Automated voice pack building
24 Feb 2019 13:33 #72999 by yets
Replied by yets on topic Automated voice pack building
Hey moeder, I'm actually trying to update right as I type. I came back to search for installation tips as I've never compiled myself. I'll let you know how it goes. :)
01 Mar 2019 22:02 #73105 by yets
Hey moeder, I gave the file a try and it's great, it includes voice menu etc. However, I'm trying to build from your voicediet2 branch (cloned) after I edit one of the protocols but it's building without the changes found in your zip. Can you offer some help please?
03 Mar 2019 09:59 #73139 by Moeder
Replied by Moeder on topic Automated voice pack building
To enable voice (and voice menu) you have to modify src/target/tx/devo/devo7e/target_defs.h to:
HAS_EXTENDED_AUDIO 1
HAS_MUSIC_CONFIG 1
HAS_STANDARD_GUI 0
What protocol changes do you want to make?
03 Mar 2019 17:46 #73160 by yets
Thanks Moeder. I'll give it another go. I think I found these defines last night, compiled, flashed but the Devo would have a blank screen.
I have copied modified code for the Bayang_nrl2401 to include some aux channels for Silverware. It is currently under a pull request (as of yesterday) but I don't know how long it will take to get to the nightlies
05 Mar 2019 01:15 #73206 by yets
Still struggling trying to get a docker build that compiles with the target options. I've changed the target_defs but whatever I do, it just won't build with them. I've checkedout Git to a local branch on voice_diet2 but I'm not sure what the docker is doing. Any help please?
05 Mar 2019 14:35 #73219 by Moeder
Why doesn't it build? Do you have docker setup to use your local repo? Then
git checkout voice_diet2
git submodule update --init (in case you didn't already)
cd src
Edit target defs, after that
make - j2 devo7e (or other number than 2,depending on cpu cores)
If this does not work, post error messages.
05 Mar 2019 15:15 #73221 by yets
It builds but either doesn't incorporate the changes or didn't initiate correctly on the tx (blank lit LCD screen). I have been building just with Bash and also the GitHub desktop app all from source. I'll give it a go with your commands, building with git bash has been a bit of a learning curve. Thanks
05 Mar 2019 16:15 #73222 by yets
These are the errors attempting bash from src
$ make -j2 devo7e
env: perl: Invalid argument
+ Compiling 'target/tx/devo/devo7e/channels.c'
/usr/bin/sh: arm-none-eabi-gcc: command not found
make[1]: *** [objs/devo7e/channels.o] Error 127
make: *** [devo7e] Error 2
06 Mar 2019 05:34 #73228 by Moeder
That means you are not inside the container. Did you start it as described in the wiki?
Nevertheless, I will post a build for you tonight based on current master.
06 Mar 2019 08:50 #73231 by yets
To the best of my abilities I have followed your instructions, even deleting it all and starting the process over a few times. I navigate through to source in bash and I get all the errors. I even downloaded arm-none-rabi-gcc.
Last night I tried to download just the diet_branch2 through git as source but it would still build master and no target Def's changes. So I'm really not sure what I'm doing wrong
06 Mar 2019 17:57 - 06 Mar 2019 17:57 #73238 by Moeder
Somehow it seems you are not in the docker container. Start it with
docker start -i deviation_build
Then click on shell or use arrow keys and press enter. Go to directory /git (depending on how you set it up this should point to you git repo or some other local directory of yours).
Last edit: 06 Mar 2019 17:57 by Moeder.
06 Mar 2019 20:19 - 06 Mar 2019 20:35 #73240 by yets
yets wrote: To the best of my abilities I have followed your instructions, even deleting it all and starting the process over a few times. I navigate through to source in bash and I get all the errors. I even downloaded arm-none-rabi-gcc.
Looks like I was making a mistake with the folder directives when building container, I was typing /c/users/name/git rather than ~/git. Now changes are incorporated from local repo. However, now Docker will not build as I have a new error;
Updating build.py
Building zip_devo7e
Preparing for ARM build
: No such file or directory
make[1]: *** [include/libopencm3/stm32/f0/irq.json.cleanhdr] Error 127
make: *** [distclean] Error 2
GENHDR include/libopencm3/stm32/f1/irq.json
make[2]: *** [include/libopencm3/stm32/f1/irq.json.genhdr] Error 127
make[1]: *** [libopencm3/lib/libopencm3_stm32f1.a] Error 2
make: *** [zip_devo7e] Error 2
I will try your new suggestions Moeder. How do I navigate with the shell? cd doesn't work, I am not proficient with command
EDIT: Ok, I managed to navigate to SRC but and attempt to make make - j2 devo7e, however I have the same error as above.
+ Copying template files for devo7e
make[1]: *** Waiting for unfinished jobs....
+ Checking string list length for devo7e
filesystem/devo7e
../utils/extract_strings.pl -target devo7e -objdir objs/devo7e
Please install cpplint via 'pip install cpplint' or equivalent
Last edit: 06 Mar 2019 20:35 by yets. Reason: more information
06 Mar 2019 21:16 #73242 by Moeder
you didn't fetch git submodule for libopencm3, run this line once in the git directory:
after that, a make devo7e should work.
I had time to make a build for you based on current master without language support but with voice, voice menu, main config menu. Thanks to the recent changes a lot of things can fit in a devo7e build currently ;)
But please don't give up on getting the build environment to work!
File is to big to attach, please download here
06 Mar 2019 21:32 - 06 Mar 2019 22:52 #73243 by yets
Thanks for creating it Moeder. Sorry for being bothersome.
I'm still attempting get the environment to work,
I just tried
and it checked out. However, still getting the same error. Is it a docker problem? Have I corrupted files in it somehow?
Last edit: 06 Mar 2019 22:52 by yets.
07 Mar 2019 11:33 - 07 Mar 2019 11:35 #73250 by Moeder
That's odd. Did you try make distclean before make devo7e?
Edit: please post some screenshots or paste a terminal log of what you are doing, it is a little hard to guess what exactly you are doing.
Last edit: 07 Mar 2019 11:35 by Moeder.
07 Mar 2019 12:57 - 07 Mar 2019 13:54 #73252 by yets
I've tried reinstalling Docker Toolbox again, clean builds and yet still experiencing the same problem.
This trying make as suggested;
And results in;
When building a container using /c/users/name/git:/git it builds perfectly, but not when using ~/git
Last edit: 07 Mar 2019 13:54 by yets.
07 Mar 2019 13:55 #73254 by Moeder
Don't know if it really matters, but I believe you have to run git submodule from src directory
07 Mar 2019 14:00 #73255 by Moeder
I don't use win environment, maybe vlad_vy can help...
07 Mar 2019 14:25 #73256 by vlad_vy
Replied by vlad_vy on topic Automated voice pack building
No, I use completely local Windows environment, without git and Docker.
07 Mar 2019 16:27 #73261 by yets
vlad_vy wrote: No, I use completely local Windows environment, without git and Docker.
Do you have guide to build then?
Time to create page: 0.400 seconds
