Voice alerts test build
16 May 2017 14:02 #62360 by Moeder
First, I didn't start this thread, so I cannot edit the first post of this thread, and second I agree that it is more useful to add hardware/configuration related stuff to the wiki and voice menu related stuff to the manual. That is why I started the wiki page, but I hope someone else can fill up info and maybe add some more detailed information on configuring ini files. I'd rather spend time coding than documenting :P
21 May 2017 01:08 #62462 by Deal57
I have checked the new voice.ini file (the one with 300 phrases) and it works great on my devo 12e. The numbering scheme seems was a bit confusing at first. The file numbers start at 200, but the numbers in the configuration screen start at 1, so if you have a particular numbered file to use then you need to know to subtract 199 from the file number to match the number on the screen. I use RD DR0 for throttle active (file # 265), so I need to choose 66 for the file number in the config screen; likewise RD DR1 is Throttle Hold (file #267), so i need to choose number 68. It's not terribly hard to use but it is confusing now that we have so many choices!
Besides that it's great. Thank you!
I know someone who produces voice materials (books on tape, podcasts, etc.) and I'm working to try compression on the sounds. This should help reduce or eliminate sounds being run over by the next alert... well, at least I hope that it will.
21 May 2017 14:02 - 21 May 2017 21:21 #62470 by Deal57
I have added some material to the WIKI page and of course it's a work in progress. It is intended to summarize the information we've gathered in this thread. Please add your own observations or notes and feel free to correct anything I've missed!
I have a few questions from working this material:
  • The Voice Alerts MP3 files appear to be located only in the test builds area. Should they be available from a different place, perhaps the Downloads section, but maybe in a separate "Voice Alerts" category?
  • Installing and configuring the voice system isn't difficult but it could be a large manual... should it be created as a separate manual from the standard ones?
  • Going forward do all nightly builds (and eventually the release) have support for the 400 voice alert files? Do the older 200 alert files work with the new nightly?
  • Is there anyone working with the AudioFX devices that can work with me to make sure the notes are consistent across the hardware?
  • Can we match the *.ogg files (required by the AudioFX devices) to the *.mp3 files or is there a conversion program?
Last edit: 21 May 2017 21:21 by Deal57. Reason: Requesting additional input.
22 May 2017 14:14 #62493 by 52dgj
Replied by 52dgj on topic Voice alerts test build
你好,我的发射机是devo10,请问devo10可以加语音模块吗?
hello.my launcher is devo10.Is it possible to add a voice module?
My English is not very good……
I'm using Google Translate:P
22 May 2017 16:41 #62497 by Moeder
Good work, deal57
  • once the voice pack is satisfying, I agree it should be uploaded in a separate section and in multiple languages. But the feedback on it has been sparse so far
  • I think it should go into the same manual
  • all future (and current) nightlies support 400 files, of course smaller voice.ini's still work
  • I can update the genspeech to also create ogg files for AudioFX useres
23 May 2017 13:31 #62504 by 52dgj
Thank you
Thank you
Thank you
26 May 2017 02:25 #62552 by Deal57
I have added a new section to the WIKI page with the details of installing the emulator voice alerts.
I am impressed by the tight integration of the voice alerts in the emulator. They function exactly like the transmitters and this is an incredibly useful alternative as I get to know this feature. I echo the sentiments of the previous message: thank you!
@52dgj: Yes, you can install into the Devo 10. Check out the Voice Alerts WIKI page for some ideas, and let us know if you need more information.
27 May 2017 06:25 - 27 May 2017 19:55 #62591 by Moeder
Good work on the wiki!
