Voice alerts test build
17 Nov 2017 21:32 #65950 by yets
Replied by yets on topic Voice alerts test build
I'm a windows man so I probably am stuck then
17 Nov 2017 21:51 #65951 by Moeder
Or not...I have a project in progress, please have a little patience :woohoo:
17 Nov 2017 21:54 #65953 by yets
Of course, if there's any thing I can test let me know. :)
18 Nov 2017 10:25 #65970 by Solmer
Replied by Solmer on topic Voice alerts test build
Hi! Don't worry, just search for text to speech online and you'll get a lot of places which converts text to voice (mp3) I don't remember which I was using a few weeks ago...
18 Nov 2017 10:32 #65971 by Moeder
I'm making good progress on automated online voice pack generation in multiple languages - Travis features an OS X virtual machine which can be used for this purpose B)
18 Nov 2017 15:23 #65973 by Moeder
18 Nov 2017 22:39 #65977 by sv650s
Replied by sv650s on topic Voice alerts test build
It's time now for me to install all components in my devo 12S
I would like to use the lipo of devo 12S and not a separate lipo.
So, where i can find 4.2v in my radio ?
I have found a 4.2v on pin of orginal TX module, is it serious to use this pin ?
Thanks for your help
19 Nov 2017 10:06 #65985 by jejeg
Replied by jejeg on topic Voice alerts test build
sv650s wrote: Hi,
Salut
En sortie d'inter. direct ,pas facile d'y aller mais plus sur .
19 Nov 2017 11:11 #65987 by sv650s
En effet je cherche un point 4.2v plus facile d'acces que celui de l'interrupteur
Si vous avez une idée, ce serait cool
So, i search a 4.2v pin more easy to access than the switch on/off
If you have an idea, it will be cool
19 Nov 2017 14:02 #65988 by sv650s
J'ai finalement fait comme jejeg, j'ai directement connecté l'alimentation en sortie de l'interrupteur et tout est maintenant ok
Enfin presque... car la voix est extremement nasillarde meme en baissant le son
Quel HP utilises tu jejeg ?
I did everything like jejeg, I directly connected the power supply at the output of the switch and everything is now ok
Finally almost ... because the voice is extremely nasal even down the volume
What HP do you use jejeg?
19 Nov 2017 16:55 #65995 by sv650s
J'ai utilisé un haut parleur d'un vieux telephone portable, c'est un peu mieux ainsi.
Cependant j'ai toujours ce soucis de fichier qui n'est pas lu jusqu'a la fin...
Par exemple, le mp3 "temporisateur 1 expiré" lorsqu'il est lu, je n'ai que "temporisateur 1 ex"
J'ai augmenté le temps dans le fichier voice.ini jusqu'a 5s sur ce fichier et cela ne change absolument rien...
Je ne comprends pourquoi certains fichiers ne sont pas lu en entier.
I used a speaker of an old mobile phone, it's a little better as well.
However, I still have this file problem that is not read until the end ...
For example, the mp3 "timer 1 expired" when read, I only have "timer 1 ex"
I have increased the time in the voice.ini file up to 5s on this file and that does not change absolutely anything ...
I do understand why some files are not read in full.
19 Nov 2017 17:26 #65996 by Moeder
Please post the model.ini with a little description of how to reproduce it and I will try to solve it
19 Nov 2017 18:59 #65998 by magic_marty
sv650s wrote: J'ai finalement fait comme jejeg, j'ai directement connecté l'alimentation en sortie de l'interrupteur et tout est maintenant ok
Do you remember which wire ect you connected to? Or maybe you took a picture perhaps?
19 Nov 2017 20:04 #66000 by jejeg
j'ai utilisé un HP d'environ 4 cm de diamètre en 8ohm (je crois) ,il m'en reste un je prendrais une photo et la posterai .
Le son est nickel même trop fort malgré son emplacement à l'arrière , j'ai mis le volume à 7
I used a HP about 4 cm in diameter 8ohm (I think), I still have one I would take a picture and post it.
The sound is nickel even too loud despite its location at the back, I put the volume to 7
19 Nov 2017 20:21 #66003 by sv650s
I have connected vcc of dfplayer on the yellow cable on the switch on/off
Sorry no photo
19 Nov 2017 20:24 #66004 by sv650s
Oui je veux bien une reference car tous ceux que j'essaye ont une qualité moyenne ou un volume trop faible même avec le volume a fond
Yes I want a reference because all those I try have an average quality or a volume too low even with the volume at the maximum
20 Nov 2017 18:29 #66015 by sv650s
Jejeg, as tu eu le temps de regarder le hp que tu as mis sur ta radio ?
Sinon toute bonne reference de hp est la bienvenue
Pour mon soucis de fichier non lu entierement, je suis en train de refaire les fichiers pour voir si cela change quelque chose
Sinon, le temps indiqué apres le nom de fichier dans le voice.ini, c'est le temps pour lire le fichier ou le temps d'attente apres lecture du fichier ?
Jejeg, did you have time to look at the speaker you put on your radio?
Otherwise any good speaker reference is welcome
For my unread file problem, I'm trying to redo the files to see if it changes anything
Otherwise, the time given after the file name in the voice.ini, is the time to read the file or the waiting time after reading the file?
20 Nov 2017 21:50 #66016 by jejeg
Désolé je n'ai pas eu le temps ce soir ,je suis rentré tard mais promis pour demain :rougir:
20 Nov 2017 21:52 #66017 by sv650s
Merci jejeg
Thanks jejeg
20 Nov 2017 22:06 #66018 by jejeg
Pour ton fichier voice.ini , est ce que tu peux l'envoyer .
Time to create page: 0.795 seconds
