28 Feb 2016 00:59 - 28 Feb 2016 01:20 #43807 by blackmoon
Replied by blackmoon on topic 3in1 / 4in1 RF module
Thank you all, very informative.
Mike this is a really neat idea!
mwm wrote: An interesting - an possibly easy, but beyond me - hack would be a board that mounts "over" the CPU chip, using POGO pins to connect to each of the unused pins on the MCU and providing a through hole or pin to connect things to on it. That way, you could add more RF modules to any of them, as well as switches and possibly even analog inputs (have to see if any of those pins are usable for analog input).
Once we confirm these things things work, we should add a page to the wiki docs on adding a third module to each of these. And possibly a new forum thread on the topic of adding a third module sans the MM. It's a pretty common request.
The pcb where the pogo pins should be located shouldn't be hard to do, 3d print a cap for it that would lock onto the ST chip is out of my league though.
I'll ask a friend that is good at designing stuff if he can do something for the MCU cap. I'll give him the Devo7E MCU datasheet, then if he comes with something I'll try the pcb (I already have an idea about it, i think it could work).
So those" A4 (20), A8 (41), A15 (50), B3 (55), B4 (56), B9 (62), and C12 (53). The GPIO's for C13, C14, C15" are the usable pins on the 7E.
D0 and D1 not so sure ?
Last edit: 28 Feb 2016 01:20 by blackmoon.
28 Feb 2016 01:43 - 28 Feb 2016 02:09 #43808 by mwm
Replied by mwm on topic 3in1 / 4in1 RF module
blackmoon wrote: The GPIO's for C13, C14, C15" are the usable pins on the 7E.
Are you sure C13, C14 and C15 are usable? Those cpu pins are tied to the RTC and various oscillators as secondary functions. As are D0 and D1. I'd have to dig through the sources and see which clock/oscillators are used to figure out if they can be used.
Edit: Pins C13, C14 and C15 share the same functionality on the 8, and are used there. So those should indeed be ok. They are CPU pins 2, 3 and 4. Still not sure about D0 and D1, though, as those are oscillator in/out, and are given dedicated pins on the 8.
Last edit: 28 Feb 2016 02:09 by mwm.
28 Feb 2016 02:03 #43810 by mwm
TomPeer wrote: what about the 8s, I don't use this tx as much as the 10, so i would like to try at the 8s first.
Unused pins are A4 (29), A8 (67), A15 (77), B3 (89), B4 (90), C5 (34), D2 (83), D3 (84), D6 (87), D12 (59), D13 (60), E0 (97), and E1 (98).
Those are all probably unused on the 6 as well, however with C9 and C10 (which connect to the two extra switches on the 8) exposed on pads, there's less need for them.
Next step is the same as for the 7E: check the hardware to see if any of those pins have exposed pads.
28 Feb 2016 02:14 - 28 Feb 2016 02:15 #43811 by blackmoon
Oops forgot the question mark, I was in fact asking you if those would be the ones usable.
If not to much hassle could you confirm without doubt which ones can be used ? So I can forward that to the 3D slave :D
Thank you.
Last edit: 28 Feb 2016 02:15 by blackmoon.
28 Feb 2016 08:01 #43820 by mwm
blackmoon wrote: If not to much hassle could you confirm without doubt which ones can be used ? So I can forward that to the 3D slave :D
Thank you.
It's in the earlier message. For the 7e, definetely A4 through C12. For the 8, A4 through E1. I believe C12, 13 and 14 on the 7e should also be free since they are used on the 8 for switches and the like and have the same functionality on both mcus.
28 Feb 2016 09:30 #43823 by Fernandez
Replied by Fernandez on topic 3in1 / 4in1 RF module
www.deviationtx.com/forum/6-general-disc...evo7e?start=40#34661
PA0 and PA4 are certainly unused, but no exposed pins. Phracured blue have connected analog pots to those.
28 Feb 2016 12:11 #43826 by mwm
If they can be used for analog inputs, is reserved them for that.
And again, that PB failed to find pads isn't a good sign for there being pads.
28 Feb 2016 12:21 #43827 by TomPeer
Replied by TomPeer on topic 3in1 / 4in1 RF module
Thanks for this information but i do not know how to find those. i guess i just count the pins from a givven point? for example A4 is pin number 29? Where do i start to count?
28 Feb 2016 12:43 #43829 by dc59
Replied by dc59 on topic 3in1 / 4in1 RF module
Bad news , I think there is no unused pin with pad on DEVO 8S board.
