22 May 2016 04:16 #48995 by VeGani
Replied by VeGani on topic 3in1 / 4in1 RF module
I follow the instructions on BG page, and also your post, dc59.. Not sure if I accidentally damage the board during my attempt to remove the pin n solder the wires.. Considering my soldering skill, probably I should use dupont wire instead of remove the pin..
22 May 2016 14:10 #49015 by dc59
Replied by dc59 on topic 3in1 / 4in1 RF module
VeGani wrote: I follow the instructions on BG page, and also your post, dc59.. Not sure if I accidentally damage the board during my attempt to remove the pin n solder the wires.. Considering my soldering skill, probably I should use dupont wire instead of remove the pin..
Would you post some pictures of your 7E wiring and hardware.ini setting?
23 May 2016 07:07 #49062 by valley_nomad
Replied by valley_nomad on topic 3in1 / 4in1 RF module
cmpang wrote: finally get some time to wire up the new 4-in-1 module from Taobao. Connections are straight forward with the attached diagram.
Output power verified with my primitive spectrum analyser to be on par with the original 7e Devo and the other three add on modules.
Range tested with Devo RX601, WLToys V931 (KN), FrSky X4R, WLToys v911 (Flysky), JXD385 (V202),Syma Car (Syma X8) all to be on par with original.
I do ask the seller about the PA/LNA issue. The reply is all done within the modules. No further explaination given tought..
cmPang
Is this the same picture of 3-in-1 installation on BG?
23 May 2016 07:36 - 23 May 2016 08:03 #49063 by valley_nomad
kahuna001 wrote:
Left original Rev and Right Current.
The small 12pin chip looks like 2.4GHZ CMOS SP3T ANTENNA SWITCH RFX333 ( www.skyworksinc.com/uploads/rfx/RFX333_DataSheet.pdf )
The big 8pin chip must be a MCU, maybe one of those ATTiny chips
Don"t know why their markings needed to be removed....
Last edit: 23 May 2016 08:03 by valley_nomad.
23 May 2016 11:50 - 23 May 2016 11:57 #49069 by midelic
Replied by midelic on topic 3in1 / 4in1 RF module
The chip maybe like 4in 1 is similar CD4052 multiplexer.
The control can be via PA /LNA pins and CD4052.
Last edit: 23 May 2016 11:57 by midelic.
23 May 2016 14:14 #49074 by bricamac
Replied by bricamac on topic 3in1 / 4in1 RF module
How to connect this 3in1 FR module on Devo 12S ? Especially the PINs on the main board that we could use ( for example like the B7 on Devo 10)
Photo of DEVO 12S board :
23 May 2016 21:07 - 23 May 2016 21:09 #49084 by valley_nomad
midelic wrote: The chip maybe like 4in 1 is similar CD4052 multiplexer.
The switch has to be a RF-specific chip.
Can somebody restate the exact issue we have with this 3-in-1 module that has been sold so far? Is there a way to fix it?
Last edit: 23 May 2016 21:09 by valley_nomad.
24 May 2016 06:54 #49108 by VeGani
I will try to redo my wire soldering on this module first.
BTW, earlier I've installed module A7105 from my V911 transmitter according to DeviationTx manual. Should I remove this module before I install this 3in1, or both can be installed at the same time with the same wiring and hardware.ini shown on BG page?
24 May 2016 09:19 - 24 May 2016 09:21 #49114 by valley_nomad
HappyHarry wrote:
wasp09 wrote: The dead original RF module in my 7e was different from the 8S module I replaced with. The original module was marked 6S. Devo 6S does not use 6S RF module then. :)
the main board on the 7e is marked 6f, was that not what was on the module?
wasp09 wrote: YJ,
It is still a mystery on how the 3 in 1 controls the X2401C on board. Current alone does not tell us everything, like whether the X2401C is switched into LNA mode if we need to receive.
Regards,
there is no lna for the a7105 and nrf24l01 on the 3in1 board, and as of the latest shipment from banggood there have been no changes to the 3in1. when i find time tonight i'm going to review it on BG to let people know of this as some stuff requires this to bind as well as telemetry
[edit]
i was too slow lol
[/edit]
On TaoBao's 3-in-1 page the seller mentioned its limitation :
"高频头带有功率放大器(PA)和低噪声放大器(LNA),由于DEVO系列固件不提供相关控制功能,所以只能默认发射时开启PA,接收时不能开启LNA,也就是说,支持发射功率放大,也可以接收回传数据,但是回传距离有限。"
"The RF module has the PA and LNA. Due to the fact that Devo firmware doesn't provide corresponding control function, it can only turn on the PA by default when transmitting and can not turn on the LNA when receiving. In other words, it supports transmission power amplification and also supports receiving telemetry data with limited distance"
Last edit: 24 May 2016 09:21 by valley_nomad.
24 May 2016 09:21 #49115 by dc59
valley_nomad wrote: Don"t know why their markings needed to be removed....
I asked TaoBao seller (3in1 board designer) about this question, he told me as he know there is someone trying to clone this board,
he must protect his product , that is why he removed the mark on some chip.
24 May 2016 09:24 #49116 by dc59
VeGani wrote: I will try to redo my wire soldering on this module first.
There is a A7105 in 3in1 module already, you don't need A7105 from V911 TX, just remove it!
