Voice alerts test build
- Morlacus
Really I don't know, I have just discovered it two days ago and this is not documented in the manual. The question is what do they represent ? In my opinion one would be good. and the alarm on it.Moeder wrote: What do the two voltages mean? Which one needs an alert? Or is it needed on both?
- pulpfiction15
I made the 'upgrades' dated 26 Mar, all good on the devo6 and the Devo12
@Molacus,
Did you check the real voltage, and compare it to the displayed value, I have it also that the voltage drops when I touch the screen.
@magic_marty,
I have put the media and script folder as also the MkDevo12Lib.exe file on a SD Card.
Run the MkDevo12Lib.exe as administrator. It works on older Windows machines (32bit) and Windows 10 (64bit).
- Morlacus
pulpfiction15 wrote:
@Morlacus,
No and I don't know how to do that, the difference between the 2 displays is very small (.10 to .12 volts ) and measuring a value on the battery will not be a proof of the good value. The best would be that a developper who knows why there is a double display explains the reason why.
Morlacus wrote: As concerns battery voltage display, the devo 12 has a double display. the second can be seen when pressing the voltage display.
I went to see if I could figure out what it was for you, but I can't reproduce that behavior using the emulator (don't have a 12) build of the latest master branch. So, could you:
1) verify that it happens if you use a default model file with no edits? If that doesn't have the issue, then post the misbehaving model.ini file. Otherwise
2) Try the nightly build of the emulator. If you see the problem there, provide a more detailed description of how you get to the voltage. Otherwise
3) Try the nightly build on your Tx and let us know what happened.
- magic_marty
pulpfiction15 wrote: @Moeder,
@Molacus,
@magic_marty,
Did exactly as you described (put all files on SD card right clicked MK.exe select run as admin) and it says it created the file but nothing appears...I will try it on my old desktop running WinXP pro ..My laptop is running Win10 64bit ...Maybe it will work on my older pc
- magic_marty
- Morlacus
magic_marty wrote: Finally figured it out...OMG the script file was in a file named script so i removed it and now it works..But now my screen is black again and i can't remember how to get the blue background back...i tried renaming the devo12 file but it wont work..Could somebody lease tell me which file i need to rename and what to name it..?
You need to have in your media directory a file named devo12.bmp just to please the programm and the blue background which was named devo12.bmp has to be renamed backgrnd.bmp. So copy devo12.bmp and rename it backgrnd.bmp
- magic_marty
- magic_marty
Got it working i removed the .bmp from the devo12 and backgrnd files and now i have the blue background again...
Thanks for helping..
- Morlacus
magic_marty wrote: Tried copy and rename the devo12 and still black backgrnd ..do i need to put the .bmp at the end of the name of the file?
Would be simpler if you have all extensions of files appearing
So go to files options and unmark "Hide file extensions for known file type" then you should see the full name of your files" and give a new screenshot
Please to see that it works
- magic_marty
- Morlacus
mwm wrote: I went to see if I could figure out what it was for you, but I can't reproduce that behavior using the emulator (don't have a 12) build of the latest master branch. So, could you:
1 It happens with every model and also a default
2 tried with nightly build (firmware and library)dated 20-3 same process
3 re tried with original devo 5.00 firmware : same. It seems that this is a feature of 5.00 release.
Inclused a mp4 showing the manip
- magic_marty
Got it...thanks
- Morlacus
a little bug on devo 12s
The voices work when ppm in use but the voice menu is not accessible
- Moeder
@morlacus : of course... will be fixed in next build.
- Morlacus
magic_marty wrote: on the transmitter menu>input monitor i have 25 ch1 sliders does anybody else have this? As far as i can tell it is not causing any problems just kind of weird..
I confirm i have the same thing
- Moeder
I uploaded new builds, so now the voice menu should be available all the time for Devo12.
Off-topic:
@FDR: while we are at it: can we at some useful labels to Issues to differentiate between. Maybe "Minor" "Major" "Color GUI" "B&W GUI" "Protocol"?
Done.Moeder wrote: @FDR: while we are at it: can we at some useful labels to Issues to differentiate between. Maybe "Minor" "Major" "Color GUI" "B&W GUI" "Protocol"?
What else do you need?
I also simplified the default label set, i.e. deleted a few to ease the choice...
- Moeder
Those were the ones I could just think of but I'm sure they are far from exhaustive
Me too...Moeder wrote: Thanks! I still need a devo12
...and many more things!
Builds
- Voice alerts test build
