Storing RX ID ?
- goebish
- NRF Weirdo
17 Apr 2016 13:04 #46693
by goebish
Storing RX ID ? was created by goebish
I started having a look at the FlySky AFHDS 2A protocol
www.deviationtx.com/forum/protocol-devel...l-as-used-i10-i6-it4
RX ID (32 bit) needs to be stored on the TX after bind, how can I store it ?
I thought of protocol options, but that's not very clean, do we have another way to store values ?
17 Apr 2016 13:08 #46694
Replied by PhracturedBlue on topic Storing RX ID ?
why are protocol options the wrong place? this seems like an ideal place to me. I assume there is no reason to view this value? We should enhance the protocol options to have a non-visible storage, which you could then use. Alternatively, can the fixedid be used for this value? Do we need both a fixed-id and a Rx-Id?
- goebish
- NRF Weirdo
17 Apr 2016 13:10 #46695
by goebish
Replied by goebish on topic Storing RX ID ?
Yes, that would be better to hide it.
RX ID is sent by the RX at bind time then it needs to be sent by the TX in every packets.
- goebish
- NRF Weirdo
17 Apr 2016 14:49 #46703
by goebish
No, a TX ID is also required.
www.deviationtx.com/forum/protocol-devel...6-it4?start=20#46630
- goebish
- NRF Weirdo
07 Aug 2016 13:22 - 07 Aug 2016 14:02 #52540
by goebish
Sorry to revive this thread, but I need a solution for that.
Until now I used protocol options to store RXID for my afhds2a test builds but there're some issues with that:
- it shouldn't be user modifiable
- I need to store a 32 bit value, looks like only 16 bit (int16_t) can be used for option items so:
- I've to use 2 16 bit values, this is becoming a problem because:
- that takes 2 protocol option "slots", which are limited to 4 per protocol (NUM_PROTO_OPTS), and now I'm running out of slots for a new option (SBUS output enabled/disabled)
Do we already have an existing solution for this issue ?
If not, maybe we could add a function to ProtoCmds eg case PROTOCMD_GETMISCOPTIONS and a .proto_miscopts[] field to the Model struct ?
Last edit: 07 Aug 2016 14:02 by goebish.
Time to create page: 0.148 seconds
- Storing RX ID ?
