Single-Board Universal Module
08 Mar 2015 15:30 - 08 Mar 2015 15:33 #29456
Replied by PhracturedBlue on topic Single-Board Universal Module
I ordered the 0.9.3 board as well (even though I don't have the 0.9.2 boards back yet). They have the same schematics, but I want to see whether the new compressed design can be assembled or not.
I also ordered one of these:
http://www.ebay.com/itm/221503432907
It is HM-12 based, and should support the latest smartphones with BLE as well as traditional devices. We'll see when it gets here.
Last edit: 08 Mar 2015 15:33 by PhracturedBlue.
- moss
09 Mar 2015 15:52 #29496
by moss
Replied by moss on topic Single-Board Universal Module
"...can be assembled or not..."
The parts density may be on par with typical phones, GPS modules etc, so for automated pick and place it should not be hard.
With a shaky hand, or two, tweezers and a 10X microscope it will be a challenge
09 Mar 2015 17:27 #29501
well, I violate a lot of the recommended restrict areas for the 0402 parts in the compressed layout, so I am not sure whether they'll be ok for pick and place or not. It mostly comes down to cost. I'm sure that there are pcb houses out there that could assemble this board. I'm not sure we'll be able to afford them though.
- moss
10 Mar 2015 15:57 - 10 Mar 2015 16:00 #29527
by moss
If so, it may be less expensive with the original shield, and have one made as a one-piece deal. It is really low-tech and should be source-able from a low cost supplier.
I would get an assembly quote from at least seeed to see which design to use.
It is already a 2-sided SMT board, could also some RF parts be located on layer 4?
Last edit: 10 Mar 2015 16:00 by moss.
10 Mar 2015 17:56 - 10 Mar 2015 17:56 #29529
I do not want to move RF components to the bottom of the board. I also don't want to speculate too much on manufacturability. Once it is actually working, I'll talk to smart-prototyping about it and see what they have to say.
Last edit: 10 Mar 2015 17:56 by PhracturedBlue.
14 Mar 2015 03:06 #29684
I got my 0.9.2 boards today as well as the peregrine switches. I soldered up the easy side (bottom) but I think I'll wait until tomorrow to take a shot at the top. With any luck we'll soon know if changing out the switches has fixed the issue
14 Mar 2015 20:19 #29706
Well after a couple hours of nerve-wracking placement, I've gotten the new board assembled. I had one 0402 component tombstone up on me, but I got that resolved and everything else looks ok. However, the board isn't powering up via USB. I don't see the issue as yet, but it seems to be related to the USB connector. I don't get 5V to the board through the USB connector, but if I apply 5v through the PPM connector, I get 3.3V on the board, so there doesn't seem to be any power/ground short. I didn't expose the full JTAG interface on the board, so I'll need to figure soething out to get it up and going.
- mikemacwillie
14 Mar 2015 21:12 #29707
by mikemacwillie
Replied by mikemacwillie on topic Single-Board Universal Module
Hopefully something simple like one of the diodes installed backwards?
14 Mar 2015 23:34 #29712
Nope, it was really as simple as the usb connector not being connected. I think I didn't seat it properly before putting the board in the oven. Fixing it was more of a pain than I expected, but I now have USB working...On to testing
14 Mar 2015 23:49 #29713
And.....the switch appears to be working!
All 4 RF chips are talking on the SPI bus.
I am seeing a signal passing through the switch now too!
I haven't verified that all 4 legs are working (the code is blindly iterating through the 4 RF chips, changing the switch every 20 seconds or so), but I am definitely seeing an RF signal passing through the switch now.
So I can finally actually make progress on programming and testing.
Happy days.
Happy days.
- Jasenk
15 Mar 2015 01:26 #29716
by Jasenk
-Jasen
Replied by Jasenk on topic Single-Board Universal Module
This is great news! Any talk about price targets for "mass production"? I'm really curious what ballpark this is in. $40-$50? Patiently waiting of coarse.
Is the Bluetooth part an option? or will it be a requirement?
This will be a dream come true for many people, no pressure. I wish I could contribute in some way.
Thanks in advance! I hope all goes well with testing. Thank you for taking the time in addition to the development to keep us updated on your progress.
-Jasen
15 Mar 2015 01:48 - 15 Mar 2015 02:02 #29717
bluetooth will be optional. It would initially have no functionality for a Deviation equipped radio. It would be required to use the board in a non-deviation equipped radio. In the future I'll likely add bluetooth support even for Deviation transmitters, but that'll likely be far in the future.
