Devo10 ESky protocol draft
12 Jun 2014 22:07 #24062 by dremaer
Replied by dremaer on topic Devo10 ESky protocol draft
good news :woohoo:
we are two interested now... i'm sure that will be others... :)
15 Jun 2014 02:12 #24081 by Gerry
Replied by Gerry on topic Devo10 ESky protocol draft
Make that 3 interested persons
I would like to be able to fly my HoneyBee V2 with the devo7e
FFS (Forever Fixing Stuff)
15 Jun 2014 06:38 #24083 by victzh
Replied by victzh on topic Devo10 ESky protocol draft
OK, I heard you.
Please try and report success/failure for the attached builds for Devo 10 and Devo 7E.
15 Jun 2014 21:30 #24099 by dremaer
hi victzh
i've tried the version 7E and it Power On but i don't have Main Menu... nothing appears...
15 Jun 2014 23:55 #24101 by Gerry
Hi Victzh,
after installing the 7e files, the 7e will power up but the same problem as dremaer, hit ENT button and devo goes to the main menu which is blank, if I hit ENT again the 7e appears to turn off
16 Jun 2014 03:11 #24103 by victzh
Yea, I saw it myself. Strange, Devo10 did not do this. Can you check nightly build, does it behaves strange as well.
16 Jun 2014 03:14 #24104 by victzh
And do not test deviation-devo7e-v4.0.1-bd281d2.zip, it can be OK. I'm interested in the next one (when it appears). It can have name deviation-devo7e-v4.0.1-e1e910c.zip.
16 Jun 2014 03:39 #24105 by victzh
Scratch all that.
Take last nightly at www.deviationtx.com/repository/func-startdown/1707/
Copy 'media' directory from it to your Devo 7E. It should fix the menu problem.
Copy 'protocol' from mine zip file and Upgrade from it also.
It would help if you copy 'layout' also.
16 Jun 2014 03:46 #24106 by PhracturedBlue
Replied by PhracturedBlue on topic Devo10 ESky protocol draft
Ran out of string space so builds didn't complete. I've updated it now and the nighty is up to date now.
16 Jun 2014 15:47 #24108 by dremaer
installed and at first sight works well. however i can't go further because i'm waiting my NRF module.
a question: it's the Esky150 protocol that i should take for my belt cp right?
16 Jun 2014 15:49 #24109 by dremaer
dremaer wrote: installed and at first sight works well. however i can't go further because i'm waiting my NRF module.
And i almost forgot to tell...
Thank you...
16 Jun 2014 15:56 #24110 by SeByDocKy
Replied by SeByDocKy on topic Devo10 ESky protocol draft
No the ESKY150 is corresponding to the new ESKY protocol. Please download the beta version from the Victzh msg
16 Jun 2014 16:25 #24111 by dremaer
well
after this update i tried to bind with my v911 but it won't work... i went to "Model Setup" and *FlySky had a star before means i think "module not installed". I went to TX file and i have the module activated.
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=None
has_pa-nrf24l01=0
what could it be?
16 Jun 2014 16:42 #24112 by jesmail
Replied by jesmail on topic Devo10 ESky protocol draft
If you are using the nightly build, the parameters have moved to the hardware.ini file. So set them there and it should work.
16 Jun 2014 16:46 - 16 Jun 2014 16:47 #24113 by SeByDocKy
dremaer wrote: well
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
has_pa-nrf24l01=0
what could it be?
You are right .... There is a bug for my Devo 7E to bind the Esky150 (missing module). It's working with my Devo10. I am using the 15 june NB ....
Of course I tested other protocol nRF24L01 based such as V2x2 or Sky Wlaker and it's working with my Devo7E...
Last edit: 16 Jun 2014 16:47 by SeByDocKy.
16 Jun 2014 17:32 #24114 by dremaer
SeByDocKy wrote:
dremaer wrote: well
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
has_pa-nrf24l01=0
what could it be?
i have 2 files from this date...1126.0kb and 773.3kb. wich?
16 Jun 2014 18:08 #24115 by dremaer
forget my question...
since a while i try to solve this but i can't. my A7105 don't want to be reconized. however with 4.0.1 version it works fine.
18 Jun 2014 15:22 #24143 by victzh
OK, did anyone have success with my builds for ESky protocol? Once again - take 'media' directory from the nightly build, 'protocol' and dfu from my zip.
18 Jun 2014 18:45 #24148 by dremaer
hi victzh
i've tried just like you said on my Devo 7E and no major issues. however i can't bind my v911. i checked .ini file it's ok, and in model setup, the A7105 protocols have a "*" after the name like "*Flysky", "*Hubsan4", "*V202". it's normal?
but if i retrograde to 4.0.1 version my v911 binds and the "*" disappears.
18 Jun 2014 19:25 #24149 by victzh
Did you modify hardware.ini accordingly? Nightly build differs from 4.0.1 in this, the section about modules moved from tx.ini to hardware.ini.
Time to create page: 1.594 seconds
