19 Oct 2016 08:08 #55128 by joeblack
Replied by joeblack on topic 3in1 / 4in1 RF module
Would also like to buy a 4in1 module for my DEVO10.
I´m from Austria/Europe and TAOBAO doesn´t ship there.
My Question:
is there a way to buy such a 4in1 Modul for me now or do i have to wait until it´s available at Banggood or Aliexpress..... :woohoo: .
thanks in advance
joe
19 Oct 2016 08:41 #55131 by ajtank
Replied by ajtank on topic 3in1 / 4in1 RF module
It seems the other fellows used an agent called Taobao Focus to buy the module from China.
19 Oct 2016 10:57 #55132 by DaveyP
Replied by DaveyP on topic 3in1 / 4in1 RF module
Check my post (and others) www.deviationtx.com/forum/7-development/...dule?start=860#54118
As ajtank suggests, use Taobao Focus to do the transaction for you.. they even send pictures of the item so you can check it before they dispatch.
19 Oct 2016 12:54 #55142 by epilot
Replied by epilot on topic 3in1 / 4in1 RF module
The module is available on Banggood now.
4in1 module
19 Oct 2016 13:59 #55143 by Elmtree
Replied by Elmtree on topic 3in1 / 4in1 RF module
I installed my 4in1 module, but I'm not sure if I need to enable the amps in the hardware.ini. Do I?
19 Oct 2016 14:32 #55147 by raketemensch
Replied by raketemensch on topic 3in1 / 4in1 RF module
epilot wrote: The module is available on Banggood now.
4in1 module
Is this the new drop-in module? If so, I guess it needs a little soldering on the 7e, but I haven't seen a guide for it yet. I'd love to pick this up, but I'm not sure if I'd be capable of installing it yet.
19 Oct 2016 15:02 #55148 by victzh
Replied by victzh on topic 3in1 / 4in1 RF module
This "drop-in" module still requires soldering even in Devo 10. The small 3 position connection point should be soldered as shown on one of the pictures on Banggood.
19 Oct 2016 15:04 - 19 Oct 2016 15:13 #55149 by ds864
Replied by ds864 on topic 3in1 / 4in1 RF module
Yes me too. The picture on the site looks like the Devo 10.
I've been looking at this ( www.hacksmods.com/category/devo/ ) to see how to do each module but the 4 in 1 sounds like a better move. I just need some step-by-step instructions for the Devo 7e if this is compatible?
Do you have to remove the existing module? Will this then have a better range than the stock module?
Last edit: 19 Oct 2016 15:13 by ds864.
19 Oct 2016 15:28 #55150 by hexfet
Replied by hexfet on topic 3in1 / 4in1 RF module
Elmtree wrote: I installed my 4in1 module, but I'm not sure if I need to enable the amps in the hardware.ini. Do I?
Yes, enable the pa for all.
19 Oct 2016 15:44 - 19 Oct 2016 15:44 #55151 by Fer
Replied by Fer on topic 3in1 / 4in1 RF module
At last. It is available in Banggood. Of course i have already purchased mine (at a price of 55 euros with all the commisions and fees for the agent), but it is good to know that banggood now offers this module.
Until a better option appears, that solves the LNA problem with a hardware fix, this is the best option so far for DEVO 10 users.
Last edit: 19 Oct 2016 15:44 by Fer.
19 Oct 2016 15:46 #55152 by victzh
@ds864 - for installing 4-in-1 you need to remove existing module because 4-in-1 has CYRF6936 as well. It will have better range because it has PA - Power Amplifier - and though stock module has it also it is artificially limited.
19 Oct 2016 15:55 #55154 by ajtank
4in1 module
This module is mounted on a carrier board which is designed specifically for Devo 10. For Devo 7E you need to get the module without the carrier board
For 7E it seems the 3-in-1 is more appropriate.
19 Oct 2016 16:05 #55155 by victzh
3-in-1 still has problems with protocols using receiving part of RF - either telemetry or with auto-acknowledge. Today 4-in-1 is the best module to install despite higher cost. Devo 10 specific module is also suitable for 7E, there are instructions for this here (thanks, HappyHarry) www.deviationtx.com/forum/how-to/5955-7e...-4in1?start=20#50816
19 Oct 2016 16:08 #55156 by HappyHarry
Replied by HappyHarry on topic 3in1 / 4in1 RF module
ds864 wrote: Yes me too. The picture on the site looks like the Devo 10.
devo 4in1 fitting guide to the 7e is availabe here >> www.deviationtx.com/forum/how-to/5955-7e...he-devo-version-4in1
19 Oct 2016 16:25 - 06 Mar 2017 06:04 #55157 by vlad_vy
Replied by vlad_vy on topic 3in1 / 4in1 RF module
Summary of module connections (3 wires) (Devo 6, Devo 7e, Devo 10, Devo 8, Devo F12E, Devo 12):
7105 = TMS pad (A13)
2500 = TCK pad (A14)
2401 = ???
4in1 module pinout
Devo6
2401 = C10
hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = C10
has_pa-nrf24l01 = 1
; enable-multimod = A13
Devo7e
2401 = A15
hardware.ini
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
  has_pa-cyrf6936 = 0
  enable-a7105    = A13
  has_pa-a7105    = 1
  enable-cc2500   = A14
  has_pa-cc2500   = 1
  enable-nrf24l01 = A15
  has_pa-nrf24l01 = 1
Devo10
2401 = B7
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
Devo8, Devo F12E (PCB looks slightly different but MCU and pin are the same)
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
Devo12
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 06 Mar 2017 06:04 by vlad_vy.
20 Oct 2016 07:37 #55181 by ds864
Thanks for the help on this it still looks like a lot of work fitting the 4-in-1 into a 7e. I kind of like the idea of the 3-in-1 as I won't be touching the original module. This way if it all goes wrong I still have that module working (no worse off). But what are the issues with the 3-in-1 you mention?
20 Oct 2016 08:48 #55182 by vlad_vy
I'm not sure, but it looks like 3in1 has problem with LNA for A7105 and nRF24L01 chips.
20 Oct 2016 13:59 #55190 by justyn07
Replied by justyn07 on topic 3in1 / 4in1 RF module
i just order a 4 in 1 module from banggood and i never done the hardware ini. do you just copy paste the ini.
20 Oct 2016 14:25 #55191 by vlad_vy
You need UNIX style editor to edit *.ini files. For example, "Notepad+".
20 Oct 2016 15:24 #55195 by justyn07
thank you. i have notepad+.
Time to create page: 0.890 seconds
