Single-Board Universal Module
20 Jun 2015 13:29 #34399 by PhracturedBlue
Replied by PhracturedBlue on topic Developing a universal module
Back on topic, I finished building the 0.9.4 board. My manual pick&place makes it so much easier. I don't think it saves any time, but for someone without steady hands, it is much less stressful to place with an x/y table. A few things I discovered:
1) The table gets in the way of my scope lamp. I have a pen-lamp on the table which helps but could really be brighter
2) The bearings aren't working well. I have linear bearings and roller bearings. The linear bearings allow for smooth up/down motion, but do not allow the pen to turn. The roller bearings allow for smooth rotation, but don't provide smooth up/down motion
3) I need better software for the camera on the table. I can' get a full-screen image. Also, the camera is at too great of an angle, which is making perspective hard to see.
4) my pcbgrip actually works really well with this to hold the board, but I need to figure out a better way to secure it to the table (I need to take it off the stand to use it with the x/y, and things move around a little/getin the way.
I had to fix several tombstoned parts on this round, but otherwise things look ok. I haven't yet tested the board though. I'll work on that today.
21 Jun 2015 07:44 #34436 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Developing a universal module
Not sure if it's of interest, but came across a Chinese PCB/Assembly/Sourcing/etc company recently that look pretty good; competing with seeed etc., but offering a "one stop shop". " Smart Prototyping ", I haven't priced up anything properly yet but their other pricing seems very competitive. You can send them your own bits and/or get them to source parts locally; "Based in the Special Economic Zone of Shenzhen we have direct access to most manufacturers of electronic components in the world and to the world famous electronic market of Asia.". I figure if these are the kind of guys who are typically assembling your quads etc., then they should know what they are doing with fine-pitch QFN parts :P
21 Jun 2015 12:50 #34445 by PhracturedBlue
Yes I've talked with them. If I were to have boards produced and shipped back to me, I'd probably use them. Their pricing is very reasonable for the service they provide. It doesn't help with the fundamental issue though....I don't think I can personally sell the boards.
21 Jun 2015 16:10 #34456 by PhracturedBlue
Well, to be worth it, I think we would need to order at least 100 of them. That isn't out of the question, my guess is I could sell that many. The problem remains that I am not convinced it is legal to sell them in the US. While the probability of the FCC getting involved is tiny, and even then, the board has been designed to be compliant, if it was found not to be, the fines can be extraordinary. It would be safer to find someone outside of the US to do fulfillment, and I still have hopes that is possible. Before that I need to actually get the board functioning properly though. I have high-hopes for the 0.9.4 board.
I have found 2 minor issues:
1) the holes for the usb plug are too small now that they've got vias in them. I had to cut the alignment holes off my USB plug.
2) there is too much paste on the regulator. That is actually just a problem with the stencil, so easily resolved.
Other than that, the new regulator and p-fet setup is working really well. A lot more reliable than the resistor setup I had previously.
The board boots up and communicates, but I haven't gotten all 4 modules working yet. I also have several software related issues I need to resolve before I can make any progress.
21 Jun 2015 16:32 #34457 by mwm
Replied by mwm on topic Developing a universal module
Well, if I do it, you don't have to worry about the FCC getting involved, I do. And that's why it's a "group order". I'm not selling them, I'm just coordinating a group of people who want to buy them. Since their minimum is a price point, not a board count, I have no idea what the minimum order is, and would have to learn how to use the tools I'd need to figure that out. Has someone worked out what a minimum order would be?
I'm curious as to why you think you could sell 100 of them. Based on the poor showing of the t-shirts, that seems optimistic. Sure, the module is actually useful, but better than an order of magnitude more?
21 Jun 2015 17:38 #34467 by SadSack
Replied by SadSack on topic Developing a universal module
Think of the long list of end user....
All active developers<<<as if you could keep them away
Devo10/8/12 Plug&Play<<<<no soldering, all using same hardware! Software only issues
Tranis <<< it's fits and does everything! Maybe controlled by tx?
Erx9 <<< as above
And all other brand, 3 wires + Antenna and bluetooth.
Is hundred gonna be enough :blink:
Ps Mwm post a survey in your blog on Regroup. Using your blog will hit vast majority of Regroup user.
22 Jun 2015 01:19 #34484 by mwm
SadSack wrote: Think of the long list of end user....
Fewer than 10.
SadSack wrote: Devo10/8/12 Plug&Play<<<<no soldering, all using same hardware! Software only issues
Don't forget us 6 owners! That's plug and play as well. I once swapped the CYRF between my 10 and 6 while chasing a problem. And the 7E users who would be willing to rig up the wiring for it. Now discount anyone who has a working MM, or has no interest in flying things that need a new module, and whose motto isn't "If it ain't broke, mod it!"
SadSack wrote: Tranis <<< it's fits and does everything! Maybe controlled by tx?
