Devo10 ESky protocol draft
- victzh
17 Dec 2013 06:22 #16732
by victzh
Devo10 ESky protocol draft was created by victzh
This is the most recent Deviation with ESky protocol added built for Devo10.
Please test if you can, binds on fixed channel pair, so the implementation is not complete. Do not do interference test, results can not be interpreted.
- billmester
20 Dec 2013 17:54 - 20 Dec 2013 17:55 #16856
by billmester
Replied by billmester on topic Devo10 ESky protocol draft
I have made the upgrade, but I cannot bind it. There is a star "*" next to the Esky protocol, I cannot click bind or do anything...
Am I doing sg. wrong? Do I need to write anything into the tx.ini?
bm
bm
Last edit: 20 Dec 2013 17:55 by billmester.
- victzh
20 Dec 2013 19:26 #16859
by victzh
Replied by victzh on topic Devo10 ESky protocol draft
Star means that nRF24L01 is not configured.
You need to have nRF24L01 module physically added to your Devo (look for Devo mod instructions in www.deviationtx.com/repository/Documenta...uleInstallation.pdf/ ) and you need to modify your tx.ini to instruct the Devo that you have this module installed. It is described in this document as well.
- billmester
20 Dec 2013 19:52 #16860
by billmester
I have a V911 module built in, salvaged from a V911 Tx... is that good?
- billmester
20 Dec 2013 21:05 #16862
by billmester
I have enabled the module and -seems- to work fine...
BUT
Yesterday the RX was working fine, I could start binding and so on...
Today - I only get the "slow blink of death". I have looked around in forums and nobody got a solution on this... The rx just keeps blinking slowly, no matter what.
Sorry, I need to give up, the rx quit on me
BUT
- mono
20 Dec 2013 23:18 #16864
by mono
Bill...
the v911 module is a different critter to the nRF24L01, which as victzh said, you need installed to communicate with the ESky receivers.
You can get the nRF24L01 module from ebay (for example) but make sure you get one with a power amp in it.
Replied by mono on topic Devo10 ESky protocol draft
billmester wrote: I have a V911 module built in, salvaged from a V911 Tx... is that good?
Bill...
- billmester
20 Dec 2013 23:44 #16866
by billmester
Hi mono,
to be fair, it makes no sense for me anymore... my only Esky rx just died on me today right when I wanted to test this protocol.
If I would invest money in receivers/tx modules now, I'd buy a DSMX sat instead for my new 3GX
I wanted to get the Esky rx back to life to revive my first 6ch copter, a fully upgraded HBK2, sitting on a shelf since the Esky tx died...
I think I'll buy a 6ch Devo or a Spektrum (6115 or similar) to revive it, will not bother with Esky electronics any more
Sorry guys, I really wanted to help, but Esky quality just veto'd it
- SeByDocKy
04 May 2014 08:39 #22872
by SeByDocKy
Replied by SeByDocKy on topic Devo10 ESky protocol draft
It's possible to build the last NB for devo 10 with this beta ESKY protocol ?.
I should receive my ESKY 150 tmr ....
- victzh
07 May 2014 16:31 #22974
by victzh
Hi, I did not work on finalizing ESky because of total lack of interest - it seems that ESky is gone from the model RC arena.
I still have it in my archives, and will try to bring it to life, if you're interested.
What's ESky 150 tmr, by the way?
- SeByDocKy
07 May 2014 18:50 #22977
by SeByDocKy
Hi it's a new Flybar less micro Heli.... I just received it this morning
. Very nice and based on the BK2423 so NRF24L01 compatible. This new micro is very good ...
Yes I am definitively interested and some other users in RCgroup.
www.rcgroups.com/forums/showthread.php?t=2112972
victzh wrote: Hi, I did not work on finalizing ESky because of total lack of interest - it seems that ESky is gone from the model RC arena.
- victzh
08 May 2014 07:59 #22992
by victzh
Does it use standard ESky protocol?
- SeByDocKy
08 May 2014 08:43 #22997
by SeByDocKy
I think so ... it's my first ESKY model ... so can't tell u. But I think the job you already did shound be tested. In the worst case, I can capture SPI log of the TX for u. I got a devo 7E and devo 10 (w/ MM)
victzh wrote: Does it use standard ESky protocol?
- billmester
08 May 2014 20:27 - 09 May 2014 19:10 #23030
by billmester
Well, ESKY is dead - and still alive
This is my current project, a JetRanger, using the carcass of my first heli, a King2... sort of.
Based on the resurrected King, it has Align ESC, Esky brushless motor, Esky-Walkera-Align tail, original Esky digital cyclic servos, Walkera digital tail servo, Esky metal head with Align bearings, converted to FBL (!)... and the Esky TX-RX are binned since long ago
It has now a cheap K-Bar gold version with 2xSpektrum sats with DSM2.
Btw, the $30 controller can hover the thing with hands off the tx. Far better than my 3GX...
(no 3D, only hover and basic circles, but anyway.)
Last edit: 09 May 2014 19:10 by billmester.
- billmester
08 May 2014 20:35 #23031
by billmester
The bottomline is: "old" Esky 2.4G TX-RX are history. If you have them, replace them quickly. Do not waste time on them.
- victzh
09 May 2014 05:14 - 09 May 2014 05:17 #23051
by victzh
Here is the ESky fresh build for Devo10 (coincidentally with an extra protocol, KN). I checked it on real ESky RX - binds and controls RX fine.
Enjoy!
Enjoy!
Last edit: 09 May 2014 05:17 by victzh. Reason: Attachment added
- SeByDocKy
09 May 2014 06:03 #23052
by SeByDocKy
Hi Victzh ...
I just check on my new ESKY150 and doesn't work
... I guess they changed something in their protocol ....
Do you want I capture some SPI log with my Saleae ?
victzh wrote: Here is the ESky fresh build for Devo10 (coincidentally with an extra protocol, KN). I checked it on real ESky RX - binds and controls RX fine.
Enjoy!
Hi Victzh ...
- SeByDocKy
09 May 2014 06:42 - 09 May 2014 06:43 #23054
by SeByDocKy
Last edit: 09 May 2014 06:43 by SeByDocKy.
- SeByDocKy
- victzh
09 May 2014 15:13 #23068
by victzh
CSN, SCK, MOSI, and MISO - that's all is needed.
- SeByDocKy
09 May 2014 15:25 #23070
by SeByDocKy
and not GND too ?
victzh wrote: CSN, SCK, MOSI, and MISO - that's all is needed.
and not GND too ?
Time to create page: 1.000 seconds
Builds
- Devo10 ESky protocol draft
