a7105 module on devo 6 and cant create new model
28 Sep 2015 08:56 #38153 by Timmz32
does the new wiring connection work with the nightly builds for devo 6 and the a7105 module or is there a seperate way to connect the module because when i connected it and turned it on it said the module was missing. it works in my 7e but not my 6? do i need to do anything special? any help would be great also when i flashed nightly builds and did everything the manual says i do not have any models and it wont allow me to create one i can chooose one but it wont save. or go to a page to bind or anyting?
28 Sep 2015 16:14 #38166 by mwm
Yes, the new wiring works with the nightly build in that setup. I'm using it.
Sounds like you've got a bad connection of some sort. The new wiring connection is to disable/enable transmission, which means you save power and transmit interference when the module isn't in use, but the rf module is still there so it shouldn't be missing even with the wrong wiring.
29 Sep 2015 10:26 #38210 by Timmz32
even without the module it wont allow me to save a new model. what could it be? if i got this right from a7105 module to the cyrf module 1 to vcc, 2 to tms, 3 to pin 3, 4 to pin 2, 5 to pin4, and on a7105 module 6 to 9 an 7 to 8 ?
30 Sep 2015 02:53 #38247 by mwm
What makes you think you can't save a model?
Time to create page: 0.050 seconds
