General development guidelines
25 Apr 2012 21:16 #49
Replied by PhracturedBlue on topic Re: General development guidelines
I'll check it out once I get home, but I don't see an issue in the code. The memcpy is being compiled as:which should work fine
Did you try running in the debugger? I found that using gdb with the STLink and loading my elf file works reasonably well, even if it is a little fragile.
8009918: e1a0c001 mov ip, r1
80099c8: e1a0100c mov r1, ip
80099cc: e4d1c001 ldrb ip, [r1], #1
80099d0: e2522001 subs r2, r2, #1
80099d4: e4c3c001 strb ip, [r3], #1
80099d8: 1afffffb bne 80099cc <memcpy+0xc0>Did you try running in the debugger? I found that using gdb with the STLink and loading my elf file works reasonably well, even if it is a little fragile.
26 Apr 2012 15:30 #61
I indeed see that the memcpy hangs the MCU (and that it is the memcpy and not something about printf). Sorry, I ran out of time before I could load it into the debugger and step through it. Maybe something about reading directly from ROM? It doesn't make much sense to me.
- rcH4x0r
26 Apr 2012 16:09 #62
by rcH4x0r
Replied by rcH4x0r on topic Re: General development guidelines
-Moving the tmp array off the stack doesn't help.
-A memset to fill the buffer with 'A' hangs too.
-A simple for loop to copy the 7 bytes from flash to the buffer works (as does printf).
Looks like there is an issue with the libs/toolchain
26 Apr 2012 16:46 #63
I think there s something wrong with the branch:
(That isn't actually a blx, as the first nibble is 'f' which marks it as a 'BL' instruction (which makes more sense, so I guess objdump is confused see below)
However, the 1st nibble in the second byte is 'e' which is not valid for 'BL' in thumb or thumb2 as far as I can tell (it should be 11x1)
So the compiler seems to be generating bad code which is probably what confused objdump. This is the only occurrence of this I see in the firmware, so maybe something about newlib?
8006a78: f002 ef48 blx 800990c <memcpy>(That isn't actually a blx, as the first nibble is 'f' which marks it as a 'BL' instruction (which makes more sense, so I guess objdump is confused see below)
26 Apr 2012 19:04 #66
I'm not at home at the moment to test it, but try the following:
in Makefile change:to
I did this, and the compiled code now looks like this:which looks a lot better
in Makefile change:
$(TARGET).elf: $(LINKFILE) $(OBJS)
$(CC) -o $@ $(OBJS) $(LFLAGS)$(TARGET).elf: $(LINKFILE) $(OBJS)
$(CC) -o $@ $(OBJS) $(LFLAGS) $(CFLAGS)I did this, and the compiled code now looks like this:
8006a78: f002 ff48 bl 800990c <memcpy>- rcH4x0r
26 Apr 2012 20:25 #70
by rcH4x0r
Didn't work for me. I am busy this weekend, unfortunately, so I cannot help much more
27 Apr 2012 02:27 #71
Well, the changes I made to the Makefile and just committed (the above plus one other addition) do seem to have solved the issue for me. I no longer get hangs with the memcpy with trunk. If it doesn't work for you, send me you .list file and I'll take a look.
- rcH4x0r
27 Apr 2012 04:49 - 27 Apr 2012 20:14 #72
by rcH4x0r
Hopefully the "one other" will fix it for me too. When I get time I will test again
Edit: Yes, that fixed it, onwards!
Last edit: 27 Apr 2012 20:14 by rcH4x0r.
- wuselfuzz
01 Aug 2012 15:25 - 01 Aug 2012 15:26 #805
by wuselfuzz
Replied by wuselfuzz on topic Re: General development guidelines
My two cents:
About using C++:
I tried an object oriented C++ approach for my quadcopter stuff once which resulted in a PWM interface with a Sam7xPWM implementation accessible as a singleton.
The resulting user code was about this simple:
All the neccessary hardware setup (configuring GPIOs, creating a microsecond timer, setting up all four sam7x hardware pwm channels) worked automagically in the singleton's static constructor.
Even cout worked through the USART.
However, the drawbacks were:
- IMO, it's nicer to have a hardware_init()-function called at the start of main() that sets everything up in a specific order. Instead of read-modify-write operations for e.g. the data direction registers of a port belonging to a peripheral, this allows you to set up the registers once and be done with that.
- Using cout just once added many kilobytes of additional code. Much more bloat than just using printf.
- You need a more complex linker script and startup code to properly call static constructors.
About global (or rather file scope) variable use:
I'd rather use an object-oriented C (NOT C++) approach at many places and avoid global variables. As an example, there's the global struct Model Model and there's the function
u8 MIXER_MapChannel(u8 channel).
In an OO approach, Model would be the object, mode would be a property and MapChannel would be a method. "object oriented C" would then be like
Why all the hassle? Think about flight mode switches, dual rates, and the likes.
About using C++:
int main() {
PWM& pwm=Sam7xPWM::getInstance();
pwm[0]=1000;
pwm[1]=500;
}All the neccessary hardware setup (configuring GPIOs, creating a microsecond timer, setting up all four sam7x hardware pwm channels) worked automagically in the singleton's static constructor.
u8 MODEL_MapChannel(struct Model *m, u8 channel) {
switch(m->mode) {
}Why all the hassle? Think about flight mode switches, dual rates, and the likes.
Last edit: 01 Aug 2012 15:26 by wuselfuzz.
01 Aug 2012 16:14 #806
I'm not sure exactly what you are referring to here though:
It may make more sense for Model to be private to mixer.c and to use accessors to get at it (you'll see some of that in the code as well), but I don't think doing so will have a significant impact on the MapChannels function.
If you notice, I am not very consistent about this. In some cases I pass the object, and in others I directly access global variables. From a uC perspective I am used to programming on more limited platforms than the STM32, and there can be significant overhead to passing more than a couple parameters in a function call. That probably isn't particularly relevant to the stm32 though. In any case, I'm open to any improvements to cleaning up the code.wuselfuzz wrote:
u8 MODEL_MapChannel(struct Model *m, u8 channel) { switch(m->mode) { ... } ... }
The mapping is only relevant for the 4 sticks (as all other input are labeled, there is no confusion about what they do). I'm not sure this is the best example to show your point.Why all the hassle? Think about flight mode switches, dual rates, and the likes.
01 Aug 2012 16:15 #807
Also, if you do want to make changes like this (which is fine) I'd like to see the checkins done incrementally rather than wholesale so we don't disrupt the code base too significnatly.
01 Aug 2012 16:40 #808
Replied by FDR on topic Re: General development guidelines
I guess a better example would be the control structure and it's event handling...
That could benefit from inheritance too...
Time to create page: 0.370 seconds
- General development guidelines