24 May 2016 15:31 - 24 May 2016 18:50 #49129 by wasp09
Replied by wasp09 on topic 3in1 / 4in1 RF module
wasp09 wrote: YJ,
Regards,
[edit]
i was too slow lol
[/edit]
It may be more than a matter of not having a LNA. The "PA" chip, say RFX2401C, has both PA/LNA. It is sitting in between the RF chips and the antenna. Unless the board has a way to bypass the "PA" chip and connect the RF chips to the antenna on receiving, the reception could be way worse than just not having a LNA especially if the RF chips are sitting inside a metal shield.
Besides enabling PA or LNA, the chip can be powered down. However the insertion loss between TXRX and ANT would be something like 50dB, not really passing through...
Regarding the devo code not providing control, it does control PA/LNA switching on standalone RF modules using outputs from the RF chips, on A7105 through setting GIOPIN1 and 2 (see A7105_SetTxRxMode), on CC2500 through setting IOCFG0 and IOCFG2 (see CC2500_SetTxRxMode) and on NRF24L01 by setting TX mode which changes VDD_PA (see NRF24L01_SetTxRxMode). As I said before either the MCU onboard has to listen in the spi or it has to monitor those IO/VDD_PA pins to know about mode changes. It probably is too complicated for hardware multiplexer to decode them directly. Perhaps it is time for the N in 1 board suppliers to tell the deviationtx developers what the boards need to work correctly. It looks like extra control pins are already there on board, we just need to know how to make use of them.
BTW, CD4052 probably won't work too well for switching 2.4GHz.
Last edit: 24 May 2016 18:50 by wasp09.
24 May 2016 19:59 - 24 May 2016 20:03 #49138 by valley_nomad
wasp09 wrote: ... It may be more than a matter of not having a LNA. The "PA" chip, say RFX2401C, has both PA/LNA. It is sitting in between the RF chips and the antenna. Unless the board has a way to bypass the "PA" chip and connect the RF chips to the antenna on receiving, the reception could be way worse than just not having a LNA especially if the RF chips are sitting inside a metal shield.
Regarding the devo code not providing control, it does control PA/LNA switching on standalone RF modules using outputs from the RF chips, on A7105 through setting GIOPIN1 and 2 (see A7105_SetTxRxMode), on CC2500 through setting IOCFG0 and IOCFG2 (see CC2500_SetTxRxMode) and on NRF24L01 by setting TX mode which changes VDD_PA (see NRF24L01_SetTxRxMode). .....
OK. My understanding is that this 3-in-1 module almost doesn't have receiving capability at all, which is WORSE THAN the separate RF module approach.
Last edit: 24 May 2016 20:03 by valley_nomad.
24 May 2016 20:10 #49139 by HappyHarry
Replied by HappyHarry on topic 3in1 / 4in1 RF module
that's an outright falsehood, deviation does indeed have control for pa/lna switching for all of the modules, so it's clearly a limitation of his design, plus it isn't mentioned on banggood where most of us non chinese reading people purchased these from. it needs to be made clear on banggood to stop other people purchasing them under false pretenses (as well as the 4in1 issues midellic and pascal found), unfortunately bangood doesn't seem to be willing to post my review that mentions these issues, even though i clearly purchased 3 of the 3in1's.
24 May 2016 20:56 #49141 by Fernandez
Replied by Fernandez on topic 3in1 / 4in1 RF module
I also have also doubts about RF path of this module, at 2.4ghz any length few mm of pcb line, causing loss or impedance mismatch, unless really proplerly designed. striplines.
It would be much better if the RF outputs of each chip oriented with its rf output, directly connected to the 3way switch. Also the antenna output stripline after the LNA has some low pass capacitors, I hope this is designed properly.
In my opinion would be more optimal keep RF output very short and use a ceramic bandpass filter for 2.4ghz as some other modules use, at least then be sure the output has no loss.
And indeed the pa//lna pins must be switched.
24 May 2016 21:15 - 24 May 2016 21:17 #49144 by valley_nomad
Additionally according to RF path in RFX2401C the statement on 3-in-1 module's capability of receiving telemetry data with limited distance may also be false
Last edit: 24 May 2016 21:17 by valley_nomad.
24 May 2016 21:44 - 24 May 2016 21:45 #49145 by midelic
CD4052 on 4in1 module and is not used for switching 2.4Ghz.It is connected with PA/LNA chip TXEN pin and PE1 PE1 Peregrine antenna swicth pins.
If you check data sheet of CD4052 you'll understand how it is working
Last edit: 24 May 2016 21:45 by midelic.
24 May 2016 22:01 #49147 by valley_nomad
midelic wrote: CD4052 on 4in1 module and is not used for switching 2.4Ghz.It is connected with PA/LNA chip TXEN pin and PE1 PE1 Peregrine antenna swicth pins.
I see. It looks like a fix here :)
24 May 2016 22:11 - 24 May 2016 22:12 #49148 by midelic
Yes I'm preparing for a fix on A7105 and NRF 24L01 LNA.
I need to remove the pullup 4.7K resistor on TXEN pin cut 3.3V trace corresponding to A7105 and bridge togheter CD4052, pin12 with pin 11,and modify code for using CYRF XOUT switching A7105 to LNA.
Last edit: 24 May 2016 22:12 by midelic.
24 May 2016 22:22 #49151 by valley_nomad
midelic wrote: Yes I'm preparing for a fix on A7105 and NRF 24L01 LNA.
That is for 4-in-1?
The solution for 3-in-1 may be a bit different if it uses RFX333 as switch which has three control bins.
Time to create page: 0.475 seconds
