Renaming custom builds
- joeclone
30 Oct 2019 14:33 #75347
by joeclone
Renaming custom builds was created by joeclone
Sorry if this been asked before, tried search but didn't get any results. How do I rename a custom build? All the builds I've tried come out as v5.0.0-9502535. Dunno if this is a random number but I'd like to rename it so I can know whats what in the devo screen after it's flashed.
31 Oct 2019 08:21 - 31 Oct 2019 08:28 #75351
Replied by vlad_vy on topic Renaming custom builds
Edit Makefile HGVERSION :=...
I use for my local builds:
HGVERSION := $(TARGET)"-v5.0.0-"$(shell date +%Y-%m-%d)
or
HGVERSION := $(TARGET)"-v5.x.x-"$(shell date +%Y-%m-%d)
or
Last edit: 31 Oct 2019 08:28 by vlad_vy.
- joeclone
31 Oct 2019 11:04 #75352
by joeclone
Replied by joeclone on topic Renaming custom builds
Vlad, thanks for the info will try it out.
- joeclone
31 Oct 2019 15:26 #75353
by joeclone
just to confirm is it this line in src/Makefile?I need to change to i.e.
HGVERSION ?= $(shell ../utils/get_version.pl ${TARGET})
HGVERSION := $(HGVERSION)HGVERSION := $(devo10)"-v5.0.0-"$(shell date +%2019-%10-%31)- vlad_vy
31 Oct 2019 16:19 - 31 Oct 2019 16:28 #75354
You don't need "devo10", variable $(TARGET) will be replaced by selected target, in your case devo10.
HGVERSION ?= $(TARGET)"-v5.0.0-"$(shell date +%Y-%m-%d)
With current nightly builds probably will work setting the build name from command line (without changing makefile):
make TARGET=devo10 HGVERSION=devo10-v5.0.0-(any you want to add)
Last edit: 31 Oct 2019 16:28 by vlad_vy.
- Renaming custom builds
