Assign beeper on switch
- Landin
04 Jun 2015 05:11 #33412
by Landin
Assign beeper on switch was created by Landin
Is there a way?
Like, say I want to set a beep when Im at 50% throttle and my naza is in hover mode, or a trippe sound when my knob is at 30% etc etc. Is there a way to make it happen? Just a beep to mix in and adjust the endpoints on it?
04 Jun 2015 15:20 #33425
Replied by mwm on topic Assign beeper on switch
Nope. I could see adding it though. Not as a mix feature, but similar to the telemetry config. When channel X in the mixer is <=/=/>= some value, beep. Would that do?
However, the telemetry warnings would be annoying if they happened during normal flight modes. I've had some RTF Tx's that do that - the V323 in headless mode, for instance - and that is just annoying. I'm not sure we could do this in some way that wouldn't be incredibly annoying.
Maybe think about how you want such things to behave, and open a feature request in the bug tracker (it's int he main menu on your left)?
- Durete
04 Jun 2015 15:41 #33426
by Durete
Replied by Durete on topic Assign beeper on switch
I think could be a good feature to warn about some states. For example beep when you engage the flip mode.
- Landin
06 Jun 2015 09:30 #33539
by Landin
Replied by Landin on topic Assign beeper on switch
Yes. And when you do alot of videorecording. For example if switching to gps hold position mode, and when throttle is exactly at hovermode there is a short beep so you know the copter will sit still.. I think there are many ways to use the beeping function.
Isnt it easy to just set the beeper as a source, that you can mix in on a channel? So it wont take that much datastorage in the transmitter?
Time to create page: 0.100 seconds
- Assign beeper on switch