Erx9 <<< as above
I think this is the real difference, as they wouldn't be ordering deviation T-shirts. I suspect they outnumber the first two groups by a fair factor, even after you discount the ones who've already built a module using the modified MM plans. I think that changes the shortage on T-shirt orders from a factor of 10 to more like a factor of 2 or 3, which I'm willing to believe.
22 Jun 2015 01:59 #34487 by mikemacwillie
Replied by mikemacwillie on topic Developing a universal module
Hobbyking has been producing a few open source products lately.. Might be worth approaching them once it's all complete. Especially if it functions as a stand-alone module that can be put in a JR style housing / module bay.
22 Jun 2015 04:28 #34493 by RoGuE_StreaK
PhracturedBlue wrote: Yes I've talked with them.
Did I have a mental lapse and just recommend a service that I probably first found out about in this thread? :unsure: :lol:
12 Jul 2015 22:41 #35387 by Richard96816
Replied by Richard96816 on topic Developing a universal module
Wonderful progress and team work. Great ideas.
I've got a smattering of experience in a large collection of pursuits, expert in none. Much to assimilate here. Pardon me if I mis-comprehend.
Using a multiplexer between the transceivers and antenna doesn't feel right. I've seen better solutions in the distant past, but sadly can't recall them in detail. The single package of the multiplexer is handy, but costly of performance, I think. Especially if only one transceiver is meant to be enabled at a time.
Also, adding a microprocessor to a project is a game changer. Wonderful in many ways, though not so in others. Designers often overlook the power of the processor and create potential harmful error conditions. The processor should not be able to bring harm to itself, surrounding circuitry or others through bad programming or random crash conditions. These possibilities should be surveyed at various stages of design and prototyping. Scrutinize all inputs and outputs and consider worst-case scenarios.
Allowing a processor to selectively enable and disable a bank of transceivers is handy and powerful. Allowing it to enable all simultaneously, if that is not intended, is probably a bad idea. It's easy enough to provide additional circuitry to prevent it. If you only intend to build one unit such may be excusable. Probably not if you're planning to build dozens.
Microprocessor design requires additional responsibility.
I was given a DAK bread machine as a gift, years ago. It would mix, knead, and cook loaves of bread from start to finish. Come back when it's done. Mine was the first version. Happened by the kitchen in the middle of the baking phase one time -- the whole unit was glowing bright red. Plastic parts were sagging. The heater was on runaway. The processor had crashed, perhaps due to heat. And it was in sole control of the heating element. Needless to say, the next version built in a discrete safety override. Certainly not of the same scale and impact as an r/c transmitter, but an important lesson many should learn.
Please be careful.
16 Aug 2015 14:42 #36947 by frogamic
Replied by frogamic on topic Single-Board Universal Module
So I just spent the last 3 hours straight reading this thread from start to finish, and I have to say it's amazing to see what the community can do when everyone gets together, you've put together a real go-er. With this so operational already I'm hesitant to go putting holes in my new 7e for extra antennae when it might not be required soon.
I wonder if a similar sp4t rf switching circuit could be used with the multi-module to share a single antenna between the modules, or does it only work at unamplified power levels? (I know nothing about RF having chosen the computer science path over electrical engineering)
17 Aug 2015 03:30 #36962 by Richard96816
Replied by Richard96816 on topic Single-Board Universal Module
frogamic wrote: With this so operational already I'm hesitant to go putting holes in my new 7e for extra antennae when it might not be required soon.
Putting an antenna farm atop your 7e is not necessary. These antennas are thin pieces of flexible wire within a plastic tube. The original 7e antenna housing will accommodate multiple such wires. Add a module, along with it's antenna and do a range test. I think you'll find things work just fine with a single tube housing multiple antenna wires. Especially since only one is energized at a time.
I've only added one module (nrf24l01) to my 7e so far. But it works great with two antennas in the tube. Range test your's and decide.
7e's with multiple antennas on top are pretty ugly.
17 Aug 2015 03:53 #36963 by frogamic
Richard96816 wrote: The original 7e antenna housing will accommodate multiple such wires. Add a module, along with it's antenna and do a range test. I think you'll find things work just fine with a single tube housing multiple antenna wires. Especially since only one is energized at a time.
I already replaced the stock antenna with a flexible one. I also don't like the multiple antenna look which is why I'd like to make a multiplexer. Based on the datasheet of the PE42641 it can handle 35dB of power, more than the modules put out. I'm sure I can handle the logic portions of the circuit but knowing nothing about RF I wouldn't know how to design that portion or if it's even viable.
