Hardware fix for T8SG v2p voice + some other fixes
- eried
28 Jan 2020 00:05 - 28 Jan 2020 00:08 #75830
by eried
Hardware fix for T8SG v2p voice + some other fixes was created by eried
Hi, I discovered that the problem with the voice in the T8SG v2 plus carbon is actually in the hardware itself. The PCB lacks two pulls up resistors so the people designing the remote did a small fuck up.
The problem is as kanamonoka user shows:
Here is how to fix it and how it works after the fix:
The fix looks like this:
Additionally, I soldered and straightened the antenna connector (because it always comes off):
Lubricated the gimbals (they made a faint squeaky sound) with www.tamiya.com/english/products/87099grease_hg/index.htm (perfect for plastic to plastic)
Printed a plan cover for the back:
www.thingiverse.com/thing:1259444
Last edit: 28 Jan 2020 00:08 by eried.
- Ryou
28 Jan 2020 08:27 #75832
by Ryou
Replied by Ryou on topic Hardware fix for T8SG v2p voice + some other fixes
Thanks for the great information.
I will take measures.
- eried
28 Jan 2020 09:05 #75833
by eried
Replied by eried on topic Hardware fix for T8SG v2p voice + some other fixes
Great! It would be nice to find a way also to add another USB mode that connects the D+ and D- of the MP3 chip directly to the main usb
maybe for pcb V4
- Ryou
28 Jan 2020 09:53 #75834
by Ryou
Wiring 47k ohms solved problem ①.
Thank you.
Thank you.
- sansjunk
05 Mar 2020 05:12 #76003
by sansjunk
Replied by sansjunk on topic Hardware fix for T8SG v2p voice + some other fixes
@eried you had mentioned about fixing the voice queuing issue. Is this fix in the build yet?
- eried
05 Mar 2020 18:48 #76018
by eried
No, there is a small discussion about my implementation. You can join the discussion here:
github.com/DeviationTX/deviation/pull/961
sansjunk wrote: @eried you had mentioned about fixing the voice queuing issue. Is this fix in the build yet?
- sansjunk
09 Mar 2020 11:57 #76057
by sansjunk
Thanks. I don't have anything valuable to add there. Just a thought I had was that we can look at how other voice supported TX behave and may be get some ideas from there.eried wrote: No, there is a small discussion about my implementation. You can join the discussion here:
- eried
09 Mar 2020 13:42 #76058
by eried
Well, basically I like voices being skipped, i.e. in the middle of a sound if you trigger another sound and TheRealMoeder does not. So I need to refactor it in a way that is flexible for both
- Enrique33
11 Apr 2020 20:08 #76179
by Enrique33
Replied by Enrique33 on topic Hardware fix for T8SG v2p voice + some other fixes
Hi eried. I'm fixing the hardware issue with your solution, thank you for your knowledge. Have you got a specific range for the two resistance we have to solder please?
- eried
12 Apr 2020 07:49 #76180
by eried
Any will do but between 1k and 40k might be the best. The recommendation from the manufacturer is the one I used
- Enrique33
13 Apr 2020 01:15 #76182
by Enrique33
Thank you for quick answer
- Hardware fix for T8SG v2p voice + some other fixes
