Voice feature improvements
06 May 2018 09:40 - 06 May 2018 09:41 #69075 by Moeder
Voice feature improvements was created by Moeder
Hello voice fans,
I put a little work into improving the voice feature. I've split the voice config menu into sub menus as depicted below to allow for easier access to the desired settings especially on the monochrome screens. I also plan on adding a "global alert config" menu to allow choosing a model specific type of alert (buzzer, voice, voice + vibrate) for battery, binding, inactivity timer and telemetry alerts. I will also try to improve the output of AUX value output and suppress SW1 voice output when rapidly flipping from SW0 to SW2. What else is on your personal wishlist? Attached some pictures.
edit: why can't I add any pictures or files to my posts? now it does :blink:
Last edit: 06 May 2018 09:41 by Moeder.
06 May 2018 10:00 #69076 by Fernandez
Replied by Fernandez on topic Voice feature improvements
Do you mean from the Tx, we can select and browse/scroll true a list and select the designated mp3's to play?
that would be great.
06 May 2018 10:28 #69078 by Moeder
Replied by Moeder on topic Voice feature improvements
For telemetry and timers you already can, so global alert setup the way I thought of it is just for selecting whether you want voice, voice + vibration or buzzer on select alerts (it doesn't make sense for switches IMHO).
06 May 2018 18:45 - 06 May 2018 18:47 #69083 by yets
Replied by yets on topic Voice feature improvements
I'm happy with whatever but can I request what ever you do, can it be ported to Devo 7E? I don't mind having to use the emulator and files to change things
Last edit: 06 May 2018 18:47 by yets.
06 May 2018 19:16 #69084 by Moeder
As before, devo7e without standard GUI and without voice menu will be possible, with the voice menu made available through the emulator. Yets, what is your experience on delay between each sound file being played (like telemetry and timer alarms)?
06 May 2018 21:55 #69086 by yets
I'm perfectly happy with that Moeder :)
There is a slight delay but if I'm honest, from my experience it's not something I notice. Would it be helpful if I posted a video?
07 May 2018 04:34 #69088 by Moeder
That would be nice to see in a video. On my T8SG I noticed that that files are not finished playing before the next one gets triggered, so a little more delay is needed between files. I'm now wondering if this is a general problem or just in specific setups (different type of sdcards?).
08 May 2018 06:15 - 08 May 2018 06:18 #69108 by yets
I'll try to upload something over the next few days. If I remember correctly, the alarms would always play in its entirety before the next one would trigger. If you tell me exactly what you'd like I can video that
Last edit: 08 May 2018 06:18 by yets.
08 May 2018 12:18 #69114 by 52dgj
Replied by 52dgj on topic Voice feature improvements
Do you have this build in the nightly build?:) :) :)
08 May 2018 13:04 #69115 by Moeder
Not yet, I'm still working on it and have yet to do the touchscreen menus. I'll hopefully post a first test build for monochrome transmitters soon though.
08 May 2018 15:07 #69117 by 52dgj
Ok, thank you very much for your improvements,hhhhhh...:P :P :P
Time to create page: 0.793 seconds
