Voice alerts test build
23 Oct 2017 21:28 - 13 Nov 2017 14:31 #65224 by Moeder
Replied by Moeder on topic New startup sound and FrSkyX test build
Moeder wrote: a) include startup sound fix
b) enable voice for FrSkyX by default
c) add a protocol option to disable voice on FrSkyX in favor of s. port telemetry output to trainer jack
Mission accomplished. Please try the test builds attached. Also please check for the shutdown music (remember this is off by default in deviation it has to be enabled via "Transmitter config->Power Down Alert").
Last edit: 13 Nov 2017 14:31 by Moeder. Reason: removed old builds - please use nightly!
24 Oct 2017 10:49 - 25 Oct 2017 01:01 #65227 by BlackLotus
Replied by BlackLotus on topic Show my works! and problem question!
Oh.. I see. I'll try and report!
Thankyou Moeder.
add.
I didn't try yet.
Transmitter battery is 3S.
I'm using Pololu S7V8A
It's input volatge range is 2.7V ~ 11.8V :(
Newbie who using Devo 10
Last edit: 25 Oct 2017 01:01 by BlackLotus.
24 Oct 2017 18:43 #65229 by pulpfiction15
Replied by pulpfiction15 on topic Show my works! and problem question!
@Moeder,
First tests are positif, all seems to work as expected.
For the shutdown sound, it does not work, but I think it is normal, as all my dfplayers are powerd from the transmitter.
Thanks for your work/developments.:woohoo:
24 Oct 2017 20:11 - 13 Nov 2017 14:31 #65234 by Moeder
Replied by Moeder on topic Show my works! and problem question!
@pulpfiction15:
Could you try the builds below for shutdown music? Also, did you make sure power down alert is activated in transmitter config? Please be aware that your TX could hang on shutdown...
25 Oct 2017 18:18 - 25 Oct 2017 18:24 #65263 by pulpfiction15
@Moeder,
I do not notice any difference, no shutdown sound.
I can also confirm that in 'transmitter config' 'power-down alert' is set to 'on'.
One think I notice is that the 'welcome to deviation' is played at max volume, after that it's OK.
I do not mind to much, not having a shutdown message.
Last edit: 25 Oct 2017 18:24 by pulpfiction15.
25 Oct 2017 19:07 #65264 by Moeder
Ok, thanks for the test. I'll still leave it the way it is, as in different cases (concerning dfplayer power supply) this would probably the best way to code it. You are right....volume does not get set until after the first message is played. I'll fix that and make a pull request then.
27 Oct 2017 02:25 #65293 by yets
Replied by yets on topic Show my works! and problem question!
Hey guys, I was thinking about embarking on this little project for my 7e but I just wanted to be clear that the current build does not include access to standard mixer GUI? That's fine as I use advanced but am I correct in understanding that I'll be unable to edit each individual model under the model menu? I'm a little confused as to what functionality I'll be losing.
Additionally, I have used the emulator to create custom layouts, will this cause a problem?
27 Oct 2017 04:35 #65296 by Gerry
Replied by Gerry on topic Voice alerts test build
@yets
Correct, there is no standard mixer with the D7e voice alerts build.
There is no voice menu to select voice alerts with the D7e, voice alerts need to be manually added and saved to each model ini file using notepad++ . All other mixer functions are as before.
Not sure if voice is configurable in the emulator, I've never used it.
I don't think custom layouts will cause a problem.
FFS (Forever Fixing Stuff)
27 Oct 2017 14:01 #65308 by yets
Replied by yets on topic Voice alerts test build
Gerry wrote: @yets
Thanks Gerry, that's really helpful. I'm going to order some parts today to make an external box and maybe power it through the 2s balance lead on the Lipo with a step down converter. I haven't updated Deviation since March so these test builds should be quite up to date then?
27 Oct 2017 23:10 #65314 by Gerry
@Yets
Not sure if the voice files on the download page are up to date yet, I used the voice firmware for the 7e from this post.
www.deviationtx.com/forum/builds/5089-vo...uild?start=700#63351
also you will need the voice pack found here www.deviationtx.com/downloads-new/catego...-moeder-voice-alerts its the last one (assuming english)
28 Oct 2017 08:39 #65319 by Moeder
The firmware build is a little outdated for 7e (although just some minor things), I'll try to post an updated build soon, as well as the emulator which has the voice config menu (same as with the layout editor which is only available in the emulator).
28 Oct 2017 08:41 #65320 by Moeder
By the way... fixes for startup voice and FrSkyX are now available in nightlies!
28 Oct 2017 09:28 - 28 Oct 2017 10:08 #65321 by pulpfiction15
@Moeder,
I downloded this morning build; 806bd1b.
Only on the devo12S I have a 'double' welcome message. on the Devo6 I hear it only ones.
Volume of the welcome message is still at maximum.
Edit: figured out that I have the double welcome wih a model with protocol 'FrskyX'
Last edit: 28 Oct 2017 10:08 by pulpfiction15.
28 Oct 2017 10:29 #65323 by Moeder
Volume is probably due to the player not ready for volume commands (same issue as with welcome message), this will be a quick fix.
I'll check the double welcome message on FrSkyX as well...
28 Oct 2017 14:29 - 28 Oct 2017 14:30 #65326 by yets
Moeder wrote: The firmware build is a little outdated for 7e (although just some minor things), I'll try to post an updated build soon, as well as the emulator which has the voice config menu (same as with the layout editor which is only available in the emulator).
That would be helpful. I'e been using a nightly dated back from March (6328?). So anything more as up to date that would be great for me. Thanks, looking forward to trying it, just waiting the long game for parts to arrive now!
Last edit: 28 Oct 2017 14:30 by yets.
28 Oct 2017 17:22 #65328 by pulpfiction15
@moeder,
I went out flying today, ... about the double welcome message, maybe it is not the protocol issue, I switched to other models with FrskX, and got a single welcome message.
02 Nov 2017 20:22 - 13 Nov 2017 14:32 #65442 by Moeder
@pulpfiction15: thanks for your testing experience. Please try the build attached concerning startup message volume on your devo12.
@devo7e-users: Please find attached a devo7e build with voice enabled at the cost of loosing standard mixer GUI. Voice menu is only available in the emulator, which you can also find attached.
Last edit: 13 Nov 2017 14:32 by Moeder. Reason: removed devo12 build - please use nightly!
03 Nov 2017 19:53 - 03 Nov 2017 19:54 #65471 by pulpfiction15
@Moeder
First, welcome message volume is correct, thanks.
About the double welcome message on some models, I made some more tests.
It happens with the model here attached.
It is due to Virt3 channel, I think it wants to play the message from the mux at startup, but why two times the welcome message ?
File Attachment:
File Name: model10.ini
File Size:3 KB
Last edit: 03 Nov 2017 19:54 by pulpfiction15.
04 Nov 2017 20:53 #65516 by Moeder
Thank you of posting the model.ini and identifying the problem. It was caused by the mux voice playing triggering before the delayed startup sound had played. I made a pull request which forces the startup sound to reset the voice queue, but this actually means your mux voice will not play on deviation startup (it will still play when switching into a model using mux voice). I hope you can live with that for now. My brain doesn't want to come up with a more complex solution tonight ;)
04 Nov 2017 21:40 #65519 by pulpfiction15
@Moeder,
I do not mind at all, I never had any message at starup before :P
Now I have always welcome message, thanks again.
Time to create page: 0.685 seconds
