XK K110 (S-FHSS) build for Devo 7E and Devo 10
17 Mar 2016 18:34 #44732 by victzh
If you press bind button on K110, it turns off the LED and waits for the signal. On Orange it blinks and either binds - becomes green, or not - becomes red. On TX it's not a Bind, it's Re-init, I don't know why it is written "Bind" on it, I'll figure out. The S-FHSS does not have a specific bind signal, the RX just recognizes the signal as belonging to one of S-FHSS TXs and binds to it.
17 Mar 2016 18:35 #44733 by SeByDocKy
Replied by SeByDocKy on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
I am stupid :) The binding button is in the battery bay :)
and it's working perfectly :)
Clap clap :)
17 Mar 2016 18:37 #44735 by victzh
Great, I'm relieved. I need someone with original Futaba S-FHSS RX's to test it. Especially check the directions - I copied XK's, but am not sure they are correct.
17 Mar 2016 18:39 #44736 by SeByDocKy
What is the 3G/6G channel ?
17 Mar 2016 18:46 #44739 by SeByDocKy
Ok I need to define a model for the X350 ...
Coz it's strange ... I can invert motor rotation with hold switch (CH6) for me.. It should be when throttle is above or not 50%
17 Mar 2016 18:46 #44740 by victzh
5 - low (I set -100) is 6G (I don't know what this G stands for, I call it 6-axis), high (I'd set +100) should be 3D.
The protocol itself is AETRGP12 where 1 and 2 are two Aux channels. I suspect you can add 4 more channels but don't know does Futaba have more than 8 channel receivers for S-FHSS. The protocol temporal resolution is 6.8ms, spatial - 10bit or 1024 steps out of which less used - it's centered around 496, not 512 or 511. At least in XK's version.
17 Mar 2016 18:52 #44741 by victzh
They have R3008SB with S.BUS, but it's T-FHSS - it seems it's with telemetry. I found an interesting proposition on eBay - www.ebay.com/itm/Futaba-10J-S-FHSS-Helic...ver-MD2/281968812268 , but I really really don't need it myself - I have no models to fly with it. So, until next clone.
17 Mar 2016 19:00 #44742 by SeByDocKy
Ok what I need is when CH is 3D (the light is well turning to red), now I need to apply CH6=+100 when throttle is above 50% and -100 when throttle is below ...
I hope I am clear :)
17 Mar 2016 19:06 #44743 by victzh
CH5, not CH6. CH6 is pitch. And if you share this model file it would be great. I have installed the CC2500 module into unmodded otherwise Devo 7E, so I'm missing switches for full setup.
17 Mar 2016 19:11 #44744 by SeByDocKy
victzh wrote: CH5, not CH6. CH6 is pitch. And if you share this model file it would be great. I have installed the CC2500 module into unmodded otherwise Devo 7E, so I'm missing switches for full setup.
Well ... I didn't work on this profile yet ... :( I am zero in config file :(
17 Mar 2016 22:38 - 17 Mar 2016 22:39 #44754 by hexfet
victzh wrote: On TX it's not a Bind, it's Re-init, I don't know why it is written "Bind" on it, I'll figure out.
I think this is controlled by the return value of the protocol command PROTOCMD_CHECK_AUTOBIND
Nice work! Good protocol to add :)
Last edit: 17 Mar 2016 22:39 by hexfet.
18 Mar 2016 00:12 #44758 by dc59
Post my XK K120 model file for DEVO10 , should be worked on DEVO8S
DR/EXP: FMOD0 50/30 , FMOD1 70/30 , FMOD2 100/30
CH5 : ELE DR0=3D / ELE DR1=6G
CH6 : pitch scalar=40
FMOD0 -30,0,+100
FMOD1 -100,0,+100
FMOD2 -100,0,+100
File Attachment:
File Name: XK-K120-D10.ini
File Size:4 KB
18 Mar 2016 04:09 #44766 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Great work Victzh,although I won't benefit from this do to me not having the cc2500 module installed,just want to thank you for your impressive hard work that gives us all a better flying experience.Appreciate your time and sacrifice.
18 Mar 2016 06:59 #44767 by victzh
Thanks guys! It's really encouraging to hear this! I will finish it up very soon.
I'm also interested in tests against Futaba's S-FHSS receivers.
Also, I'm looking at T-FHSS - does anybody know is it also CC2500 based? There is a deal now on eBay, it's very tempting, but a little out of my price range.
18 Mar 2016 07:10 #44769 by dc59
victzh wrote: Thanks guys! It's really encouraging to hear this! I will finish it up very soon.
Futaba T6K ?? T-FHSS
18 Mar 2016 07:14 #44770 by Fernando
Replied by Fernando on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
dc59 wrote: Post my XK K120 model file for DEVO10 , should be worked on DEVO8S
FMOD0 -30,0,+100
FMOD1 -100,0,+100
FMOD2 -100,0,+100
File Attachment:
File Size:4 KB
I will test in my Devo8s when my CC2500 module arrives. It will take a while...Thank you.
18 Mar 2016 07:18 #44772 by victzh
Used 10J for couple hundred. The problem is, after hacking it I have absolutely no use of it, and I have so many radios already - all these heaps of plastic, mainly toy grade ones.
18 Mar 2016 07:19 #44773 by SeByDocKy
I need expert in config file for the XK X's 3D quadcopter (X350 and upcoming X100, X251, X252)
First of all, we need basically only 3 2-way swiches : Th Hold, D/R, 3D/6G. I would like a basic config compatible from a 7E...
So Th Hold can be the HOLD1, D/R = FMOD1 and 3D/6G can be the lower throttle trim for example ...
In 6G, for the X350, throttle stick behaves normally: From 0 to 100, motors spinning always in the classic rotation sens
In 3D; here the lowers RPM value is at central throttle stick position. Above motor are spinning in the normal way (from +small_value to 100 I guess) and below motor's rotation is inverted (from -small_value to -100 I guess)
I hope I was more or less clear ...
18 Mar 2016 10:08 #44782 by cewece
Did anyone test this with a Detect X380 ?
18 Mar 2016 20:40 - 18 Mar 2016 20:41 #44800 by SeByDocKy
I tuned a bit the config file forthe X350
HOLD: 3D/6G
FMOD: D/R
right yaw trim: Horizon/Accro
Can be improved of course ....
Last edit: 18 Mar 2016 20:41 by SeByDocKy.
Time to create page: 0.237 seconds
