newlib (stdc) + uart + petit_fat integration
08 Aug 2012 09:58 #969 by FDR
PhracturedBlue wrote: I'm not sure how much spce we have, so if that 50MB file is too big, feel free to remove it.
Only MatCat could tell, but I think it should be fine...
08 Aug 2012 18:02 - 08 Aug 2012 18:06 #979 by FDR
My dfu builted on Windows doesn't work.
It flashing the screen and restarting over and over with a 1s cycle time...
EDIT: Nop, my bad, it is working! I forgot to copy the filesystem dir...
Last edit: 08 Aug 2012 18:06 by FDR.
08 Aug 2012 18:05 #980 by PhracturedBlue
Replied by PhracturedBlue on topic newlib (stdc) + uart + petit_fat integration
FDR wrote: My dfu builted on Windows doesn't work.
Then it didn't completely fail, since that is the watchdog kicking in
Did you try using the stm32.zip I supplied? If you get the same result with that then it is likely the code as opposed to the toolchain. By the way you can install it wherever you want as long as it is in your path, so you can have both toolchains installed simultaneously.
08 Aug 2012 18:07 #981 by FDR
Sorry! It works! :woohoo:
I forgot to copy the content of the filesystem dir... :oops:
09 Aug 2012 11:32 - 09 Aug 2012 11:42 #1000 by wuselfuzz
Replied by wuselfuzz on topic newlib (stdc) + uart + petit_fat integration
I'll test out other FAT implementations, soon. I don't really trust petit_fat for the write limitations, I'd rather see a full FAT implementation.
Compiled size of the complete FatFs Module and of this one ultra-embedded.com/?fat_filelib to be tested.
+1: www.larwe.com/zws/products/dosfs/index.html
Last edit: 09 Aug 2012 11:42 by wuselfuzz.
09 Aug 2012 12:52 #1002 by PhracturedBlue
wuselfuzz wrote: I'll test out other FAT implementations, soon. I don't really trust petit_fat for the write limitations, I'd rather see a full FAT implementation.
I'd also check out ELM. Make sure you can change the sector-size, since we require 4096k sectors.
Time to create page: 0.045 seconds
