 02:14 #17699 by marciaa
esky big lama
02 Jan 2014 06:00 - 02 Jan 2014 06:01 #17709 by John-Boy
Hi Marciaa,
Would you post a link to the patched versions you made?
I added a 3 way switch for multiwii use to my 7e.
I haven't had any luck with building a 'patched version... :(
Just me I guess.... ;)
John L.
Last edit: 02 Jan 2014 06:01 by John-Boy.
02 Jan 2014 06:08 #17710 by dianjing
can you help me to add 3sw to 7e ver4.0
thank you
02 Jan 2014 15:03 - 02 Jan 2014 15:13 #17737 by HappyHarry
you can find my 4.0 7e 3way switch build here >> www.deviationtx.com/forum/builds/2531-4-...ra-toggle-icon#17736
and my 4.0 7e 2 x 2way switch build here >>
www.deviationtx.com/forum/builds/2532-4-...ra-toggle-icon#17738
also dianjing you have sent me an encrypted pm, without the encryption password i can't decrypt and read it?
Last edit: 02 Jan 2014 15:13 by HappyHarry.
02 Jan 2014 16:39 #17745 by PhracturedBlue
I think that is just a bug in the PM system. There is no way of encrypting a PM in our board, and likely no way to decrypt it either.
For future reference, sending the same message to multiple users and/or posting the same question in multiple threads is not acceptable practice on this board.
02 Jan 2014 16:55 #17748 by HappyHarry
I think this happens when you select the 'password' checkbox and input a password, but if the person on the receiving end doesn't have the password its pointless using it.
02 Jan 2014 19:25 - 02 Jan 2014 20:24 #17768 by southtirol32
i don´t understand why its not possible to compile, is the nightly v4.0.0-b5ebe69, the patch is attached´:, it´s possible that the building station has a problem ?
Last edit: 02 Jan 2014 20:24 by southtirol32.
02 Jan 2014 19:28 - 02 Jan 2014 19:33 #17769 by HappyHarry
you can find working patches in the same posts as my builds, and there is nothing wrong with sbstnp's vm build machine as i have just tested it, i dowloaded the latest source from pb's repo, applied the two 2way switch patch, and compiled the firmware on it without issue
Last edit: 02 Jan 2014 19:33 by HappyHarry.
02 Jan 2014 21:36 #17776 by dianjing
:) thanks a lot for your reply.
i had 7e with 2 3sw. which 4.0 can i use?
my e-mail is This email address is being protected from spambots. You need JavaScript enabled to view it.
could you please send me the firmware?
thank you for you help.
02 Jan 2014 21:52 #17780 by dianjing
my 7e have 1 hold switch . 1 fmod swich
and 2 3sw(add by myself) connect way is from this
02 Jan 2014 21:53 #17781 by dianjing
can you help me again. to send me the new firmware for 2*3sw .
thank you !!
Time to create page: 1.051 seconds
