- bjr981s
28 Aug 2017 03:19 #64000
by bjr981s
Replied by bjr981s on topic 3in1 / 4in1 RF module
I assume this is the new 4 in 1 Suitable for the F12E? Without Ram swap requirement.
Is their another source. Amazon link says does not ship to Australia.
Cheers Brian
Cheers Brian
28 Aug 2017 04:05 #64003
Replied by FDR on topic 3in1 / 4in1 RF module
No, it seems the same as the one on Banggood...
- bjr981s
28 Aug 2017 07:51 #64005
by bjr981s
Ah, thats for there reply. Thats a pity I already have a couple of these.
Cheers Brian
Cheers Brian
- llinde
25 Sep 2017 05:33 #64641
by llinde
Replied by llinde on topic 3in1 / 4in1 RF module
All of a sudden my Devo 10 with 4-in-1 module developed problems.
The range is only about 4 to 5 feet. I did not change anything in hardware and software configuration.
Does this mean the 4-in-1 module is gone, or can it also be another hardware or software problem.
I already checked connecting a different antenna direct to the 4-in-1 module, this has no effect.
25 Sep 2017 06:04 - 25 Sep 2017 06:10 #64642
Replied by vlad_vy on topic 3in1 / 4in1 RF module
Most likely you damage RF power amplifier at 4in1 module. It can be damaged if transmitter powered on without connected antenna.
Last edit: 25 Sep 2017 06:10 by vlad_vy.
- llinde
25 Sep 2017 06:40 #64644
by llinde
I was thinking that too, but antenne was never off with the transmitter on....vlad_vy wrote: Most likely you damage RF power amplifier at 4in1 module. It can be damaged if transmitter powered on without connected antenna.
25 Sep 2017 07:04 - 25 Sep 2017 07:04 #64645
If you have white Devo 10 with detachable antenna, I think it has UFL connector at small PCB inside antenna holder. That UFL connector can lost contact with antenna, I had such case with Devo 8s.
Last edit: 25 Sep 2017 07:04 by vlad_vy.
- llinde
25 Sep 2017 07:52 #64646
by llinde
Otherwise I might replace the 4-in-1 and immediately have the same problem...
I have indeed a white Devo10, is there an easy way to check that connector?vlad_vy wrote: If you have white Devo 10 with detachable antenna, I think it has UFL connector at small PCB inside antenna holder. That UFL connector can lost contact with antenna, I had such case with Devo 8s.
25 Sep 2017 08:03 #64647
You can check resistance between RF module UFL connector and output Antenna connector, for both ground and both center contarts.
- llinde
25 Sep 2017 14:24 #64655
by llinde
Is it also possible to check resistance with UFL connector connected to the 4-in-1 board? For ground that should be no problem because I think the shielding on the board is grounded, but is there a connector point on the 4-in-1 that is directly connected to the antenna signal?
Do you mean the connector on the wire that is going to the antenna? If yes, both ground and center are zero at both ends, meaning they should be OK.vlad_vy wrote: You can check resistance between RF module UFL connector and output Antenna connector, for both ground and both center contarts.
25 Sep 2017 14:33 - 25 Sep 2017 14:34 #64656
Last edit: 25 Sep 2017 14:34 by vlad_vy.
- llinde
25 Sep 2017 16:02 #64661
by llinde
What to do next, replace 4-in-1 module?
Checked, looks OK too...vlad_vy wrote: Center pin from 3 pins on the side with 7 pins (2 3 2).
[/attachment]
- wasp09
25 Sep 2017 19:52 #64664
by wasp09
Replied by wasp09 on topic 3in1 / 4in1 RF module
Replace RF power amplifier.
- llinde
25 Sep 2017 20:10 #64665
by llinde
Is there a way to check that is the problem or can there be no other reason to cause these problems.
I still don't understand what can have happened, since al antenna connections seem to be OK now.
I'm afraid I'm not expert enough to do that.wasp09 wrote: Replace RF power amplifier.
- llinde
26 Sep 2017 20:15 #64679
by llinde
I'm not happy because I don't know what caused this, all measurements on the antenna were OK.
Is there something I can examine or repair on the defect module?
I replaced the 4-in-1 module completely and now my Devo 10 is working OK again.llinde wrote: What to do next, replace 4-in-1 module?
- goebish
- NRF Weirdo
28 Sep 2017 12:08 #64717
by goebish
Replied by goebish on topic 3in1 / 4in1 RF module
Is it the end of the 4-in-1 and the start of a new era ?
Invalid consumer key/secret in configuration
28 Sep 2017 12:15 #64718
Is that an error message?
Where did you get that?
- goebish
- NRF Weirdo
28 Sep 2017 16:56 #64721
by goebish
Sorry, nothing really important, I had thought someone made an universal RF using an esp32, but I was wrong.
- devoflyer
23 Nov 2017 10:04 #66094
by devoflyer
Replied by devoflyer on topic F7 Adding an RF Module
Been searching around on the site but cant find anything definitive for the F7.
Picture of F7 Board with NRF24L01 (U.FL Antenna) on right.
Can anyone confirm what the pins get connected to.
From what I've read it connects to A13, A14 and A15 for the Multi module.
I only need one of these but don't know where it is on the board.
4 in 1 Module (for pin identification)
On the Module I can see i need to connect,
From NRF24L01 to existing RF Module.
3.3V and CE to VN
Mosi to Mosi
Miso to Miso
Gnd to Gnd
Sck to Sck
I'm assuming CSN goes to either A13, A14 or A15 (dont know where they are).
I'm unsure where to connect IRQ from the NRF24L01
Any and all help is apreciated.
Attachment not found
3.3V and CE to VN
Mosi to Mosi
Miso to Miso
Gnd to Gnd
Sck to Sck
- retiredfist
28 Nov 2017 22:26 #66244
by retiredfist
Replied by retiredfist on topic Devo 8s 4 in 1 module
Could anyone please help me take a picture inside their Devo 8S with the 4 in 1 module along with where the pinouts go.
Please...
Please...
Time to create page: 0.446 seconds
- Devo 12s 3in1 / 4in1 RF module neat installation.
