Preparing for the next Deviation release
23 Sep 2015 02:56 #37984
Replied by mwm on topic Preparing for the next Deviation release
On hold, a PB seems to be busy elsewhere again.
For now, you can test the nightlies, which are in general more reliable than the last release.
The last round of changes broke the build by overflowing a static buffer in the Devo in one of the systems. I've done a build and uploaded it in spite of the error at www.deviationtx.com/downloads-new/category/212-mwm-newnighlyt .
- andmiller
23 Sep 2015 03:42 #37987
by andmiller
Replied by andmiller on topic Preparing for the next Deviation release
Hey guys, great work by the way, been following and using for a while.
Anyhow, do we need to use the new dfu tool to flash the test builds? I am having issues with DSM protocols on Lemon Rx and would like to test the newer builds.
23 Sep 2015 03:46 #37989
You only need to use the new FDU tool for the F12E (or maybe it's the F7 - I forget), which uses a non-standard file system. For everything else, the Walkera DFuse tool works fine.
- richardclli
23 Sep 2015 03:49 #37990
by richardclli
Replied by richardclli on topic Preparing for the next Deviation release
Seems the emulator of your build is not Windows executable. I need to run it in Linux? It is elf binaries? Any related link to the instructions?
- richardclli
23 Sep 2015 03:51 #37991
by richardclli
What problem do you have about Lemon RX? I just got a few Lemon RX DSMX sat and have not tried it yet.
23 Sep 2015 04:02 #37993
You're right - the emulator is a FreeBSD binary, not a Windows one. I never got cross-compilation to work on BSD
. If you can use a Linux binary, let me know and I'll upload build and upload one of those. Not sure what that will need, though.
- richardclli
23 Sep 2015 04:06 #37994
by richardclli
Yes, Thanks, I can use both Linux and Windows binaries.
- andmiller
23 Sep 2015 04:08 #37995
by andmiller
There is a problem with dropped signal and range, on 150mw I only get maybe 30 meters, I have a genuine spectrum transmitter from a nanoqx (toy transmitter) that gets much better range. Have no issues with v911 or devo protocols. I found several instances of others facing this issue with 4.0.1
- andmiller
23 Sep 2015 04:10 #37996
by andmiller
Mwm, will the nightlies you linked contain the fix? Or do I need to use some test builds from indigo?
23 Sep 2015 22:15 #38008
Ok, I've uploaded new emulator builds for the new nightly test builds.
+andmiller, I don't know if those builds will have the DSM fix you're looking for in them or not. While the DSM code is much newer than the code in 4.0.1, there's also been some significant work on DSM that isn't in the current default branch, and that's what I'm building. It's what the automated builds would build if they were still working..
If you can point me to a commit or pull request or other indication of where they came from, I can probably figure it out.
- RoGuE_StreaK
23 Sep 2015 23:49 #38011
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Preparing for the next Deviation release
Out of interest, has anyone tried contacting orange or lemon to see if they'd assist with any of the DSM stuff? From what I've seen on rcgroups Lemon appear to be eager to help out / interact, but don't know if they'd be will to share their protocol work. Maybe if we can phrase an approach in such a way that they can see a financial benefit in their RX's being fully supported by deviation... ?
- andmiller
24 Sep 2015 01:28 #38014
by andmiller
The nightly you built seems to work much better. Before I only got like 30 meters on 150mw, I just tested in the house through 3-4 walls and 10 meters I can get a signal with 100uw, less than 1/1000th the power! I think there was another DSM fix for the bind dialog, but I'm not too concerned about that. Thanks for the info. BTW, I am using a lemon sat with a naze32 and its working pretty well now.
- richardclli
24 Sep 2015 01:45 #38015
by richardclli
Wow, nice to know that, I think I can just use my Lemon RX safely without any worry.
24 Sep 2015 01:45 #38016
I contacted both OrangeRx and LemonRx. The OrangeRx folks never replied. The LemonRx folks offered to send some sample Rx's to us, which offered I forwarded to PB. He said he would talk to them about it.
FWIW, LemonRx doesn't test with either OrangeRx or deviation, and doesn't recommend using either of them.
- andmiller
24 Sep 2015 02:21 #38019
by andmiller
Well, honestly I think there is only one vendor who supports Deviation. Just be sure to test and range test before operating your model, and be aware of your surroundings.
- richardclli
24 Sep 2015 02:58 #38021
by richardclli
I think I will do a check anyway.
24 Sep 2015 08:43 #38024
And who would that be?
andmiller wrote: Well, honestly I think there is only one vendor who supports Deviation. Just be sure to test and range test before operating your model, and be aware of your surroundings.
- andmiller
24 Sep 2015 12:03 - 24 Sep 2015 12:07 #38027
by andmiller
Didn't SkyArtec help out with a protocol? I seem to remember that from a while back, I could be mistaken. I was just trying to make the point that even though Deviation is not supported by the vendor, doesn't mean we shouldn't use it, as long as we are careful.
Last edit: 24 Sep 2015 12:07 by andmiller.
24 Sep 2015 13:42 #38028
Ah, yeah - I believe a couple of the vendors have helped with their protocol development to some degree or another. Either indirectly by releasing documentation on some of their internal protocols, or directly via their support forums, etc.
But you're right - vendor support - or lack thereof - of deviation is pretty much immaterial. You need to be careful even if you're using vendor-supported & tested stuff on both ends. Because after all, most of them don't tell you anything about what kind of testing they did!
- richardclli
27 Sep 2015 08:01 #38103
by richardclli
mwn, I have tried to download your emu build and run in Linuxx, but seems it is not the correct one. (still ends with .elf). Could you please give me the link for download the Linux emulator?
Time to create page: 0.306 seconds
- Preparing for the next Deviation release
