GUI
20 Jul 2012 18:35 #613 by FDR
Replied by FDR on topic Re: GUI
Help!
I can't do the image button, because the ImageMap struct member of the guiButton defined const, so I cannot assign a value for it runtime. :(
What do you suggest?
20 Jul 2012 19:16 #614 by PhracturedBlue
Replied by PhracturedBlue on topic Re: GUI
FDR wrote: Help!
What are you trying to do?
you want an image to change when you press it, or to only do an action when an image is pressed?
I was planning to support the latter case by defining a screen-region that when clicked executes a callback. If you want to be able to dynamically change an image, that is somewhat more challenging. I currently do it by deletingthe old object and replacing it with a new one.
20 Jul 2012 19:39 - 20 Jul 2012 19:46 #615 by FDR
I want to make an image button, like an icon.
Based on the button struct, which has everything for it, but would make a different create function, which instead of the button type gets file name and size parameters, like an image control does.
But I can't fill the buttons ImageMap part with this data, because it is defined const...
EDIT: Sorry, I've misunderstood you question! So I want the latter case only...
Last edit: 20 Jul 2012 19:46 by FDR.
20 Jul 2012 20:30 #616 by FDR
So, we are running again...
I have checked in a complete rearrangement of the mixer pages!
Now it is much more logical for me.
(Especially after you have enlighten me about the min/max values.)
All the controls are in the order they shoul be set, or at least in which they effect the output.
20 Jul 2012 20:52 #617 by FDR
FDR wrote: I want to make an image button, like an icon.
...or should we add every icon as a new button type?
20 Jul 2012 21:12 #618 by PhracturedBlue
No the ImageMaps are only for standard GUI primitives. I will checkin code that provides the capabilities you want shortly.
20 Jul 2012 22:25 - 20 Jul 2012 22:28 #619 by PhracturedBlue
I've committed pressable labels and pressable images now.
Edit:
On the main page the icon and the model name will both go to the load/save page. this is just an example, we probably don't want them both to gothere, but it shows how it works.
Last edit: 20 Jul 2012 22:28 by PhracturedBlue.
20 Jul 2012 22:32 #620 by PhracturedBlue
And I've merged your changes. Very Nice!
20 Jul 2012 22:37 #621 by MatCat
Replied by MatCat on topic Re: GUI
I need to get back to helping on this! Been so busy with work lately...
21 Jul 2012 06:18 #634 by PhracturedBlue
I had to completely rewrite the keyboard widget so it could support buttons. It should be basically working now (both with buttons and the mouse) with mostly the same features it had. the caps button behaves more like you'd expect now.
Let me know if you see any regressions. The new code should make it possible to support a pure-numeric keyboard. I'll work on that next.
21 Jul 2012 14:12 #637 by PhracturedBlue
Ok, the fixed-id now uses a number-only keypad.
The listbox has button support, but it isn't very good (I used left/right for the scrolling)
I also fixed it so you can change mixer-type without resetting the selection.
21 Jul 2012 14:34 - 21 Jul 2012 14:37 #639 by FDR
PhracturedBlue wrote: Ok, the fixed-id now uses a number-only keypad.
About the numeric keypad's navigation:
- from 8 the up goes to 4;
- from 0 the up goes to 7;
- from 9 the up goes to 5;
- from 9 the down is not clear, where it goues to;
- can't select done.
EDIT:
Can the list box selection include the scrollbar too? They form one control together.
Last edit: 21 Jul 2012 14:37 by FDR.
21 Jul 2012 15:22 #641 by FDR
I saw you failsafe control. :unsure:
It took me a while to turn it on! ;)
21 Jul 2012 15:30 #642 by PhracturedBlue
FDR wrote: About the numeric keypad's navigation:
- from 9 the down is not clear, where it goes to;
It should be much more intuitive now.
EDIT:
No, that will be somewhat difficult as they are separate gui objects.
21 Jul 2012 15:30 #643 by PhracturedBlue
I think we do need different icons for these toggle-able spinbuttons. That would make it clear when they can be pressed or not.
21 Jul 2012 15:34 #644 by FDR
PhracturedBlue wrote: I think we do need different icons for these toggle-able spinbuttons. That would make it clear when they can be pressed or not.
Yes indeed.
I've just made the reverse clickable too...
Ckecked in.
21 Jul 2012 15:40 #646 by FDR
Better, but still hard to select done:
- from del the down goes to 0;
- from done the up goes to 9...
EDIT:
OK, not a big deal...
21 Jul 2012 15:43 #647 by PhracturedBlue
Yes indeed.
Ckecked in.
Ok, i merged it. i also just added support for SPINPRESS buttons. They aren't used yet though.
we can then switch the controls over to use FILE_SPINPRESS64 etc where necessary to use them.
21 Jul 2012 15:45 #648 by PhracturedBlue
yes, that is known. I'm not sure yet how to fix it without coding every transition though.
For now the rule is that when switching rows, it will always select the closest numeric/alpha button, and will never select the 'special' del,done, caps, ... buttons.
21 Jul 2012 16:04 #649 by FDR
PhracturedBlue wrote: Ok, i merged it. i also just added support for SPINPRESS buttons. They aren't used yet though.
Checked in spinpress bitmaps.
Time to create page: 0.879 seconds
