Voice alerts test build
09 Jan 2018 18:46 #66788 by yets
Replied by yets on topic Voice alerts test build
How do I set it up exactly? I'm working with a Devo 7E
10 Jan 2018 21:48 - 10 Jan 2018 21:54 #66823 by Moeder
Assuming THR is on channel 3, this should trigger voice file 201 once when passing -95 % on throttle stick:
[channel3]
template=complex
[mixer]
src=THR
dest=Ch3
[mixer]
src=AIL
dest=Ch3
scalar=-95
usetrim=0
muxtype=voice
curvetype=fixed
and later in the file...
[voice]
Ch3=201
Do not get confused by "src=AIL", it is ignored in curve type fixed. For more information on the usage of mux voice and mux beep, refer to this post .
Memo for myself: I guess it's time to add this to the manual... :whistle:
edit: if you find the voice not playing reliably on fast stick movements, additionally read this post in the same thread as above .
Last edit: 10 Jan 2018 21:54 by Moeder. Reason: add link to post on how to make it react in fast stick movements.
10 Jan 2018 23:30 #66829 by yets
Thanks Modder, I'm hoping that this can work with a throttle curve that I use. Will check in the morning
11 Jan 2018 18:13 #66868 by Moeder
It should. Mux voice works on top of any other complex mixer without affecting the previous functionality. If you are using expo Dr type mixer, you will first have to set it up as a (more powerful) complex mixer
11 Jan 2018 22:56 #66871 by yets
Thanks Modder, got it working. I used a virtual channel. Just trying to work out a few kinks
14 Jan 2018 22:35 - 15 Jan 2018 08:38 #66885 by yets
Hey Moeder, the automated voice packer doesn't seem to be working. Has something expired?
Edit: ignore please, it took two hours to build!
Last edit: 15 Jan 2018 08:38 by yets. Reason: I
15 Jan 2018 13:17 #66887 by Fernandez
Replied by Fernandez on topic Voice alerts test build
As this is a lengthy read, is there somewhere a summary on the latest how to install setup?
Or could the first post be updated?
Is voice now officially supported or is in testbuilds.
(I have been testing at the begin stage of the voice and now want to embed it into my TX)
15 Jan 2018 16:31 #66889 by Moeder
yets wrote: Hey Moeder, the automated voice packer doesn't seem to be working. Has something expired?
Yes,Travis is currently having problems with their macos build environment, so there is quite some backlog, just have a day or two of patience.
15 Jan 2018 16:35 #66890 by Moeder
Fernandez wrote: As this is a lengthy read, is there somewhere a summary on the latest how to install setup?
I can't open the opening post as it belongs to someone else. Also everything is now in nightlies for quite some time, so the "test build" thread is probably not longer serving it's purpose, on specific problems I rather suggest opening new threads, so they can be found easier in the future. Quite some information has been added to the wiki, thanks to some users sharing their experience. The manual hasn't been updated on this topic yet.
15 Jan 2018 19:50 #66892 by yets
Thanks for your reply Moeder. Yes, it's taking ages, I'm testing some different voices so it's a bit of a wait. I don't mind though, just nice to know what's going on with Travis.
Do you think there'll be more voices added, some better quality ones?
15 Jan 2018 20:18 - 15 Jan 2018 20:22 #66894 by Moeder
Some of the voices are pretty good, I haven't found a way to update macos voices to HD version via command line unfortunately.
Edit: I actually planned to change the build process so all submissions are build at once every 24h or so instead of each submission triggering a build. But since voicepacker use has been soooo low I didn't see the necessity yet ;)
Last edit: 15 Jan 2018 20:22 by Moeder. Reason: Explanation
15 Jan 2018 20:54 #66895 by yets
The ladies English voices aren't that great imo. I'm a bit fussy though!
Yeah, it seems I'm the only one using it but once you set up the voice alerts with your own lost, you don't have reason to use it again... Unless you're like me, who's tinkering away. You do what keeps you happy Moeder, whatever it is, I'm very thankful.
23 Jan 2018 22:30 #67090 by Gerry
Replied by Gerry on topic Voice alerts test build
Hi Moeder, its been awhile since I updated my 7e (not U7e), been busy with other things. Is it possible to get a updated voice FW for the 7e with latest protocol fixes/features (eg freq tune for a7105, delay for telemetry alerts).
Cheers
FFS (Forever Fixing Stuff)
24 Jan 2018 19:31 #67124 by Moeder
Of course, but please have couple of days of patience, busy times over here...
24 Jan 2018 20:25 #67127 by Gerry
Thanks Moeder,
I'm happy to wait.
26 Jan 2018 16:15 #67195 by Moeder
Here is the current nightly (2018-01-26) with standard GUI disabled and voice enabled (still no voice config menu though, RAM is to small for more menus :(, so configuration via emulator or ini editing only)
File Attachment:
File Name: deviation-...7248.zip
File Size:1,168 KB
26 Jan 2018 21:38 #67205 by Gerry
thanks Moeder, much appreciation.
24 Feb 2018 06:39 - 24 Feb 2018 07:20 #67729 by vlad_vy
Replied by vlad_vy on topic Voice alerts test build
The devo8 and devo12 "Voice config" page "External voice currently not available" has not [Exit] button as all other pages.
Last edit: 24 Feb 2018 07:20 by vlad_vy.
24 Feb 2018 07:50 - 24 Feb 2018 07:51 #67730 by vlad_vy
Last edit: 24 Feb 2018 07:51 by vlad_vy.
25 Feb 2018 19:08 #67768 by pulpfiction15
@vlad-vy,
This evening I made a new build for the 'option' to draw the backgorund.
That's working OK, but with ' drawn_background=1' startup message is at maximum volume.
With ' drawn_background=0' startup message is played correctly as per setting.
Time to create page: 0.610 seconds