As far as selling it goes, I still don't know. My reading of the FCC regulations say that this module is a sub-assembly (and thus only needs to be tested once installed in a radio, and then only if it is sold that way). However, if the option to hook it up to a PC is developed, then the module becomes a stand-alone device and needs to go through licensing. In that case, it would need to come with an antenna and enclosure since FCC regulation would require that the tested antenna be the only one available. I don't think it is even possible to license the module for insertion to a transmitter. Again, the FCC requires testing with the antenna, and I would not be able to supply the final antenna (since the whole point is to reuse the existing Tx antenna)
Since the penalty for selling an unlicensed transmitter is very high, I would not be comfortable selling this in any form to anyone in the US. Thus I could:
a) sell them myself, but only outside the US
b) find someone outside the US who could sell into the US
I'm more likely to do (b), just because it is a hassle to ship internationally, and shipping from the US is very expensive these days. Either way I have no interest in monetizing this, so any profit would not come to me.
Seeed has a storefront that may make this possible (they're in China and following FCC requirements should then fall to the purchaser). However, I'm not sure this board could have sufficient volume to get them to agree (I think they have a minimum expected sale of 500 items to warrant their time). Checked and it is a 100 minimum which may be obtainable
I haven't done a recent analysis, but I think I estimated that these board would need to sell for ~$50 each to make it worthwhile for anyone to sell them.
Last edit: 15 Mar 2015 02:02 by PhracturedBlue.
- Jasenk
15 Mar 2015 02:27 #29718
by Jasenk
-Jasen
That's a lot to deal with. I'm guessing that even a high level soldering skill could not assemble this with out special equipment. You mentioned an oven earlier, do you use it to flow solder to the surface mount parts? I'm not that familiar with these processes. I am capable of high quality hand soldering but this sound like it's beyond even that type of capability. If I could assemble it myself it we be on me at that point. Would this be possible?
Might all be an exercise to see if it could be done, not sure what the end game will be then?
Thanks,
Thanks,
-Jasen
15 Mar 2015 02:35 #29719
SadSack manually assembled a board using only a soldering iron but the man is insane
I can't even imagine being able to do so. I believe 2 other users here built the 0.9 board, but I don't know what techniques were used. For me to do it, I use a stencil, solder-paste, tweezers, a home-built reflow oven, and a microscope to check my work. It takes me 2-3 hours (several breaks to keep me from going cross-eyed) and a lot of frayed nerves. I would never consider selling hand-assembled units. They also are quite expensive to do this way since you don't get to economies of scale.
- sbstnp
15 Mar 2015 07:36 #29723
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Single-Board Universal Module
Great news PB. $50 is totally reasonable and I'd buy that in an instant. Heck, I'd even get it for $100 without second thoughts.
Devo 10 + 4in1
- SeByDocKy
15 Mar 2015 10:37 #29726
by SeByDocKy
WHAOOHHH fantastic
Replied by SeByDocKy on topic Single-Board Universal Module
PhracturedBlue wrote: And.....the switch appears to be working!
Happy days.
WHAOOHHH fantastic
- SadSack
15 Mar 2015 12:19 #29729
by SadSack
Replied by SadSack on topic Single-Board Universal Module
Happy days!
It's only Qfn parts that are a pain. Cheap iron with correct tips very cheap from Bg. Oven is nice but not needed but reflow blower is a must and stencil. I Failed badly making stencil. If you have reflow blower moving USB is simple task.
- SadSack
15 Mar 2015 12:30 #29730
by SadSack
Once built what's needed to test board and check everything functioning? Ie test equipment.
15 Mar 2015 12:34 #29731
I do have a hot-air rework station, and that was my next fix if I couldn't jumper the connector. SadSack is being quite modest. hand-soldering 0402 parts takes some special skill even with the correct equipment. The stencils from oshstencil are very inexpensive and work great by the way. To the US they ship fast too. I'll post more once I've done some more testing.
15 Mar 2015 12:48 #29732
I wrote a test protocol that repeats a constant signal on a single channel (one any of the modules). I will use my RF Explorer to measure signal strength and compare to a stock board for each protocol. That should give confidence that the RF section has acceptable performance, and that all 4 chips are actually transmitting. After that, the code is basically ready to go, so I'll plug it into a Devo radio and try it out.
I also have the V0.9.3 board coming, maybe as soon as this next weekend. That one has the same circuit but a more compressed layout to support a proper shield. I need to attempt to build one and see how it goes.
I don't know if I mentioned it before, but these little boxes are great for managing SMT parts:
r.ebay.com/x5qfiY
With hundreds of capacitors that all look identical, I would go crazy without them.
r.ebay.com/x5qfiY
Time to create page: 0.390 seconds
- Single-Board Universal Module
