GUI
- MatCat
28 Apr 2012 15:30 #76
Replied by PhracturedBlue on topic Re: GUI
We need to figure out how the GUI should be designed. My expectation is to build it in the emulator, and then port it back to the actual Tx once we have everything worked out. I am not yet sure how to deal with the filesystem. the 4kB sector-size may be an issue for us. So my thought is to just design the GUI on the PC where we can just use the native filesystem to get everything working, and then figure out how to implement it on the actual hardware.
I just committed some fixes to get the emulator to accept the mouse as a touch sensor, so we should have access to enough hardware in the emulator to get started.
The emulator supports:
* The same screen API and size as the Devo8
* 10 buttons (we can easily add more)
* virtual sticks
* Using the Mouse as a touch pointer
I was thinking of using either 16bit BMP as the file format. It has a pretty big header that we don't need, but is universally supported. We'll need to fill in the LCD_DrawImage().
* virtual sticks
- MatCat
28 Apr 2012 19:00 - 28 Apr 2012 19:04 #78
You don't need any of that for the emulator.
Just checkout the source and do:
make TARGET=emu_devo8
You will need libfltk-dev (I used 1.1 but 1.xx should work)
To build for ARM, you should just get this:
github.com/esden/summon-arm-toolchain
and build everything you need from there, but that isn't needed for the emulator
Last edit: 28 Apr 2012 19:04 by PhracturedBlue.
- MatCat
28 Apr 2012 21:57 #79
by MatCat
Replied by MatCat on topic Re: GUI
Yeah I am trying to get the arm toolchain itself working too, I got all prerequisites going but it doesn't seem to see the gmp/mpfr/mpc libraries for some reason... I hate CentOS for development, maybe I will install a copy of debian tonight on my laptop ontop of Windows 8 developer preview
- MatCat
28 Apr 2012 22:03 #80
by MatCat
Appears some files are missing:
target/emu_devo8/fltk.cpp:19:19: error: FL/Fl.H: No such file or directory
target/emu_devo8/fltk.cpp:20:26: error: FL/Fl_Window.H: No such file or directory
target/emu_devo8/fltk.cpp:21:23: error: FL/Fl_Box.H: No such file or directory
target/emu_devo8/fltk.cpp:22:24: error: FL/fl_draw.H: No such file or directory
target/emu_devo8/fltk.cpp:41: error: expected initializer before â*â token
target/emu_devo8/fltk.cpp:44: error: expected class-name before â{â token
target/emu_devo8/fltk.cpp: In constructor âmywin::mywin(int, int)â:
target/emu_devo8/fltk.cpp:46: error: class âmywinâ does not have any field named âFl_Windowâ
target/emu_devo8/fltk.cpp: In member function âint mywin::handle(int)â:
target/emu_devo8/fltk.cpp:62: error: âFL_FOCUSâ was not declared in this scope
target/emu_devo8/fltk.cpp:63: error: âFL_UNFOCUSâ was not declared in this scope
target/emu_devo8/fltk.cpp:65: error: âFL_KEYDOWNâ was not declared in this scope
target/emu_devo8/fltk.cpp:67: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp:72: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp:109: error: âFL_KEYUPâ was not declared in this scope
target/emu_devo8/fltk.cpp:110: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp:116: error: âFl_Windowâ has not been declared
target/emu_devo8/fltk.cpp: In function âvoid LCD_DrawStart()â:
target/emu_devo8/fltk.cpp:130: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp:131: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp: In function âvoid LCD_DrawStop()â:
target/emu_devo8/fltk.cpp:134: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp: In function âvoid LCD_Init()â:
target/emu_devo8/fltk.cpp:139: error: âwindowâ was not declared in this scope
target/emu_devo8/fltk.cpp:144: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp: In function âvoid LCD_DrawPixel(unsigned int)â:
target/emu_devo8/fltk.cpp:163: error: âFl_Colorâ was not declared in this scope
target/emu_devo8/fltk.cpp:163: error: expected `;' before âcâ
target/emu_devo8/fltk.cpp:164: error: âcâ was not declared in this scope
target/emu_devo8/fltk.cpp:164: error: âfl_colorâ was not declared in this scope
target/emu_devo8/fltk.cpp:165: error: âfl_pointâ was not declared in this scope
target/emu_devo8/fltk.cpp: In function âvoid LCD_DrawPixelXY(unsigned int, unsigned int, unsigned int)â:
target/emu_devo8/fltk.cpp:177: error: âFl_Colorâ was not declared in this scope
target/emu_devo8/fltk.cpp:177: error: expected `;' before âcâ
target/emu_devo8/fltk.cpp:178: error: âcâ was not declared in this scope
target/emu_devo8/fltk.cpp:178: error: âfl_colorâ was not declared in this scope
target/emu_devo8/fltk.cpp:179: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp:180: error: âFlâ has not been declared
target/emu_devo8/fltk.cpp:181: error: âfl_pointâ was not declared in this scope
make: *** [objs/emu_devo8/fltk.o] Error 1
- MatCat
28 Apr 2012 22:43 #83
You shouldn't really need to. fltk with cygwin/mingw should work fine in Windows. The code is simple enough, it would probably compile with MSVC even.
