Main page config hangs/reboots
19 Jan 2017 19:23 - 19 Jan 2017 19:24 #58204 by FDR
Main page config hangs/reboots was created by FDR
Since I have my new 12E, I found a bug in the main page config, which seems to effect both the DEVO 10 and 12E, and probably any other BW transmitters that have a configurable main page, like the U7E, and all of those emulators too.
If you are on the main page config's list of fields, a long ENT takes you to the positioning window, where you can select a field, and with a short ENT you can change to move mode.
However if you press a long ENT there, the TX hangs and reboots, showing the USB screen after that.
The emulators crash too...
This is on a fresh build, the official 5.0 is not effected, it seems...
Last edit: 19 Jan 2017 19:24 by FDR.
06 Mar 2017 08:34 #59891 by vlad_vy
Replied by vlad_vy on topic Main page config hangs/reboots
What has to be happened with ENT long press? Nothing or ???
06 Mar 2017 09:01 #59892 by FDR
Replied by FDR on topic Main page config hangs/reboots
Nothing special, but it can happen accidentally...
06 Mar 2017 09:32 #59893 by vlad_vy
Fixed, I will place pull request.
06 Mar 2017 15:44 #59902 by Moeder
Replied by Moeder on topic Main page config hangs/reboots
Another bug in current nightlies for main page configuration is, that on color touch screens (and emulators) nothing happens when pressing the load template button. Couldn't make out the reason yet unfortunately, but I have to admit I'm not that firm in the color GUI code...
07 Mar 2017 12:46 - 07 Mar 2017 12:47 #59948 by vlad_vy
Load/Save layout page work normally, I tested it by changing call at other page. So, button call at layout config dialog do nothing.
Last edit: 07 Mar 2017 12:47 by vlad_vy.
07 Mar 2017 14:55 - 07 Mar 2017 16:53 #59957 by vlad_vy
Interestingly, dialog page from which we try to call Load\Save layout page isn't Modal window? In that case button work normally, but PAGE_PushByID() do nothing.
I don't know how do it, but we need to close dialog before PAGE_PushByID().
pages\common\_main_config.c
static void add_dlgbut_cb(struct guiObject *obj, const void *data)
    (void)obj;
    if(!data) {
        if ((guiObject_t *)&gui->dialog) {
            DialogClose((guiObject_t *)&gui->dialog, 0);
        PAGE_PushByID(PAGEID_LOADSAVE, LOAD_LAYOUT);
It work, I can open "Load Layout" and load any layout. But, it can't compile for transmitters that have not dialog window.
Last edit: 07 Mar 2017 16:53 by vlad_vy.
07 Mar 2017 19:51 #59978 by vlad_vy
    (void)obj;
    if(!data) {
        if (OBJ_IS_USED(&gui->dialog))
            GUI_RemoveHierObjects((guiObject_t *)&gui->dialog);
07 Mar 2017 19:59 #59979 by FDR
Indeed, I tried the DEVO 8 emulator, and the template load doesn't work, but writes this onto the output:
ERROR: Page stack limit(6) exceeded
07 Mar 2017 20:08 #59980 by FDR
    (void)obj;
    if(!data) {
This works for the DEVO 8.
What more do we need to check?
08 Mar 2017 05:39 #59991 by vlad_vy
We need to move both version (modified and unmodified) "add_dlgbut_cb()" to 320x240x16 main_layout.c and 128x64x1 main_config.c, and remove from common\_main_config.c
08 Mar 2017 06:14 - 08 Mar 2017 06:16 #59993 by vlad_vy
It looks like we need temporarily open "Reporting bugs" topic or category, since "Bug tracker" is inaccessible.
Last edit: 08 Mar 2017 06:16 by vlad_vy.
08 Mar 2017 06:54 #59994 by Moeder
Since the project has moved to GitHub, why not use their Issues system as well? This one should be answered bei PB/ FDR I suppose...
08 Mar 2017 07:48 #59995 by FDR
PB didn't like the built-in bug tracker of neither the BitBucket, nor GitHub.
Our own had the advantage, that the users could report bugs without the need of a new registration and login, and they were still named users not just guests...
However since the Mantis integration is broken (since a Joomla upgrade there are a lot of naming conflicts), I have rather enabled the GitHub issue tracker in GitHub. It was enabled for the other two repositories anyway...
Time to create page: 0.073 seconds