Actually the implementation of voice in the emulator was very crude in doing calls to an external program, but it really turned out to work extremely well for me during development, so I never found the need to do something more complex :P
I still have the Wishlist things in mind, but haven't found time for coding yet. As long as the rest works smooth, I'm not in a hurry. Haven't even found time to solder the new mcu in my devo7e which have been laying around here for weeks...
edit1: @deal57: I admire your clean devo12e installation. I guess we could also add a DPDT switch instead of the USB jack to switch between devo and dfplayer. Or does usb even allow both just to be connected in parallel to the internal jack? Haven't looked into the specs...
edit2: of course a y cabling is not permitted...either a low cost switch, or we might just geht a cheap usb hub in small footprint (for example this one ), remove its case and mount and solder it internally to the usb plug and devotx/dfplayer
Last edit: 27 May 2017 19:55 by Moeder.
01 Jun 2017 21:05 #62750 by jejeg
Replied by jejeg on topic Voice alerts test build
Hello everyone
I have a devo 12s with the module dfplayer with voice.fr; It works, the sound is strong but I do not have all the alerts (it stops at 9 (mix)) ???
Does anyone have a solution?
Goodbye also does not work, however, chronos, welcome, inactivity alarm work.
I'm in devo12-5.0.0-58e29b0
Thank you
bonjour à tous
j'ai une devo 12s avec le module dfplayer avec voice.fr ; ça fonctionne ,le son est fort mais je n'ai pas toutes les alertes (ça s'arrete à 9 (mix)) ???
Quelqu'un a t'il une solution ?
Au revoir ne marche pas non plus ,par contre les chronos , bienvenu ,alarme d'inactivité fonctionnent .
Je suis en devo12-5.0.0-58e29b0
Merci
02 Jun 2017 14:36 #62767 by Moeder
Bonjour!
The French voice set ist still the limited pack made during development and only contains nine custom alerts. If you want, please download the voice-en-large.zip, translate all English descriptions and pm it to me or post it here. I can the quickly generate the large set in French and upload it to the downloads section.
Concerning goodbye message, it is a known bug.)
02 Jun 2017 17:30 #62770 by jejeg
Thanks Moeder
I can translate voice announcements (the words) but not generate them in mp3
The way is a woman
Je peux traduire les annonces vocales ( les mots) mais pas les générer en mp3
La voie est féminine
02 Jun 2017 17:33 #62771 by jejeg
02 Jun 2017 18:04 #62775 by Moeder
That is what I meant, send me the words and I will generate the mp3 for you. Male or Female to your choice ;)
Nice video with feature demonstration, and also a nice Grasshopper!
02 Jun 2017 18:09 #62776 by jejeg
Great, I put myself to work and I send it in next week
ps: Woman voice please
02 Jun 2017 18:12 #62778 by jejeg
And thanks for the commentary on the video and the plane ;)
02 Jun 2017 20:38 #62795 by jejeg
Moeder wrote: That is what I meant, send me the words and I will generate the mp3 for you. Male or Female to your choice ;)
A little work for you :woohoo:
"crow"????
02 Jun 2017 20:43 #62796 by jejeg
0200 acrobaties3D
0201 ailerons3D
0202 profondeur3D
0203 débattements3D activés
0204 débattement3D on
0205 débattement3D off
0206 dérive3D
0207 acrobaties
0208 aileron
0209 aileron haut
0210 aileron bas
0211 aileron moyen
0212 ailerons
0213 aérofrein fermé
0214 aérofrein sortie
0215 aérofrein
0216 aérofrein off
0217 frein off
0218 frein on
0219 papillon off
0220 papillon on
0221 ???
0222 ???
0223 profondeur
0224 profondeur haut
0225 profondeur bas
0226 profondeur moyen
0227 moteur off
0228 moteur on
0229 moteur marche
0230 moteur désactivé
0231 moteur arrêt
0232 exponentiel off
0233 exponentiel on
En bon français ;)
02 Jun 2017 20:51 #62797 by Moeder
Crow is both flaps down and both ailerons up, mainly used in gliders. See example in this video:
02 Jun 2017 21:16 #62798 by jejeg
Ok ,in french : crocodile
03 Jun 2017 06:33 #62803 by Moeder
OK. I wait until I have the rest of the pack, as it only takes me five minutes to generate the whole set.
Time to create page: 0.800 seconds
