Deviation v5.0.0 build with latest protocols
05 Sep 2018 04:56 #70654 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
Yes. Devo 7e protocol modules limited to 4K. The full protocol and telemetry does not fit to 4K module.
06 Nov 2018 05:28 - 27 Dec 2018 08:32 #71558 by vlad_vy
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Frsky D8: Add optional RSSI channel, from goebish
Add optional RSSI channel to Frsky D8 protocol, same as FrskyX (D16) and AFHDS-2A protocol.
Tested with D4R-II Rx and random Chinese D8 Rx.
* Add WFLY protocol, from goebish
Add WFLY protocol, ported from MULTI, tested.
www.deviationtx.com/forum/protocol-devel...t/7990-wfly-protocol
* Protocol MJX Bugs 3 Mini, from goebish
Adds Bugs3Mini protocol
Channel 5: Arm
Channel 6: Leds on/off
Channel 7: Flip mode
Channel 8: Snapshot (requires mjx wifi camera module)
Channel 9: Record video (requires mjx wifi camera module)
Channel 10: Angle / Acro mode
www.deviationtx.com/forum/protocol-development/7850-bugs-3-mini
* Protocols E012 and E015, from goebish
* Add protocols for EAchine E012 and E015
* Add Emulation layer for HS6200 transceiver to nrf24l01 interface
* Move Beken chip init to nrf24l01 interface instead of repeating it in each protocols
E012 channel mapping:
Channel 6: Flip
Channel 9: Headless
Channel 10: RTH
E015 channel mapping:
Channel 5: Arm
Channel 6: Leds on / off
Channel 7: Flip
Channel 9: Headless
Channel 10: RTH
Forums thread: www.deviationtx.com/forum/protocol-devel...e015-flight-boat-car
(06.11.2018)
Last edit: 27 Dec 2018 08:32 by vlad_vy.
06 Nov 2018 05:30 - 27 Dec 2018 08:32 #71559 by vlad_vy
I can't attach more than 10 files, and so XMS builds attached with separate message
(06.11.2018)
06 Nov 2018 05:32 - 27 Dec 2018 08:33 #71560 by vlad_vy
Fresh emulator builds
(06.11.2018)
Last edit: 27 Dec 2018 08:33 by vlad_vy.
27 Dec 2018 08:39 - 17 Jan 2019 04:39 #72124 by vlad_vy
* Protocols SLT V2, Q100, Q200, MR100, from goebish
Add sub formats V2, Q100, Q200 and MR100 to SLT protocol
Channel mapping:
Channel 9: Flight Mode
Channel 10: Flip
Channel 11: Video On
Channel 12: Video Off (Q200), Picture Snapshot (Q100 / MR100)
Channel 13: Calibrate (Q100 / Q200)
Topic: www.deviationtx.com/forum/protocol-devel...17-slt-sub-protocols
* Protocol for Air Hogs "Star Trek" NCC-1701, from goebish
Ported from MULTI, untested on Deviation.
Protocol: NCC1701
Channel 5: Warp
Topic: www.deviationtx.com/forum/protocol-devel...1-star-trek-air-hogs
* Protocol for WLToys V911S, from goebish
Add WLToys V911S protocol
Channel 5: calibrate
Forum: www.deviationtx.com/forum/protocol-devel...l-for-wl-heli-v911-s
* Protocol for GD00X, from goebish
Add protocol for C-17 Transport / GD006 DA62 fixed wing.
Protocol: GD00X
Channel 5: Lights on/off
Forum: www.deviationtx.com/forum/protocol-devel.../8120-c-17-transport
* Remove Beken BK2421 / BK2423 support, from goebish
* Remove MUSIC_Play from protocol, from howard0su
* Fix WFLY protocol, from goebish
(27.12.2018)
File deleted, see below...
Last edit: 17 Jan 2019 04:39 by vlad_vy.
27 Dec 2018 08:42 - 17 Jan 2019 04:40 #72125 by vlad_vy
(27.12.2018)
Files deleted, see below...