In any case, I'm currently running Lucid, and am in the process of moving to Precise. I came really close to going back to Debian this time around. Ubuntu just isn't well suited to my servers any longer, but I love the PPAs and didn't want to give them up.
- MatCat
28 Apr 2012 23:24 #84
by MatCat
The linux boxes I am running are all for web server use, so centos it is, however it's a crappy development distro. I have been wanting to setup a linux distro on my laptop anyway so it makes sense to me to do it. I used to run Backtrack, but it's not suited for my purposes now. So I am trying to consider what to run for a more desktop / development style. I am thinking Ubuntu but I am not sure.
- MatCat
29 Apr 2012 01:57 #86
by MatCat
Yeah I am running Ubuntu 12.04 now, I had my one monitor in portrait mode and for the life of me just couldn't get it to rotate right, so I put it back to landscape, and it doesn't see my samba network... other then that everything seems good sofar
- MatCat
29 Apr 2012 14:18 - 29 Apr 2012 19:33 #88
run:
gdb ./emu_devo8
r
(wait for it to crash)
bt
and send that to me
Edit: I think I read that wrong.; You said it actually crashes your Linux box? Are you running as root? No application should be able to do that. Still, these instructions are probably the best I've got as to how you can proceed.
gdb ./emu_devo8
r
bt
and send that to me
Last edit: 29 Apr 2012 19:33 by PhracturedBlue.
- MatCat
- MatCat
29 Apr 2012 20:05 #90
by MatCat
Starting program: /home/matcat/deviation/src/emu_devo8.elf
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff64512fa in XDrawPoint () from /usr/lib/x86_64-linux-gnu/libX11.so.6
(gdb) bt
#0 0x00007ffff64512fa in XDrawPoint ()
#1 0x0000000000402d19 in fl_point (x=0, y=0) at /usr/include/FL/fl_draw.H:156
#2 0x0000000000402af1 in LCD_DrawPixel (color=0)
at target/emu_devo8/fltk.cpp:201
#3 0x000000000040283b in LCD_Clear (color=0) at screen/qvga/lcd_string.c:118
#4 0x0000000000400ff8 in main () at main.c:33
(gdb) bt
29 Apr 2012 21:59 - 29 Apr 2012 22:01 #91
Well, that is odd and not helpful.
Please answer the following:
what distro/version?
what is the value of 'fltk-config --version'
what window manager?
does the screen display before it crashes (in gdb)?
what is the result of 'ldd emu_devo8.elf'
Can you send your binary to me?
If you want to, you can try the attached compiled version. It is for 64bit Ubuntu using fltk 1.3.0, but I've verified with 1.3.0 and 1.1.10, and both seem fine.
FYI, I have tested on 64bit Xubuntu Lucid, 32bit Xubuntu Lucid, and 64bit Xubuntu Precise without issue.
Now with attachment
Now with attachment
Last edit: 29 Apr 2012 22:01 by PhracturedBlue.
- MatCat
29 Apr 2012 22:10 - 29 Apr 2012 22:12 #92
by MatCat
Ubuntu 12.04LTE standard installed window manager 64 Bit
fltk is 1.3.0
Screen with GDB shows grey background window with no contents (contents do get drawn without GDB)
matcat@MatCatLi:~/deviation/src$ ldd emu_devo8.elf
linux-vdso.so.1 => (0x00007fff9e5ff000)
libfltk.so.1.3 => /usr/lib/x86_64-linux-gnu/libfltk.so.1.3 (0x00007f5cb03a2000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f5cb018c000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5cafdce000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f5caface000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f5caf8bd000)
libXft.so.2 => /usr/lib/x86_64-linux-gnu/libXft.so.2 (0x00007f5caf6a7000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f5caf471000)
libXinerama.so.1 => /usr/lib/x86_64-linux-gnu/libXinerama.so.1 (0x00007f5caf26e000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f5caf069000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f5caed35000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f5caeb18000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f5cae81d000)
/lib64/ld-linux-x86-64.so.2 (0x00007f5cb06f4000)
libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f5cae581000)
libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f5cae376000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f5cae14c000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f5cadf2e000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f5cadd16000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f5cadb13000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f5cad90d000)
fltk is 1.3.0
Last edit: 29 Apr 2012 22:12 by MatCat.
Time to create page: 1.917 seconds
