Protocol Stacks
06 Aug 2012 14:18 #903 by FDR
Replied by FDR on topic Protocol Stacks
PhracturedBlue wrote: I spent some time double checking my code against the sample logs I got from renatopub. I don't see anything else wrong, so if it still doesn't work with the last build and fixed-id, I'm stumped. In that case, I guess I'll dump my logs and make sure what I see on the emulator is what I see from the Tx.
Sorry, I couldn't check the latest build yet, because I'm at work now!
I will check it later, when I get home...
06 Aug 2012 14:28 #904 by wuselfuzz
Replied by wuselfuzz on topic Protocol Stacks
PhracturedBlue wrote: That looks like a nice bit of kit. I'll be interested in how far 16kB goes as far as number of samples (you need to sample the SPI bus at 8MHZ to get reliable data).
The sampling core supports RLE compression, which should work pretty nice on the data to be captured.
I like that thingy, because it's completely documented and I have quite a bit of background with FPGA design.
06 Aug 2012 15:30 #905 by PhracturedBlue
Replied by PhracturedBlue on topic Protocol Stacks
That is fine. I checked the tx spi logs and they match what renatopub sent, so if it still doesn't work, I am at a loss.
Note that to change the fixed_id, you need to edit the ini file on the tx through your PC. Because the max-value is limited to 99999, you can't enter the id I listed above. But it works ok if you enter it through the ini file.
06 Aug 2012 16:43 #906 by wuselfuzz
With
fixed_id=487193
and the latest code, the rx2435 went from fast blinking (bind phase) to bound (steady light) to blinking in second intervals.
No reaction from the elevator servo.
06 Aug 2012 16:43 - 06 Aug 2012 16:44 #907 by FDR
Yep, it binds now with the new build and fixed id!
Without the fixed id it didn't bind...
However, the servo extends and the throttle value is too low!
It might use different output range, I guess...
EDIT: I've used: fixed_id=487193
Last edit: 06 Aug 2012 16:44 by FDR.
06 Aug 2012 16:49 #908 by PhracturedBlue
FDR wrote: Yep, it binds now with the new build and fixed id!
Glad to hear it.
Can you try different values? 487192, 487194, 487182, ...
I'm not surprised about the servo throw. I see the same thing for all other protocols. I need to measure the throw with the real tx to try to figure out why the range is wrong.
06 Aug 2012 16:50 #909 by FDR
...and looks like aileron is reversed, but I have to double check that...
06 Aug 2012 16:51 #910 by PhracturedBlue
We need to figure out how you can compile the code yourself.
Since there are things you could do (like playing with the range) which would be easier to do if you could compile the code.
06 Aug 2012 16:55 #911 by FDR
It has bound with 680913, so I guess any value will do...
I don't remember that I could set fixed id with the 2401 protocoll in my WK2801Pro thow...
Probably it is just the fw has to have a value, even a random one...
06 Aug 2012 16:56 #912 by FDR
PhracturedBlue wrote: We need to figure out how you can compile the code yourself.
Yep! ;)
06 Aug 2012 17:00 #913 by FDR
Or we should ask renatopub to dump some more spi with the maximum channel throws (with and without maxed servo extends)...
06 Aug 2012 17:02 #914 by PhracturedBlue
yes, WK2401 and WK2601 do not have 'fixed' id. They just internally generate one.
Since I already have an interface for fixed_id, I see no reason not to allow the user to use it (It won't reduce bind time though). I am somewhat surprised though, since the previous build had a hard-coded id (non zero) and it still didn't work.
As for building, I'm currently trying this:
www.microbuilder.eu/Tutorials/SoftwareDe...ingGCCToolchain.aspx
That should provide the same toolchain that we use on linux/mac
06 Aug 2012 17:06 #915 by FDR
FDR wrote: ...and looks like aileron is reversed, but I have to double check that...
I can confirm, that the aileron channel is reversed!
Is it correct for the other protocols?
Is the right horizontal stick input is corrected? Because while my rudder (left horizontal stick in mode 2) goes negative in the left, the aileron goes positive in that direction!
06 Aug 2012 17:08 #916 by FDR
PhracturedBlue wrote: Since I already have an interface for fixed_id, I see no reason not to allow the user to use it (It won't reduce bind time though).
Agree, but if there is no fixed id defined, then we should generate a random one!
06 Aug 2012 17:11 #917 by wuselfuzz
I tried the same with the original tx2402.
The rx also goes to "blink in 1 sec intervals" mode, this might be related to the low voltage detection of the rx2435.
However, elevator works with the original tx. Checking my deviation config now.
06 Aug 2012 17:12 #918 by PhracturedBlue
That is what I'm saying. I did that and it didn't work for you.
06 Aug 2012 17:13 #919 by wuselfuzz
I got the rx binding without the fixed_id string.
06 Aug 2012 17:15 #920 by PhracturedBlue
I think they use the same gimbal setup in both left and right sticks, just rotated 180-degrees. this would explain why the throttle was reversed (I have code that fixes that). Probably need the same thing for the rudder. (or maybe it is the right-stick that is reverse). In either case, fixing it is easy.
Since I' haven't used the deviation firmware on an actual model, I haven't noticed whether the channels all move in the right direction or not
06 Aug 2012 17:18 #921 by PhracturedBlue
wuselfuzz wrote: I got the rx binding without the fixed_id string.
I know the wk2801 has a special case for when the id is '0' (which is not allowed). I expected that any value other than 0 would work.
I'm not sure about an RNG (seems wasteful to include a prng just for this one function), but I thought the crc of the model file would make a good id when none is specified.
06 Aug 2012 17:20 #922 by wuselfuzz
PhracturedBlue wrote: I'm not sure about an RNG (seems wasteful to include a prng just for this one function), but I thought the crc of the model file would make a good id when none is specified.
newlib should supply rand(). Needs a seed, though, or it's not random at all (see xkcd).
A good seed would be RSSI values from the CYRF. B)
Time to create page: 0.686 seconds