28 Feb 2016 14:25 #43833 by Deal57
Replied by Deal57 on topic 3in1 / 4in1 RF module
Added pin reference illustrations to the spreadsheet where I've consolidated all of PB's pin usage for all the processors (post 43357). There are a few unused pins from TX to TX, that are also available on similar builds (e.g. the F7 uses almost all the 7e pins and a few more, the 8s uses the same pins as the 6s, etc.). I've examined the 6s closely (and related 8s pics) and while there are pins available, none of them appear to be exposed on pads.
Since there are three package (64-pin for 7, 100 pin for 6 and 8 and 10, 144 for 12) we need three pogos! Well, that and consensus on which pin functions to use. :dry:
28 Feb 2016 16:00 - 28 Feb 2016 16:02 #43839 by mwm
Deal57 wrote: Added pin reference illustrations to the spreadsheet where I've consolidated all of PB's pin usage for all the processors (post 43357). There are a few unused pins from TX to TX, that are also available on similar builds (e.g. the F7 uses almost all the 7e pins and a few more, the 8s uses the same pins as the 6s, etc.). I've examined the 6s closely (and related 8s pics) and while there are pins available, none of them appear to be exposed on pads.
Just to clarify - no unused pins on the 8s with pads. The 6S has pads for controls on the 8s (two extra switches and two extra trims) that aren't connected to controls. The trims are part of the button matrix, and hence unusable for other things, the two switches are digital GPIO pins, and should be usable for anything that that needs.
Why not have the 3d CAD file have places for all the pins of interest, and then the end user can just install the ones they want? There will be a problem with strength, but we need prints to test with.
Last edit: 28 Feb 2016 16:02 by mwm.
28 Feb 2016 18:58 - 28 Feb 2016 19:02 #43852 by blackmoon
I've done this sketch (don't laugh :p) to explain what I need to my friend. If he does one for lqfp64 the other two will be doable to.
Last edit: 28 Feb 2016 19:02 by blackmoon.
29 Feb 2016 11:31 #43875 by mwm
Well, I just got my 6S working with an NRF24L01 on C9. I think there may be an issue with the NRF24L01, though all the aircraft I have that use it are laggy. On the other hand, one is laggy with the RTF controller, and the other I never fly, so...
I just realized what's missing from this thread: links to the product pages! I went looking for them, but couldn't find all three. At least, I thought there were three: a 3-in-1 module, a 4-in-1 module, and a multimodule (with a rotary dial). Found the 3-in-1 and the multimodule, but not the 4-in-1.
Someone want to add them? Best if dc59 goes back and adds them to the first post.
29 Feb 2016 12:44 #43878 by blackmoon
The 4-1 is on the same page as the PPM Module, picture clickable, just below the price.
world.taobao.com/item/526271178299.htm?f...a.7728556.0.0.nacaZN
29 Feb 2016 13:42 #43879 by dc59
@mwm
I have added the product link to first post.
@blackmoon
Thanks!!
29 Feb 2016 19:13 #43888 by TomPeer
dc59 wrote:
TomPeer wrote: Does this mean you can solder in a third module (3 extra modules) without the multi module?
Yes, it is! use B7 pin to be third chip select.
I soldered in the cc2500 on pin B7, The tx recognizes the module and seems to work fine. Now i have to order some frsky receivers.
Thank you dc59!!
29 Feb 2016 19:29 #43892 by FDR
Replied by FDR on topic 3in1 / 4in1 RF module
TomPeer wrote: I soldered in the cc2500 on pin B7, The tx recognizes the module and seems to work fine. Now i have to order some frsky receivers.
Thank you dc59!!
Which TX?
29 Feb 2016 19:31 - 29 Feb 2016 19:33 #43893 by TomPeer
Devo 10
I would like to do this also with a devo 8s but i do not know to witch pin i could use. i do not know witch is 1, 2 and so on.
Last edit: 29 Feb 2016 19:33 by TomPeer.
29 Feb 2016 19:47 #43895 by FDR
If you look at it as the writing is on it, in the lower left corner there is a dot. The pins are numbered from that lower left corner around counter clockwise, so the bottom from left to right is 1..25, the right side from bottom up is 26..50 and so on...
29 Feb 2016 19:58 #43900 by TomPeer
Thanks.
I shall try to put a cc2500 module on one of the pins MWM provided.
I report back if succesfull (or not).
Time to create page: 0.918 seconds
