Automated voice pack building
29 Aug 2018 08:57 #70518 by xalex75
Replied by xalex75 on topic Automated voice pack building
It's a great job, easy to use and effective.
I'll follow tour suggestion.
Thank you!
30 Aug 2018 08:47 #70551 by xalex75
Hi Moeder.
By following your suggestion in 5 minutes I merged the 2 folders and now everything is ok.
Thank you very much for your work, without it I think that I would never have custom voices on my tx. :-)
30 Aug 2018 10:38 #70553 by yets
Replied by yets on topic Automated voice pack building
Moeder wrote: It would be an easy change, but as voicepacker use has been rather low, I refrained from putting more work into it. You can just create a pack with English voice and then replace the global alert mp3 files in your Italian set with the English ones.
I hope that you haven't stopped working on the improvements that you were taking about a few months ago? I for one would like to see development continue
30 Aug 2018 17:13 #70557 by Moeder
Replied by Moeder on topic Automated voice pack building
xalex75 wrote: By following your suggestion in 5 minutes I merged the 2 folders and now everything is ok.
If you translate the global alerts to Italian via Github (or attach the file to this thread, I'd be happy to add Italian global alerts to the voicepackers, it should be just a matter of a couple of minutes and is probably useful for others as well ;)
31 Aug 2018 06:52 #70573 by xalex75
Ok, I will do it soon. :-)
01 Sep 2018 13:34 #70608 by xalex75
Hi.
I translated the common voices.
For those "international" words (english words taht must be read by italian voice) I tried to write them as they should sound in italian (not exact translation).
For example "timer" has a corresponding italian word (cronometro or contaminuti), but english word is common use and by using italian speech in order to have the correct sound I wrote "taimer".
Let's try! :-)
04 Sep 2018 20:58 #70647 by Moeder
I have added it to the voicepacker, please give it a try
05 Sep 2018 06:45 #70656 by xalex75
Thanks, I'll try it tonight.
08 Sep 2018 16:30 #70742 by xalex75
Sorry for late feedback.
Beautiful... I just made a syntax error and I forgot to write Deviation as it sounds in italian.
I also cut "Allarme taimer" into "Taimer", I think shorter is better (it speaks every minute) and it's obvious that it's an alarm.
I attached the corrected file.
When you have time, no hurry of course, and thank you again!
09 Sep 2018 17:42 #70761 by Moeder
voicepacker is now up to date with your latest submission
09 Sep 2018 20:09 #70765 by xalex75
great
18 Sep 2018 09:31 #70968 by yets
Hey Moeder, I'm trying to get the voice timer alerts to work and while it works fine for Countdown timer, it doesn't seem to work for Stopwatch. For example, instead of saying "Flight time, 1 min" or something along those lines, it says "timer 1, 1min." Is there a means to change this?
Also, how's progress with the new features and delay timings? Avidly waiting :)
03 Feb 2019 16:00 #72691 by Moeder
Sorry, didn't read your latest post here. Can you elaborate on the issue with your stopwatch timer? I seems to work for me, at least in the emulator.
04 Feb 2019 20:22 - 04 Feb 2019 20:23 #72713 by yets
Moeder wrote: Sorry, didn't read your latest post here. Can you elaborate on the issue with your stopwatch timer? I seems to work for me, at least in the emulator.
No worries. Yes, if adding a stopwatch timer, at minute intervals the voice alert would say "timer 1, 1 minute" "timer 1, 2 minutes" and so on and so on. This occurs if the voice.ini file is edited to include "timer1=voice file". As in, changing the stopwatch timer voice alert to a custom voice is not working.
The countdown timer works as intended, as in if voice.ini is edited to include a voice alert e.g. "flight time remaining, 30 seconds, flight time remaining 15 seconds...etc"
Will we be seeing a delay/interrupt to these alerts, eg. Cutting off the alert to start a new one when a new alert is triggered rather than playing the whole sound file
Last edit: 04 Feb 2019 20:23 by yets.
05 Feb 2019 01:26 #72718 by yets
@Moeder, I am still running the voice alerts build for Devo 7E from early 2017. Can I please request a more recent version and also the source files/github? I would like to compile it myself and make a few changes to one of the protocols. Thanks
05 Feb 2019 22:30 #72723 by Moeder
I attached a build from my current work tree based on current nightly. I disabled standard GUI for this build and enabled voice, voice config menu (which fits after latest code changes) and also the layout editor (since we had r[o]om left anyways ;) )
06 Feb 2019 12:08 #72737 by yets
Moeder wrote: I attached a build from my current work tree based on current nightly. I disabled standard GUI for this build and enabled voice, voice config menu (which fits after latest code changes) and also the layout editor (since we had r[o]om left anyways ;) )
Thank you Moeder (and the rest of the Deviation team). Thanks for your hard work
06 Feb 2019 12:25 #72738 by Moeder
You're welcome. Please give me some feedback, there might still be some issues.
06 Feb 2019 19:45 #72743 by yets
Yes, I'll update Devo that this weekend an will pass back anything I find.
23 Feb 2019 09:06 #72984 by Moeder
how's your experience with this build?
Time to create page: 0.503 seconds