17 Aug 2015 08:56 #36968 by robca
Replied by robca on topic Single-Board Universal Module
Keep in ind that having multiple antennas of the same frequency close and parallel to each other is not an ideal configuration: the unused antenna actually absorbs energy from the radiating one and weakens the signal
On the Devo 7e, it's far better to have one antenna in the tube, and the other 90 degrees, at the base of the tube. that way the antenna influence each other much less. In general, it's better not to have the antenna in the vertical tube, btw, since that tends to be pointed towards the model: that type of antenna has a radiating patter that is the weakest along the axis, so when you point the tip of the antenna towards the model, you have the weakest signal possible. Multiple antennas in the same vertical tube is the worse configuration possible, from a signal strength point of view. Antennas inside the body, as far from wires/metal as possible, parallel to the top of the radio is a better antenna configuration
17 Aug 2015 20:22 #37002 by Richard96816
robca wrote: Multiple antennas in the same vertical tube is the worse configuration possible, from a signal strength point of view.
My (limited) testing simply doesn't support that claim.
It's fairly easy to test, before you unnecessarily 'uglify' your radio.
Adding a larger, longer, flexible antenna housing does make sense. So use one that will hold multiple wires.
17 Aug 2015 20:57 #37004 by moss
Replied by moss on topic Single-Board Universal Module
If you place the antennas parallel to each other at some critical point they may couple together and change the beam pattern. It could be worse, likely, or better.
A few wave-lengths apart should be safe, unless you need very long distance coverage. Placing the antennae inside the box should be OK unless it is absorptive plastic, which some black plastics, or metallized cases may be.
You don't need a Sigmund Freud sticking up out of the case, 2.4GHz 1/2 wave will fit easily inside the case.
20 Aug 2015 23:47 - 20 Aug 2015 23:48 #37085 by Durete
Replied by Durete on topic Single-Board Universal Module
I guess this small antennas should be your solution to no "uglyfy" your Devo :)
I have installed both at my 7e with very good range.
www.ebay.com/itm/221597888621?_trksid=p2...e=STRK%3AMEBIDX%3AIT
Last edit: 20 Aug 2015 23:48 by Durete.
20 Aug 2015 23:51 #37086 by mikemacwillie
Replied by mikemacwillie on topic Single-Board Universal Module
Sleeve dipoles like these bit.ly/1xXV6oY mounted internally are a good option as well, until the universal module is ready.
30 Sep 2015 10:06 - 30 Sep 2015 14:48 #38271 by TilmanBaumann
Replied by TilmanBaumann on topic Single-Board Universal Module
Wow, this is truly amazing.
I actually just started investigating on how to use the Deviation firmware in a module context. With all the different RF chips on one board.
It seemed very doable. But also a massive project.
Imagine my surprise when I realised what this universaltx directory meant.
You guys rock!
I would love to implement the opentx side of that if I get it to work. I love the idea of a universal TX module on my Taranis transmitter.
How is the current status of this then?
Board revision 0.9.4 oshpark.com/shared_projects/PNfiUaYx is the current one?
And the BOM on the first page of this thread is current too?
Any idea how much it will cost to buy the whole BOM in low quantities? Is it at this point advisable for me to just go-ahead and buy those parts and the board?
Or is there anyone gearing up to do a production run?
What is the license of the board files?
Does this board already fit the outline of a JR module case? Or would I need to change the board outline for that still?
And can someone explain to me how the serial protocol works? Obviosuly I would not run it in PPM mode.
I can not figure out what source file does the parsing of that.
PS: There are various ways to get except from FCC.
The easiest one is to sell from outside the US and let the customers sort out importation problems. :)
But also test and prototype equipment is excemt IIRC. Sell bare boards with no case. Sparkfun also does not do any FCC certification for their stuff.
www.sparkfun.com/tutorials/398
Last edit: 30 Sep 2015 14:48 by TilmanBaumann.
30 Sep 2015 18:07 #38282 by mwm
Replied by mwm on topic Single-Board Universal Module
Sounds like you haven't found the rcgroups forum on the DIY multiprotocol JR module. That use the multi-module and deviation protocol code ported to an ATTiny in a JR module. I believe someone already has OpenTx support for it, but I'm not positive. Because of that, one of the requirements on the board is that it fit inside a JR module.
Most of PB's code is GPL'ed under V3, but I couldn't find the sources for the board design to verify that.
The parts of the sparkfun page that are relevant for this are the one about "small manufacturer of open source hardware". Even selling kits is unclear, and not clearly a major advantage over something else. If we could set up a list of parts on some site that would let you click "add to cart" and get everything except maybe the PCB, that would be great. The real issue is that the assembly for this is beyond most people who'd like to have one. They probably don't have the equipment, and buying it just to make the one module is a bit excessive.
I'd like to create a non-profit organization that could coordinate contacts between people willing to build them gratis and those wanting to use them, maybe keep a US stock of parts that need ordering from china, but haven't been able to find anyone else interested, so don't have enough people to set up a legal non-profit.
Time to create page: 0.686 seconds
