Voice alerts test build
27 May 2018 10:46 #69433 by Moeder
voice.ini has to be placed into the mymedia folder of your devo12s
27 May 2018 11:18 #69435 by M8A4X
Replied by M8A4X on topic Voice alerts test build
Thank you moeder!! The 12S is now talking to me :)
By the way, I don't know if this is firmware specific but on the 12S USB drive when connected to the PC there is only a \media folder.
If the voice.ini is placed there, everything is fine. I did however create the \mymedia folder in the root of the drive and placed the file there, this did not work.
27 May 2018 15:02 #69436 by vlad_vy
Replied by vlad_vy on topic Voice alerts test build
devo12-XMS don't use "mymedia" folder, it's for devo12 only.
27 May 2018 18:24 #69438 by M8A4X
Thank you vlad_vy for the clarification!
Both the F12E and the 12S are now talking to me, this helps a lot when I can't take my eyes off the plane/quad/FPV goggles. Time to try some different voice packs ;)
28 May 2018 07:57 #69442 by Moeder
M8A4X wrote: Both the F12E and the 12S are now talking to me, this helps a lot when I can't take my eyes off the plane/quad/FPV goggles. Time to try some different voice packs ;)
I didn't notice you are using Xms. Glad it works now. Try out Deviation Voicepacker to build your own voice packs.
28 May 2018 10:18 #69444 by vlad_vy
M8A4X, can you try last devo12-XMS build with optimized GUI redraw?
www.deviationtx.com/forum/builds/6861-ul...ilds?start=360#69443
28 May 2018 16:14 - 01 Jun 2018 04:12 #69447 by M8A4X
Hello vald_vy and moeder!
@moeder: For sure I will try the voicepacker ;) I just have to get into it a litte bit more. Thank you very much for your effort!
@vlad_vy: I have uploaded it to the 12S and the menu seems really, really fast. I only tested it with "normal" operations like change of model and browsing through settings of the TX. There were no signs of "sluggishness". Even the menu: Transmitter menu-->Transmitter config draws very fast (the screen, which I am aware of, with a lot of content). So, well done! :)
Edit:
Just a remark regarding the voice announcements:
When "power down alert" is set to "ON" in the transmitter config menu there is no "goodbye" or "power down beeps" played (no beeps when audio volume is set to "0" when the transmitter is shut down. Do I miss a configuration or is this a bug?
This happens on both the F12E and 12S, each is the XMS version.
The currently installed firmwares on the transmitters are:
F12E: devof12e-XMS-v5.0.0-f17ed68
12S: devo12-XMS-v5.x.x-2018-05-28
Last edit: 01 Jun 2018 04:12 by M8A4X.
14 Jun 2018 00:40 - 14 Jun 2018 00:40 #69634 by Gerry
Replied by Gerry on topic Voice alerts test build
@Remlen Can you please make your pictures available again. Thanks
FFS (Forever Fixing Stuff)
Last edit: 14 Jun 2018 00:40 by Gerry.
14 Jun 2018 15:07 #69644 by Leo Li
Replied by Leo Li on topic Voice alerts test build
15 Jun 2018 00:09 - 15 Jun 2018 02:20 #69645 by Gerry
Thanks Leo Li, but some of the key pictures are not visible on rcgroups either.
edit. tried the rcgroups again and after a few refreshes was able to see all pictures (strange) so I saved them.
Last edit: 15 Jun 2018 02:20 by Gerry.
24 Jun 2018 10:41 #69700 by Stavross118
Replied by Stavross118 on topic Voice alerts test build
Hi everyone
Hope you can help?
Have Devo F12E with Xms file upgraded memory with latest nightly build
Trying to go through trainer port (DSC) is this possible?
Wired DFPlayer tx through tip and grounded outer on a mono female jack
5v step down with 2s lipo
Also put file voice.ini in media file
Is there anything else I need to do as just says in voice.cfg external voice currently not available?
Any help in this would be great
24 Jun 2018 11:41 #69701 by M8A4X
Hi!
You also need to add the following text in a new line in your hardware.ini (to be found in the root folder of your tx when connected to PC in USB mode):
voice=dfplayer
Insert the line exactly as written above.
Do use notepad++ for changes in hardware.ini, do NOT use windows integrated editor.
Otherwise your hardware setup seems to be correct.
Best regards
Max
24 Jun 2018 20:29 #69703 by Stavross118
Thanks a million M8A4X
Solved the problem straight away
Many thanks
All working
25 Jun 2018 05:08 #69708 by Chabaz
Replied by Chabaz on topic voice alerts play in sequence.
Is there any way i can make the announcements stop any other announcement currently playing. ie. Switching from low rates to high rates, stops medium rates from being announced
Since I'm merely moving quickly thru the medium rates position, id rather not hear it, nor wait for it to finish playing before telling me what i am actually in.
This would be fantastic for every 3 position switch on the radio.
as is, if i flip the rate switch back and forth a few times, as needed with some models to trigger a calibrate or a RTH mode, i can literally be listening to more than a half dozen low rates, medium rates, high rates, medium rates, low rates medium rates, high rates announcement chain for quite some time.
not that the last example occurs often, it just seams like it should function a little differently.
all thoughts and ideas appreciated
25 Jun 2018 05:13 #69709 by Moeder
Replied by Moeder on topic voice alerts play in sequence.
This is on my to do list for the next iteration of voice feature.
25 Jun 2018 06:44 #69710 by Morlacus
Replied by Morlacus on topic voice alerts play in sequence.
Hello
This is a suggestion
Some warning message can also be only information. For example the altitude can be considered as an informations.
It would be interesting to have the possibility to trigger this type of information by a switch.
Do you think this would be possible ?
Regards
Morlacus
04 Jul 2018 08:52 #69767 by is fpv
Replied by is fpv on topic Voice alerts test build
Hi everyone, i've brought the wrong module, i buy mp3-tf-16p not dfplayer mini, is it going to work same? Or i need to change some code on hardware.ini. Need help. Cause i've solder everything and it doesn't work at all
04 Jul 2018 12:11 #69768 by Moeder
The module should work just fine. Check out the Wiki for the software instructions including necessary changes to hardware.ini
04 Jul 2018 12:39 #69769 by is fpv
So how i enable mp3-tf-16p on hardware.ini any ideas?
04 Jul 2018 14:17 #69770 by Moeder
Just set it up as dfplayer. Again, read the Wiki on how to do so: https://www.deviationtx.com/wiki/voiceoutput#software_configuration
Time to create page: 0.376 seconds
