Remove STANDARD GUI from Devo 7e build ?
- goebish
- NRF Weirdo
06 Nov 2018 09:45 #71562
by goebish
Remove STANDARD GUI from Devo 7e build ? was created by goebish
We're encountering flash space issues again with the 7e build, eg:
github.com/DeviationTX/deviation/pull/455
github.com/DeviationTX/deviation/pull/443
vladislavy suggested we should disable STANDARD GUI in the modular build, everyone agrees with that ?
06 Nov 2018 11:29 #71566
Replied by vlad_vy on topic Remove STANDARD GUI from Devo 7e build ?
If we disable STANDARD GUI, we can enable for devo7e: 1) permanent timer, 2) datalog, 3) layout editor
- goebish
- NRF Weirdo
06 Nov 2018 11:51 #71567
by goebish
Replied by goebish on topic Remove STANDARD GUI from Devo 7e build ?
I don't think this is related but although "build passing" is showing there haven't been new nightly builds in the download section for a few days:
www.deviationtx.com/downloads-new/category/13-nightly-builds
- aMax
06 Nov 2018 14:58 #71579
by aMax
Replied by aMax on topic Remove STANDARD GUI from Devo 7e build ?
vlad_vy wrote: If we disable STANDARD GUI, we can enable for devo7e: 1) permanent timer, 2) datalog, 3) layout editor[/quote
Approved and well done in your recent 5.0 release. I am very happy with this.
- Gerry
- Bbrad
07 Nov 2018 01:04 #71591
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Remove STANDARD GUI from Devo 7e build ?
Myself and two friends have 7e all have 2x3 switch mods and extra rf modules. Mine has voice Fw so no Standard Gui already. My friends both run nightlies, but almost all their models are programmed by me and whenever I am teaching them mixers it is always done in advanced gui. I think I can speak for them and myself and say standard gui is obsolete.
I vote for remove standard gui.
- pulpfiction15
07 Nov 2018 07:56 #71599
by pulpfiction15
Replied by pulpfiction15 on topic Remove STANDARD GUI from Devo 7e build ?
I never used standard GUI, but is it not possible to create 2 builds ?
one 'Standard' and one 'Advanced' build.
- Gerry
- Bbrad
07 Nov 2018 08:34 #71600
by Gerry
As more and more protocols are added in the future will these proposed features disappear? If so, why put them in now to take them away later?
Can we have all this AND voice?vlad_vy wrote: If we disable STANDARD GUI, we can enable for devo7e: 1) permanent timer, 2) datalog, 3) layout editor
07 Nov 2018 11:05 #71606
The voice feature use much more memory than Standard GUI, so it's impossible. Except it we will have 3K spare memory, it can accept BUNCH of new protocols.
07 Nov 2018 14:09 - 07 Nov 2018 16:30 #71611
With last two nightly builds (Nightly Build 2018-11-06 and Nightly Build 2018-11-04):
Uploading Nightly - 2018-11-04
Unterminated <> operator at ../utils/upload_test_build.pl line 90.
I think the reason is github.com/DeviationTX/deviation/pull/445
it changed install_nightlies.tar.enc
goebish wrote: I don't think this is related but although "build passing" is showing there haven't been new nightly builds in the download section for a few days:
Last edit: 07 Nov 2018 16:30 by vlad_vy.
- goebish
- NRF Weirdo
07 Nov 2018 16:37 - 07 Nov 2018 16:42 #71616
by goebish
Yes that's probably the culprit, I didn't realize that this PR changed install_nightlies.tar.enc, I often have to fight with this file when doing local merge as well, I tend to manually delete it before I check out a new branch to avoid issues ...
Last edit: 07 Nov 2018 16:42 by goebish.
- goebish
- NRF Weirdo
07 Nov 2018 17:35 #71619
by goebish
PB has just fixed this issue, he had to update the yml script anyway.
- Moeder
07 Nov 2018 21:00 #71629
by Moeder
Replied by Moeder on topic Remove STANDARD GUI from Devo 7e build ?
What is this Standard GUI everbody‘s talking about?
- Gerry
- Bbrad
07 Nov 2018 22:31 #71631
by Gerry
The standard walkera style mixer gui vs advanced complex mixer gui.
- mog-joe
08 Nov 2018 01:54 #71637
by mog-joe
Replied by mog-joe on topic Remove STANDARD GUI from Devo 7e build ?
Who needs the standard Gui? I have never used them.
- daniel.snowsurf
14 Mar 2019 22:01 #73360
by daniel.snowsurf
Replied by daniel.snowsurf on topic Remove STANDARD GUI from Devo 7e build ?
I have never used Standard GUI. I always disable Standard GUI, and add extended telemetry for AFHDS 2A, and layout editor in my builds.
I don't know what's the permanent timer and datalog, I'll check it.
Another good idea would be to remap AFHDS 2A voltage telemetry to something on non extended telemetry.
- cmpang
26 Sep 2019 02:27 #75151
by cmpang
Replied by cmpang on topic Remove STANDARD GUI from Devo 7e build ?
so is the current nightly implemented the NO standard GUI yet?
Time to create page: 0.208 seconds
- Remove STANDARD GUI from Devo 7e build ?