Last edit: 17 Jan 2019 04:40 by vlad_vy.
27 Dec 2018 08:45 - 17 Jan 2019 04:40 #72126 by vlad_vy
(27.12.2018)
17 Jan 2019 04:46 - 12 Feb 2019 05:10 #72350 by vlad_vy
* Fix issue with exiting USB mode t8sg V2, from hexfet
* Add RF scanner support to 128x64x1 GUI, from howard0su
* Fix devo12-XMS.ld
* Fix detection "PAL 60" video standard for DevoF12E-XMS
(17.01.2019)
Last edit: 12 Feb 2019 05:10 by vlad_vy.
17 Jan 2019 04:47 - 12 Feb 2019 05:11 #72351 by vlad_vy
(17.01.2019)
Last edit: 12 Feb 2019 05:11 by vlad_vy.
17 Jan 2019 04:49 - 12 Feb 2019 05:11 #72352 by vlad_vy
(17.01.2019)
17 Jan 2019 06:53 - 17 Jan 2019 07:16 #72353 by vlad_vy
I think it's the time to stop updating the stable v5.0.0 release. I think that no one uses it anymore, except me. Moreover, protocols in nightly builds become incompatible with the v5.0.0 release.
Support timeline: 23 Sep 2016 - 17 Jan 2019
Last edit: 17 Jan 2019 07:16 by vlad_vy.
18 Jan 2019 00:03 #72387 by aMax
Still using your builds on my 7e...., but anyways, thanks for your long term support!
18 Jan 2019 00:12 #72388 by ralf453
Replied by ralf453 on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: "Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Add 3pos momentary trim switch, from DavidBoone
Adds the ability to use the momentary trim switches as 3 pos switches. ie, normal resting position is centred (0), while pressing the trim one way or the other results in a momentary deflection in one direction (-100) or the other (+100).
* Add support for 6 independent trim sets
You can use 4-6 contiguous virtual channels to setup 4-6 pos switch, then assign to trims "Switch" the first used virtual channel and you will have 4-6 independent trims sets. The virtual channels switch at any state should have only single channel with +100% value, all others -100%. It's intended for for 4-6 flight modes with independent trims settings.
* Add iRangeX iRX-IR8M
(01.02.2018)
18 Jan 2019 07:46 #72394 by billmester
Replied by billmester on topic Deviation v5.0.0 build with latest protocols
Hi Vlad, I am still using the 5.0.0
Now I am going to update to this latest version of jan 17.
18 Jan 2019 09:56 #72395 by vlad_vy
iRangeX iRX-IR8M can't be supported with v5.0.0, it require HAS_4IN1_FLASH support for 4in1 module.
18 Jan 2019 10:39 #72396 by kdivs72
Replied by kdivs72 on topic Deviation v5.0.0 build with latest protocols
I have been trying to get this to work on my devo f7 but for some reason my devo f7 reboots wverytime i try and switch protocols please help
18 Jan 2019 13:01 - 18 Jan 2019 13:09 #72398 by vlad_vy
If you need firmware for stock Devo F7, you need nightly build "devof7" firmware, not "devof7-XMS".
If you use modded DevoF7-XMS (with upgraded flash memory chip), check that you copy to transmitter filesystem "protocol" folder from firmware archive.
Last edit: 18 Jan 2019 13:09 by vlad_vy.
19 Jan 2019 16:44 #72415 by mscmontauk
Replied by mscmontauk on topic Deviation v5.0.0 build with latest protocols
new to the Deviation and received a new iRangeX iRX-IR8M and the current -firmware is 2017-09-19 and while im flying it stops working and cuts in and out what firmware should i upload to stop that and will it even stop that from happening?
02 Feb 2019 05:45 #72668 by is fpv
hi vlad_vy, i was wondering what was the point of this scanner? for what? how does it work. i just upgrade my devo to latest firmware.
02 Feb 2019 07:17 #72669 by vlad_vy
It's not very useful. If you have connection problems you can evaluate RF noises in 2.4GHz band.
Time to create page: 0.355 seconds
