Automated voice pack building
08 Mar 2019 06:42 #73266
Replied by vlad_vy on topic Automated voice pack building
Long time ago I use this page:
www.deviationtx.com/wiki/development/setting_up_build_env
- yets
08 Mar 2019 08:53 #73267
by yets
Replied by yets on topic Automated voice pack building
I'll give that a go. I tried Mingw64 environment and that failed to build also
I'll tried building from another computer and I encounter the same issues.
- Moeder
08 Mar 2019 15:34 #73270
by Moeder
Replied by Moeder on topic Automated voice pack building
encountered the same issue on osx...solution is simple: enter subdirectory libopencm3 and run
make
Seems we don't currently force this in Makefile....
make
- yets
08 Mar 2019 20:59 - 08 Mar 2019 22:34 #73272
by yets
I tried and it refuses to build, filled with errors
Cannot find the specified files
edit: Had to download gcc-arm-none-eabi and it makes. However, still has errors, at least it attempts to build
Moeder wrote: encountered the same issue on osx...solution is simple: enter subdirectory libopencm3 and run
make
Last edit: 08 Mar 2019 22:34 by yets.
- yets
09 Mar 2019 13:10 - 09 Mar 2019 14:16 #73278
by yets
After make in libopencm3 this issue when building
Building zip_devo7e
Preparing for ARM build
make[1]: *** No rule to make target `clean'. Stop.
make: *** [distclean] Error 2
Fetch libopencm3 via 'git submodule update --init'
make[1]: *** [libopencm3/lib/libopencm3_stm32f1.a] Error 1
make: *** [zip_devo7e] Error 2
I really don't understand why it's an impossible task to create from a local git
ok I finally have it working; not if it was this but using it helped to build;
git submodule foreach --recursive git submodule update --init
Thanks for your help and patience Moeder. I'm not sure if the build process guide may need updating to reflect the need for "make" command for libopencm3 for Windows 10 users or if I'm just a one off case
Building zip_devo7e
Last edit: 09 Mar 2019 14:16 by yets.
- Moeder
11 Mar 2019 08:55 #73301
by Moeder
The submodule has recently been introduced, the documention has not been updated. When using built in gut from docker the command runs automatically, but not on local git repository. We'll find a solution. Glad you showed patience and finally got it working.
- yets
11 Mar 2019 13:37 - 11 Mar 2019 16:04 #73302
by yets
Thanks for your explanation. One last question, I have two 3 way switches and I have enabled it in Hardware.ini but I only have SW A0/SW A1 B0/B1 but no A2 and B2. Assigning in the mixer SW A2/B2 do not work, or with A0/B0 working from mid point of switch. Is there another setting in target or capabilities that I need to enable to have 3x2 switches show up correctly?
Is this a bug? Reverted to earler build, switches work correctly
Moeder wrote: The submodule has recently been introduced, the documention has not been updated. When using built in gut from docker the command runs automatically, but not on local git repository. We'll find a solution. Glad you showed patience and finally got it working.
Last edit: 11 Mar 2019 16:04 by yets.
- yets
19 Mar 2019 17:22 #73439
by yets
Has the issue with the extra switches not working been rectified?
- Moeder
19 Mar 2019 18:28 #73440
by Moeder
Can you please share your hardware.ini here? Also, can you reproduce the behavior in the emulator?
- yets
19 Mar 2019 22:16 #73442
by yets
Hi Moeder, hardware.ini file is the same as previous Voice alert build before the voice_diet2
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
extra-switches=3x2
;extra-buttons=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
Works if I return to previous working build. EMU doesn't show the issue but the build you also made for me displays the same problem
;enable-haptic=1
extra-switches=3x2
;extra-buttons=
[modules]
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- Moeder
20 Mar 2019 15:29 #73450
by Moeder
Have you checked with current nightly? It should probably have the same issue. You are right, I cannot reproduce it in the emulator.
- yets
20 Mar 2019 23:12 #73456
by yets
I will check the current nightly tomorrow and update you
- yets
22 Mar 2019 01:14 #73504
by yets
Moeder, I tested Nightly build from 21st March and issue persists.
- Moeder
23 Mar 2019 16:52 #73519
by Moeder
PB committed a patch (well, actually a major rework of switch and channel code) to master branch which should hopefully fix the issue. Please try building from current DeviationTX/master or wait for the upcoming nightly build and check if the issue persists.
- yets
25 Mar 2019 21:26 #73556
by yets
I have tried the latest nightly build and the problem hasn't changed. No movement in channel monitor.
- yets
27 Mar 2019 21:23 #73574
by yets
Nightly build 26-3-19, problem hasn't changed
- Moeder
28 Mar 2019 10:25 #73582
by Moeder
That is really odd, as the devo7e 3*2 setup supposedly works for PB. Do you mind sharing pictures from your setup?
- yets
28 Mar 2019 22:11 #73588
by yets
I followed the same setup as the ones described and explained on these forums. I can switch back to an earlier fw and switches work but anything more recent and I get the problematic behaviour.
- yets
30 Mar 2019 01:18 - 30 Mar 2019 02:50 #73606
by yets
Here's wiring for my Devo7E,I can't see anything that could cause the issue
edit: Throttle trim isn't working correctly too. All this on fresh install of nightly and fresh model file. Is there a way to completely erase the installation on the Devo 7E or do I need to return to Devention? When upgrading the nightly etc, it flashes really quickly, maybe theres an issue with my MCU?
Last edit: 30 Mar 2019 02:50 by yets.
- daniel.snowsurf
30 Mar 2019 15:22 #73619
by daniel.snowsurf
Replied by daniel.snowsurf on topic Automated voice pack building
Same problems here with the switches and throttle trim too (used as a switch).
https://www.deviationtx.com/forum/6-general-discussions/8361-devo-7e-3x2-switches-not-working-anymore#73614
I think it's confirmed, so it's time to dig into the code.
Time to create page: 0.271 seconds
- Automated voice pack building
