- joeblack
I´m from Austria/Europe and TAOBAO doesn´t ship there.
My Question:
is there a way to buy such a 4in1 Modul for me now or do i have to wait until it´s available at Banggood or Aliexpress.....
thanks in advance
joe
- ajtank
- DaveyP
As ajtank suggests, use Taobao Focus to do the transaction for you.. they even send pictures of the item so you can check it before they dispatch.
- epilot
- Elmtree
- raketemensch
epilot wrote: The module is available on Banggood now.
4in1 module
Is this the new drop-in module? If so, I guess it needs a little soldering on the 7e, but I haven't seen a guide for it yet. I'd love to pick this up, but I'm not sure if I'd be capable of installing it yet.
- victzh
- ds864
I've been looking at this ( www.hacksmods.com/category/devo/ ) to see how to do each module but the 4 in 1 sounds like a better move. I just need some step-by-step instructions for the Devo 7e if this is compatible?
Do you have to remove the existing module? Will this then have a better range than the stock module?
Yes, enable the pa for all.Elmtree wrote: I installed my 4in1 module, but I'm not sure if I need to enable the amps in the hardware.ini. Do I?
- Fer
Until a better option appears, that solves the LNA problem with a hardware fix, this is the best option so far for DEVO 10 users.
- victzh
- ajtank
4in1 module
This module is mounted on a carrier board which is designed specifically for Devo 10. For Devo 7E you need to get the module without the carrier board
For 7E it seems the 3-in-1 is more appropriate.
- victzh
- HappyHarry
ds864 wrote: Yes me too. The picture on the site looks like the Devo 10.
devo 4in1 fitting guide to the 7e is availabe here >> www.deviationtx.com/forum/how-to/5955-7e...he-devo-version-4in1
7105 = TMS pad (A13)
2500 = TCK pad (A14)
2401 = ???
4in1 module pinout
Devo6
2401 = C10
hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = C10
has_pa-nrf24l01 = 1
; enable-multimod = A13
Devo7e
2401 = A15
hardware.ini
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
Devo10
2401 = B7
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
Devo8, Devo F12E (PCB looks slightly different but MCU and pin are the same)
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
Devo12
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- ds864
- justyn07
- justyn07
- Devo 12s 3in1 / 4in1 RF module neat installation.
