more model memories
01 Dec 2014 05:54 #26699 by cmpang
more model memories was created by cmpang
I used my 7e for all my r/c stuffs, planes, heli, boat and battle tanks.. and now come to a trouble, I run out of the model memory today. All 30 of them are being used and no more space for my new birds.
Is it feasible to add more model memory in the 7e..?
cmPang
01 Dec 2014 07:03 - 01 Dec 2014 07:04 #26700 by FDR
Replied by FDR on topic more model memories
It is as easy as copying the default.ini to model31.ini, model32.ini, and so on...
The numbering must be continuous.
Edit: In USB mode of course...
Last edit: 01 Dec 2014 07:04 by FDR.
01 Dec 2014 11:23 #26703 by cmpang
Replied by cmpang on topic more model memories
FDR wrote: It is as easy as copying the default.ini to model31.ini, model32.ini, and so on...
It works.. thx
cmPang
01 Dec 2014 19:04 #26710 by TomPeer
Replied by TomPeer on topic more model memories
This also works on a devo 10, but not on a devo 8s.
Does somebody knows why?
Tom
01 Dec 2014 19:15 #26711 by Joshua
Replied by Joshua on topic more model memories
It works also on a devo8s.
Did it on my Devo8s.
02 Dec 2014 16:30 #26727 by TomPeer
I just tried it again, still: does not work on my 8s.
02 Dec 2014 17:01 #26728 by Joshua
then you have not: model31.ini, model32.ini, and so on. ;)
02 Dec 2014 17:47 #26729 by magic_marty
Replied by magic_marty on topic more model memories
works on my devo8 i have 80 model files so i can keep copies of them at the bottom of the list in case i screw something up..:)
02 Dec 2014 19:25 #26730 by TomPeer
i did copy an working ini file to model31.ini. No gaps. But it does not stick. The model is not there. Also not to find with the computer (USB mode). It does not go over 30. Like i said it works fine on my devo 10 and i do no different things.
I realy could use some extra models but it won't work.
02 Dec 2014 21:01 #26731 by Joshua
goto USB mode.
goto your devo8 models folder.
copy model30.ini to c:\
rename model30.ini to model31.ini
copy model31.ini to your devo8 models folder.
switch of USB mode.
Did you now have 31 models?
02 Dec 2014 21:14 #26733 by aMax
Replied by aMax on topic more model memories
Copy the default.ini to the pc, rename it to model31.ini and copy it back.
Then copy some model files you already have to the flashdrive. Before you must
rename them to model32.ini to model3x.ini in increasing order.
Finished.
Works on Devo7e with now 10 more files.
03 Dec 2014 05:33 #26739 by magic_marty
Here you go model files 51 thru 100 ...they work on my Devo8 just by copying and pasting thru usb mode...
10 Dec 2014 19:11 - 10 Dec 2014 19:12 #26875 by TomPeer
Thank you all for your sugestions. I couldn't get it to work with 1 extra model (31), but i tried it with 10 extra models, copiing de default 10 times, and now it works.
Again, Thanks
Tom
Last edit: 10 Dec 2014 19:12 by TomPeer.
Time to create page: 0.056 seconds
