Voice alerts test build
26 Feb 2018 05:17 - 26 Feb 2018 06:37 #67776 by vlad_vy
Replied by vlad_vy on topic Voice alerts test build
I don't understand why it can happen. The drawn background don't touch anything related to audio. Probably extended audio device with drawn background hasn't time to properly initialize and the startup sound AUDIO_SetVolume() do nothing.
What transmitter do you use? Probably we need increase startup delay at "main.c" to 2000 with drawn background.
    // Add startup delay to make sure audio player is initialized
    // AUDIO_Init() has already been called by CONFIG_ReadModel()
#if HAS_EXTENDED_AUDIO
    audio_queue_time = CLOCK_getms() + 1500;
    num_audio=1;
    next_audio=1;
    AUDIO_SetVolume(); // Initial setting of voice volume
#endif
to
    #if (LCD_WIDTH == 480) || (LCD_WIDTH == 320)
        if(Display.background.drawn_background)
            audio_queue_time += 500;
    #endif
    num_audio=1;
    next_audio=1;
#endif
Last edit: 26 Feb 2018 06:37 by vlad_vy.
26 Feb 2018 08:07 #67782 by pulpfiction15
@vlad-vy
I testested it on a devo 6.
26 Feb 2018 08:10 - 02 Mar 2018 04:04 #67783 by vlad_vy
Can you try this test build with added startup delay?
File deleted...
Last edit: 02 Mar 2018 04:04 by vlad_vy.
26 Feb 2018 08:41 #67785 by pulpfiction15
@vlad-vy,
I am travelling and will only be able to test on Thursday evening, sorry.
01 Mar 2018 19:25 #67847 by pulpfiction15
@vlad-vy,
as promised, flashed your build deviation-devo6-v5.x.x-2018-02-26.zip, this did not help, same results.
With ' drawn_background=1' startup message is at maximum volume. :oops:
02 Mar 2018 04:07 - 03 Mar 2018 06:43 #67850 by vlad_vy
Will be better if extended audio developer Moeder look in to it.
Try next build - I added 0.2sec delay before MUSIC_Play(MUSIC_STARTUP):
File deleted...
Last edit: 03 Mar 2018 06:43 by vlad_vy.
02 Mar 2018 18:47 - 02 Mar 2018 19:18 #67855 by pulpfiction15
@vlad-vy,
some improvement;
drawn_background=1 startup message somethimes maximum volume, somethimes at set volume
drawn_background=0 startup message normal
Last edit: 02 Mar 2018 19:18 by pulpfiction15.
03 Mar 2018 06:46 - 10 Mar 2018 04:58 #67872 by vlad_vy
It looks like we are close. Try next build with 0.3sec delay before MUSIC_Play(MUSIC_STARTUP):
    num_audio=1;
    next_audio=1;
        while(CLOCK_getms() < audio_queue_time - 1200);
#endif
#endif
    MUSIC_Play(MUSIC_STARTUP);
File deleted...
Last edit: 10 Mar 2018 04:58 by vlad_vy.
03 Mar 2018 10:11 #67876 by pulpfiction15
@vlad-vy,
all OK now, thanks.:cheer:
Could you make a build also for a DEV012, to test.:whistle:
03 Mar 2018 13:00 - 10 Mar 2018 04:58 #67879 by vlad_vy
devo12 build with delay 0.3sec:
File deleted...
03 Mar 2018 19:08 #67883 by pulpfiction15
@vlad-vy,
all OK, also on the devo12 , thanks.:cheer:
05 Mar 2018 14:24 #67914 by Moeder
Thanks vlad for fixing. Influenza had it's grip on me...
12 Mar 2018 20:29 #68033 by Bisky
Replied by Bisky on topic Voice alerts test build
Can't get my U7E to work with dfplayer. The dfplayer it self is working when I pres keys. It does not work over DSC port, external port currently not available in the model voice alert.
What am I doing wrong?
I flashed this to my U7E
www.deviationtx.com/downloads-new/catego...256-v5-0-0-voice-zip
TX, Bojan
Devo F7 XMS + 4in1 module
12 Mar 2018 22:17 #68034 by Moeder
Try the current nightly and closely follow the instructions in the wiki (especially ini settings)
13 Mar 2018 16:45 #68044 by Bisky
voice.ini was missing in the media folder on the transmitter...
Devo F7 doesn't work due cpu limitations?
Ultimate F7-XMS, could it be done?
Tx, Moeder
15 Mar 2018 15:32 - 15 Mar 2018 15:33 #68093 by Moeder
Yes F7 like 7E had only 128 Kb flash, so no room for voice feature. We could compile F7XMS without standard mixer GUI to make room for voice features, but voice config menu would still not work due to ram limitations. Configuration would have to be done via ini editing or emulator.
Last edit: 15 Mar 2018 15:33 by Moeder.
15 Mar 2018 18:49 - 02 Sep 2022 08:23 #68102 by Remlen
Replied by Remlen on topic Voice alerts test build
Devo10 voice mod
Last edit: 02 Sep 2022 08:23 by Remlen. Reason: photo
15 Mar 2018 18:50 - 02 Sep 2022 08:24 #68103 by Remlen
Last edit: 02 Sep 2022 08:24 by Remlen. Reason: photo
15 Mar 2018 19:33 #68106 by Bisky
Ok, this sounds promising, but difficult to set up in the *.ini files...
would the ultimate 7e boot loader worked if I changed CPU?
15 Mar 2018 19:58 #68107 by Moeder
Bisky wrote: Ok, this sounds promising, but difficult to set up in the *.ini files...
In theory, yes, but you'd need a custom build. What is wrong in using the emulator to set up the ini files? But I won't hold you off from unsoldering and soldering yet another LQFP64 package :side:
Time to create page: 1.441 seconds
