Tiny font alignment
09 Nov 2017 11:40 #65650
Replied by FDR on topic Tiny font alignment
Well, it looks much better, so I would say yes.
Once I made an all new narrow font too, but there was not much interest in that:
www.deviationtx.com/forum/custom-skins/6...-the-bw-transmitters
Probably it is too difficult to edit the config.ini...
09 Nov 2017 16:07 - 09 Nov 2017 16:10 #65665
Replied by vlad_vy on topic Tiny font alignment
Last edit: 09 Nov 2017 16:10 by vlad_vy.
09 Nov 2017 16:20 #65666
Changing the channel monitor is not a problem if we supply the new (corrected) font, but the horizontal move might not solve the issue, since in other languages the different letters might touch that bar anyway.
How did it look like with the original font?
09 Nov 2017 16:23 - 09 Nov 2017 16:25 #65667
Last edit: 09 Nov 2017 16:25 by vlad_vy.
- sbstnp
10 Nov 2017 02:22 - 10 Nov 2017 02:25 #65683
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Tiny font alignment
This may look weird with the small UI, I would keep both fonts with different names, just in case (I know hardly anyone uses the condensed display, I personally can't live without it - but then again, I run my own version with some customisations anyway).
Devo 10 + 4in1
Last edit: 10 Nov 2017 02:25 by sbstnp.
10 Nov 2017 05:00 #65688
Or is it with the original font?
That's not bad at all.sbstnp wrote: This may look weird with the small UI, I would keep both fonts with different names, just in case (I know hardly anyone uses the condensed display, I personally can't live without it - but then again, I run my own version with some customisations anyway).
- sbstnp
10 Nov 2017 05:20 #65689
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
It's with the original font, the top is aligned higher so characters like lower-case p and g can go one pixel lower.
Devo 10 + 4in1
10 Nov 2017 05:53 #65690
You need to test it. Vertical offset is used for TYNY_FONT, but not for BUTTON_FONT.
10 Nov 2017 11:17 - 10 Nov 2017 11:19 #65698
Tested, nothing changed, mixer page with tiny font looks the same.
Last edit: 10 Nov 2017 11:19 by vlad_vy.
- sbstnp
10 Nov 2017 20:44 #65715
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
But did you change line and header height to fit more lines on the screen? I can give you my settings if you want.
Devo 10 + 4in1
11 Nov 2017 06:20 #65733
I changed line height to 8. You can attach your settings for complete testing.
15 Dec 2017 10:42 - 15 Dec 2017 11:10 #66516
Now I can properly align any version of 04b03.bdf (tiny font). At the moment it changes old 04b03.fon only, other fonts are not affected and remains the same.
We need change "bdf_to_font.pl"
sub align_chars {
my($font) = @_;
my $max_zero = 0;
foreach my $c (sort {$a <=> $b} keys %$font) {
last if ($c > 2000);
$max_zero = $font->{$c}{zero} if($font->{$c}{zero} > $max_zero);
#Align to baseline
foreach my $c (keys %$font) {
if($font->{$c}{zero} < $max_zero) {
foreach my $col (@{ $font->{$c}{data} }) {
$col <<= $max_zero - $font->{$c}{zero};
$font->{$c}{zero} = $max_zero;
}sub align_chars {
my($font) = @_;
my $max_zero = $ascent;
#Align to baseline
Last edit: 15 Dec 2017 11:10 by vlad_vy.
Time to create page: 0.325 seconds
- Tiny font alignment
