Voice alerts test build
- is fpv
04 Jul 2018 23:22 #69773
by is fpv
Replied by is fpv on topic Voice alerts test build
Thanks for the information, really useful
- sbstnp
05 Jul 2018 11:45 - 05 Jul 2018 11:45 #69775
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Voice alerts test build
Hi, can anyone show me how they wired up the dfplayer mini in their Devo 10? I'm interested in how did you power it up.
Devo 10 + 4in1
Last edit: 05 Jul 2018 11:45 by sbstnp.
- is fpv
- sbstnp
05 Jul 2018 13:06 #69779
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Devo 10 + 4in1
- Gerry
- Bbrad
05 Jul 2018 23:09 #69784
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Voice alerts test build
There are at least two posts in the last 20 pages of this thread showing where devo 10 power connection for dfplayer is.
- sbstnp
05 Jul 2018 23:24 #69785
by sbstnp
Thanks, I managed to locate some bits of useful info. Looks like there's no 5V hook up point available so I'll have to get some step ups.
Anyone tried the dfplayer mini on 3.3V in the Devo 10? Is it drawing too much current?
Devo 10 + 4in1
Spektrum Dx9
Gerry wrote: There are at least two posts in the last 20 pages of this thread showing where devo 10 power connection for dfplayer is.
Devo 10 + 4in1
- 52dgj
06 Jul 2018 00:06 #69786
by 52dgj
Replied by 52dgj on topic Voice alerts test build
This is my installation method,dfplayer mini Power supply is 3.3~5v。I hope that my bad English can help you.
- sbstnp
06 Jul 2018 00:09 - 06 Jul 2018 00:24 #69787
by sbstnp
Thank you, appreciate it. Are you happy with powering it up from 3.3V? (your English is fine btw)
Edit: poked around and looks like I can hook it up to battery voltage and use a step down. I'll give that a go and if I'm happy I'll add it to the wiki.
Devo 10 + 4in1
Spektrum Dx9
52dgj wrote: This is my installation method,dfplayer mini Power supply is 3.3~5v。I hope that my bad English can help you.
Devo 10 + 4in1
Last edit: 06 Jul 2018 00:24 by sbstnp.
- 52dgj
06 Jul 2018 00:30 #69788
by 52dgj
Translation software I use,(⁄ ⁄•⁄ω⁄•⁄ ⁄),3.3v works very well.
- sbstnp
08 Jul 2018 08:54 - 08 Jul 2018 21:26 #69810
by sbstnp
Yeah no worries. I hooked it up to 3.3V and it works fine. The volume seems a bit low, I wonder if going up to 4.2V will improve it (I'm using a 0.8W Taranis speaker).
Edit: I just realised I have had this radio since 2011 after I completely fried my previous Devo 10 trying to repair it. I've been here with PhracturedBlue, FDR and suvsuv since the beginning. That's a freaking long time. Cheers people, what a ride!!
Edit2: memories!!!
www.deviationtx.com/forum/6-general-disc...phracturedblue#15831
Devo 10 + 4in1
Spektrum Dx9
52dgj wrote: Translation software I use,(⁄ ⁄•⁄ω⁄•⁄ ⁄),3.3v works very well.
Edit2: memories!!!
Devo 10 + 4in1
Last edit: 08 Jul 2018 21:26 by sbstnp.
- joeclone
05 Mar 2019 05:40 #73213
by joeclone
Replied by joeclone on topic Voice alerts test build
Ok so I'm on a devo10 and gonna be using the frsky r9m connected to PXX protocol. As I understand if we use pxx input to devo10 we lose voice alert capability. Is there any way to have both functioning, is there another pinout on the board or stmf1 chip we can solder to to get another serial line to enable voice alert?
- Moeder
05 Mar 2019 14:31 #73218
by Moeder
No usart pin free on devo 10, pins are occupied by switches. Could possibly bit bang another pin for this, but nothing to really easily mod.
- 52dgj
05 Mar 2019 22:03 #73225
by 52dgj
Can we solder the voice support on the idle pin? Just like D7e:)
- Toolbox1211
13 Mar 2019 00:08 #73326
by Toolbox1211
Replied by Toolbox1211 on topic Voice alerts test build
So after many attempts with the f12e i cannot find an internal power source other than off the battery (always on)
Most spots just make the transmitter reboot. Even tapping the 12v external power plug and using a stepdown causes massive cpu slowdowns and is unusable. You simply cant tap off anywhere past where power enters the board from what i can tell
Only two simple options as i see it are a seperate battery for the dfplayer or an always on direct lipo power source with a stepdown converter and remembering to unplug your battery. At least in the case of the f12e
- Moeder
13 Mar 2019 08:46 #73331
by Moeder
What about a Pololu step down connected to battery voltage? Using the shutdown input (connected to a pad which is high when power is on) you can reduce idle current to 20ua.
- Toolbox1211
13 Mar 2019 13:50 #73333
by Toolbox1211
Sound like an idea could you enlighten me on where to find the shutdown input? Sorry im quite new to this lol thanks
- Moeder
13 Mar 2019 15:20 #73335
by Moeder
Check out for example:
www.pololu.com/product/3792
- Toolbox1211
13 Mar 2019 16:14 #73337
by Toolbox1211
Im know of the pololu. I ment the shutdown off the f12e
- Moeder
13 Mar 2019 20:12 #73340
by Moeder
I have no F12e or any of it's schematics. Any pin which is high when power is on will be fine.
- Morlacus
19 Mar 2019 07:55 #73430
by Morlacus
Hello
Just to know is there any modifications on the voice alert feature from last mid year and what is the last updated firmware in this case.
regards
regards
Time to create page: 0.432 seconds
Builds
- Voice alerts test build
