7e +telem +layout ed +perm timer, weekly updates
11 Apr 2014 13:46 #22336 by HappyHarry
Replied by HappyHarry on topic 7e +telem +layout ed +perm timer, weekly updates
well the majority have spoken and it looks like permanent timer was the looser, but out of the kindness of my heart (lol not really as my buddy wants the permanent timer on his one and neither of us plan to use the multimodule) i will make three builds available, one with no permanent timer(noperm), one with no layout editor(nolayout), and one with no support for the new multimodule board(nomulti). these as always are in the first post.
if you find any bugs post here or on bitbucket, and as always enjoy your flying guys :D
11 Apr 2014 18:56 - 11 Apr 2014 19:04 #22351 by blackmoon
Replied by blackmoon on topic 7e +telem +layout ed +perm timer, weekly updates
:D I knew you would come true (is it true or through ?).
ThX mate.
Last edit: 11 Apr 2014 19:04 by blackmoon.
12 Apr 2014 01:08 #22357 by cmpang
thanks HH ...
14 Apr 2014 16:11 #22409 by ZOOCOCO
Well I think telem layout perm timer are all not that important
I switch to the new Devo 10 I think there is a big different between devo 7e and devo 10 which is the resolution of the gimbal.
Can devo 7e resolution be inceaseed? Maybe change the VR on the gimbal?
If the resolution can be increased this will be a big improvment for Devo 7e.
16 Apr 2014 23:57 #22490 by anarchy
I'm looking for the guide to add the 8s telem module to my 7e any help would be appreciated
19 Apr 2014 20:11 #22579 by smith
I'm looking at adding a 3x1 switch to my 7e, but I'm not sure where to download the code from, and where to extract it to. any help would be Much appreciated
20 Apr 2014 10:14 #22596 by cocozozo
smith wrote: I'm looking at adding a 3x1 switch to my 7e, but I'm not sure where to download the code from, and where to extract it to. any help would be Much appreciated
choose a zip from the first post in this thread e.g. nomulti
you will need to reflash your devo with this build (use the same method you used to first flash from devention to the deviation firmware.
Once this is done edit the hardware.ini file so that you can enable the 3x1 switch.
e.g.
;switch_types: 3x2, 3x1, 2x2
extra-switches=3x1
cheers
G
26 Apr 2014 05:16 #22726 by bitchin86
Replied by bitchin86 on topic 7e +telem +layout ed +perm timer, weekly updates
So I tried this the other night, I loaded a file from the first post, then I go in to the hardware file that is now on my tx and change add 2x2 for my switches. Right? Or do I change the .INI file before copying it to my tx? I am unable to get the additional switches to show up in the radio.
Thanks for any help
27 Apr 2014 13:20 #22750 by cocozozo
Just edit and save the file after you have flashed the build (edit on the drive).
The switches should appear as A and B for each switch.
28 Apr 2014 21:35 #22779 by HappyHarry
sorry for missing lasts weeks update guys, just been a busy few weeks. anyway the new builds are in the first post and if you find any bugs or problems post here or on bitbucket, and as always enjoy your flying guys :)
28 Apr 2014 22:30 #22780 by bitchin86
so this is my hardware.ini file and i still am not seeing the extra switches in the radio
;enable-haptic=1
;extra-switches=2x2
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
can anyone see anything wrong?
28 Apr 2014 23:03 - 28 Apr 2014 23:04 #22781 by hexfet
Remove the semi-colon before "extra-switches=2x2". The semi-colon means ignore the rest of the line.
Last edit: 28 Apr 2014 23:04 by hexfet.
28 Apr 2014 23:11 #22782 by bitchin86
Awesome thank you very much just got it working :-)
09 May 2014 21:19 - 09 May 2014 21:20 #23084 by smith
i got the latest build with no perm working, however i notice that on main menu, the bottom of box 2 is cut of by the top of box 3. is there any way to manually alter the postions of the boxes on the main page? thanks
Last edit: 09 May 2014 21:20 by smith.
09 May 2014 23:44 #23092 by HappyHarry
I'm not quite sure what your asking bud? as these builds don't change any of the GUI stuff
10 May 2014 22:09 #23122 by smith
Don't worry, I fixed it:). I just had to change the position of the boxes 1,2,3 on main page config as they were all overlapped after flashing the latest nightly build onto it.
12 May 2014 16:46 - 12 May 2014 16:47 #23162 by HappyHarry
ahh i got you, the main screen can be set to be model specific, or you can have the same main screen layout for all models, though i don't understand why there are overlaps in any of the boxes as my builds don't touch any of that? unless the default layout has these problems?
anyway the newest builds are in the first post guys, the main addition this time is the KN protocol that is used currently on the wltoys v977 heli, though i think there will be more using this protocol in the near future.
as always if you find any bugs report them here or on bitbucket, and enjoy your flying :)
Last edit: 12 May 2014 16:47 by HappyHarry.
17 May 2014 20:57 - 17 May 2014 21:04 #23308 by Herb
I've done the 3x2 switch mod, but after installing the latest nightly built (devo7e-nomulti-91301b7), my 7e does not work anymore.
I've edited the hardware.ini file. I uncommented the line and changed the value to: extra-switches=3x2 (by using Windows 7 wordpad)
I've changed the following: has_pa-cyrf6936 = 1 (because I've done the range mod successfully (already tested with the release 4.00)
The following two problems appear:
1. After swithing on the DEVO, a error message appears: "Bad/missing protocol modules!"
2. There are some switch combinations of the new 3-pos switches which "blocks" the up-trim of the left stick (throttle). Note: This problem also appear with the rel. 4.00 firmware.
After copying back the original fils (rel. 4.00), the "missing protocol" error disappears and everything works fine.
What is wrong?
Last edit: 17 May 2014 21:04 by Herb.
19 May 2014 16:47 #23362 by HappyHarry
the "missing protocol modules" error usually appears when you only flash the newer firmware and don't also copy across the new modules folder to the file system. try doing that and see if it fixes your problems
21 May 2014 13:59 - 21 May 2014 14:01 #23457 by HappyHarry
new builds are in the first post, main updates this time is telemetry is enabled on the FrSky protocol, a bind on start option for the v202 protocol, and the ability to use up to 12 channels when using the tx with a pc in USBHID mode.
as always if you find any bugs post here or on bitbucket, and enjoy your flying people :)
Last edit: 21 May 2014 14:01 by HappyHarry.
Time to create page: 0.803 seconds
