Wishlist for a custom Transmitter board
23 Jul 2017 06:04 #63560 by 52dgj
Replied by 52dgj on topic Wishlist for a custom Transmitter board
dc59
Hello, may I ask if you have his contact information?
你好,请问你有他的联系方式吗?
If it is not convenient to say, please call me add me micro letter,1820716861
如果不方便说,请叫他加我微信或腾讯QQ,1820716861
Thank you
24 Jul 2017 01:56 #63570 by dc59
Replied by dc59 on topic Wishlist for a custom Transmitter board
52dgj wrote: dc59
你好,请问你有他的联系方式吗?
Thank you
PM sent.
02 Aug 2017 13:44 #63685 by shahidali55
Replied by shahidali55 on topic Wishlist for a custom Transmitter board
Just joined the devo7c train. Flashed the 256k bootloader on to a bare development board, wired the SSD1306 display. It boots !!! Now waiting for the flash chip to arrive . . .
silpstream wrote:
I got things working on the SSD1306. Code changes to the init script was required as well as a hardware pin for reset of the old on bootup. After that everything went well on the screen side.
I also ended up not being able to get out of the "Missing Modules" screen, as hitting "OK" would just reboot the board. Traced it down to somewhere in the MULTI_MOD stuff, so I disabled that for now as I don't have any rf_modules to hookup. I assume, it really doesn't like the fact that no modules are present.
So now it boots up (without the reboots), displays on the SSD1306 OLED screen and we can play around in the menus.
Connections for screen as follows:
SSD1306 -> MCU Port.IO#
CLK -> A.5
MOSI -> A.7
RESET -> B.1
D/C -> C.5
CS -> B.0
The file is attached here (I named it devo7c as in devo7custom) and it WILL ONLY work for a SSD1306 screen currently. It's based on the latest nightly.
02 Aug 2017 19:03 #63688 by Fernandez
Replied by Fernandez on topic Wishlist for a custom Transmitter board
Nice !!
Thanks for sharing, do you think we need a separate build? Or could we use u7e build and add in hardware.ini a selector for the display driver?
25 Sep 2017 15:01 #64660 by Fernandez
BTW that O-led definitively doesn't look bad at all !
Are there no such small boards, with 256 or 512k which can run full featured U7E code directly ?
Maybe someday I'll build a deviation car, steering wheel transmitter with it...........
25 Sep 2017 22:15 - 25 Sep 2017 22:15 #64668 by mwm
Replied by mwm on topic Wishlist for a custom Transmitter board
Fernandez wrote: Are there no such small boards, with 256 or 512k which can run full featured U7E code directly ?
Not using the STM32F1 µcu. The ones in the 48-pin package used on those boards only go up to 128K. There are some STM32F3 CPUs that would work, but I don't see any boards in that size range. Next best bet from an µcu perspective is the STM32L4, which is the high end of the low power consumption STM32 µcus. Just checking the family diagram, it should have enough horsepower. There's exactly one board based on those: www.arrow.com/en/products/nucleo-l432kc/stmicroelectronics
That board is almost exactly the same size (15mm wide hole-center to hole center, 50mm long) as the pill boards. That board is not a Chinese clone, but from the original manufacturer, so it's a bit steep compared to the pill boards. Arrow has the best price I've found for the STM boards, as well as great shipping.
Edit: I'm already working on a deviaiton Tank.B)
Last edit: 25 Sep 2017 22:15 by mwm.
26 Sep 2017 20:00 #64678 by Wene001
Replied by Wene001 on topic Wishlist for a custom Transmitter board
Thiinking about building a deviated Car transmitter the last 2 years :-)
05 Dec 2017 15:44 #66349 by Fernandez
Any updates here on this O-led stuff?
I find this small board it uses the U7E CPU:
www.banggood.com/STM32F103RCT6-ARM-STM32...als&cur_warehouse=CN
05 Dec 2017 16:59 #66350 by victzh
Replied by victzh on topic Wishlist for a custom Transmitter board
What is your specific question? All these small OLEDs based on SH1106, SSD1306, SSD1309 - 0.96", 1.54", 2.42" 128x64 SPI - they work OK with modified initialization sequence. I have one which works for SSD1306 with charge pump and for SSD1309. SH1106 is quite similar, but I don't have one so can't promise.
It is because their memory layout and addressing mode are the same with LCD used in Devo 7. After you initialized them they just work as if they're this LCD. The only difference is contrast/brightness control - they also use commands specific to OLED controller.
19 Jan 2018 17:28 #67000 by NealXu
Replied by NealXu on topic Wishlist for a custom Transmitter board
Hi...i have a Sky9x board in a 9x and was happy with it until Deviation. If Deviation had a board I wouldn't hesitate to get one. If it would help I would ship the tx anywhere for someone to poke around at.
19 Jan 2018 23:08 #67002 by fenist
Replied by fenist on topic Wishlist for a custom Transmitter board
Customised bootloader
Customised devo 7e (128k) Deviationtx
Hello! Can You share your code? I want to run deviation on maple mini and use hp4067 (16 ch multiplextor) for extra pins.
But now i have problems with bootloader - standart bootloader from devo7e seems to be not working on maple mini. And I can't find sources of bootloader.
13 Mar 2018 15:20 #68043 by wind10071
Replied by wind10071 on topic Wishlist for a custom Transmitter board
Moeder wrote: Normal devo7e-256 DFUs are built for SST25VFxxxB flash chips. Winbond W25Q-series is supported in the code lately, but you will need to compile a build with different target defs (one line of code change only). If you are unable to do so by yourself I could help out.
edit: build for W25Q16 attached. No way for me to test this though...
How can I change this code, can get me a screenshot of the, help me, I'm a novice?
21 Mar 2018 12:52 #68242 by wind10071
CLK -> A.5
MOSI -> A.7
RESET -> B.1
D/C -> C.5
CS -> B.0
How to change the code, cancel the greeting of no 6936 module "Missing Modules" “OK” ? Can you explain, thank you.
The modified code file can be sent to my gmail? This email address is being protected from spambots. You need JavaScript enabled to view it.
24 Mar 2018 12:38 #68325 by Bisky
Replied by Bisky on topic Wishlist for a custom Transmitter board
Is there a schematic how to hook up to make it work?
I heave a maple mini and w25q32 1.3 inch oled, loaded devo 7e 256 boot loader.
Tx, Bojan
Devo F7 XMS + 4in1 module
04 Apr 2018 19:00 #68507 by Bisky
Bisky wrote: Is there a schematic how to hook up to make it work?
Tx, Bojan
Would somebody be so kind to compile this for me, please.
I can't do it. :dry:
20 Sep 2018 14:56 #70994 by phamminh
Replied by phamminh on topic Wishlist for a custom Transmitter board
can you help me
27 Sep 2018 10:25 #71059 by phamminh
i upload firmware ok,coppy system ok, but lcd not working,please help me
27 Sep 2018 10:26 #71060 by phamminh
i try buy new lcd but it is still
27 Sep 2018 10:32 #71061 by fenist
Phamminh, do You really think that your post contains all required information?
What board do You use?
What LCD do You use?
How they are connected?
What bootloader and firmware do You use?
27 Sep 2018 10:36 - 27 Sep 2018 14:09 #71062 by phamminh
i use board stm32f103 rct6 ,lcd ssd1306 0,96 inch spi (scl-sda-rst-d/c)
i connect scl-pa5,sda-pa7,rst-b1,d/c-pc5
bootloader devo7e-256.bin
firmware deviation-devo7c-v5.0.0-89af59c.dfu
i try buy a new lcd ,but it not work,
i upload frimware ok,coppy system ok,but lcd not wwork
Last edit: 27 Sep 2018 14:09 by phamminh.
Time to create page: 0.424 seconds
