Deviation v5.0.0 build with latest protocols
23 Aug 2019 04:47 - 26 Aug 2019 04:16 #74967
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Protocol e010 cc2500, from goebish
* Add frequency tuning to WFLY protocol, from goebish
* Read multiplexed PID values from telemetry data
* Enable optimized dfu for all devo targets
* Add V761 protocol, from goebish
* Add support for Flysky AC type telemetry, from hexfet
(23.08.2019)
Files deleted, see below...
Add a new protocol for Eachine E010 using the CC2500 instead of NRF24L01* Add frequency tuning to WFLY protocol, from goebish
Add frequency tuning option to WFLY protocol* Read multiplexed PID values from telemetry data
For SilverWare, optional telemetry support was added to the Bayang protocol quite some time ago.
Recently, current PID settings were added to the telemetry data. This pull request makes them available via FadesA, FadesB, and FadesR. The change is backwards compatible and has no implications for older firmware which does not send these values.
The PID values are sent sequentially using just two bytes.
Details: https://www.rcgroups.com/forums/showpost.php?p=42032515&postcount=398* Enable optimized dfu for all devo targets
Protocol for Volantex V761-1 Trainstar Mini fixed wing
also works with Volantex Ranger 600 762-1
Channel 5: gyro on/off
Only 3 transmitter IDs/channels, selected with Fixed ID % 3.
https://www.deviationtx.com/forum/protocol-development/7798-volantex-v761-1-firestar-mini-protocol* Add support for Flysky AC type telemetry, from hexfet
Adds additional sensor support(23.08.2019)
Last edit: 26 Aug 2019 04:16 by vlad_vy.
23 Aug 2019 04:53 - 26 Aug 2019 04:17 #74968
I can't attach more than 10 files, and so XMS builds attached with separate message
(23.08.2019)
(23.08.2019)
Last edit: 26 Aug 2019 04:17 by vlad_vy.
23 Aug 2019 04:55 - 26 Aug 2019 04:17 #74969
Fresh emulator builds
(23.08.2019)
(23.08.2019)
- Birdman
23 Aug 2019 05:29 #74970
by Birdman
Replied by Birdman on topic Deviation v5.0.0 build with latest protocols
was E012 ever sorted?
- Kentuckian
- Home is Bullitt County, Ky
26 Aug 2019 02:56 #74997
by Kentuckian
Live in FailSafe mode
Replied by Kentuckian on topic Deviation v5.0.0 build with latest protocols
What please is a "Fresh emulator build" and how do learn to use it?? Thanks.
26 Aug 2019 04:15 #74999
It's transmitter emulator for Windows. See last article of User Guide how to use it.
26 Aug 2019 04:20 - 28 Sep 2019 12:32 #75000
* Fix "BUTTON_HAD_LONGPRESS"
* Add Telemetry reset, from hexfet
(26.08.2019)
Add feature to reset telemetry values on long press of Up button on telemetry monitor page.
For Frsky telemetry this resets the vario altitude "ground level" to the next received telemetry value, which zeroes the vario altitude telemetry value. Also resets the battery discharge accumulator to zero, and minimum cell voltage. The ground level value is saved in the model file to save the setting through power cycles - the value is fairly constant during a single day of flying in stable air.Files deleted, see below...
Last edit: 28 Sep 2019 12:32 by vlad_vy.
26 Aug 2019 04:23 - 28 Sep 2019 12:33 #75001
(26.08.2019)
(26.08.2019)
Last edit: 28 Sep 2019 12:33 by vlad_vy.
26 Aug 2019 04:25 #75002
Transmitter emulator
(26.08.2019)
(26.08.2019)
- Birdman
26 Aug 2019 04:30 #75003
by Birdman
I guess not.
Birdman wrote: was E012 ever sorted?
I guess not.
26 Aug 2019 04:44 #75005
I don't know. If E012 doesn't work with nightly builds, it will not work with v5.0.0 build. I use protocol updates from nightly builds.
28 Sep 2019 12:43 - 29 Oct 2019 05:59 #75159
* Fix missed "BUTTON_REPEAT" flag
* Convert mixer beep_lock variable to flag
* Don't run video_getstandard in every event loop, from howard0su
(28.09.2019)
Only check video standard after we change the video_enable. In case of no signal, we will keep checking every 1 second.(28.09.2019)
Last edit: 29 Oct 2019 05:59 by vlad_vy.
28 Sep 2019 12:45 - 29 Oct 2019 05:59 #75160
(28.09.2019)
(28.09.2019)
29 Oct 2019 06:02 #75331
* Change SPI2 speed from 2.25MHz to 4.5MHz
* Fix A7105 hanging
(29.10.2019)
* Fix A7105 hanging
(29.10.2019)
29 Oct 2019 06:03 #75332
(29.10.2019)
(29.10.2019)
- OrbitalGolem
29 Oct 2019 16:35 #75335
by OrbitalGolem
Replied by OrbitalGolem on topic Deviation v5.0.0 build with latest protocols
Hi Vlad - many thanks for your support, it's appreciated. I'm running one of your builds from April/May of this year and fly Spektrum only. Do any of the recent builds contain changes that would improve Spektrum support? Trying to determine if I should upgrade.
- jitter
29 Oct 2019 16:40 #75336
by jitter
Replied by jitter on topic Deviation v5.0.0 build with latest protocols
hi, thanks for your work! also got some questions:
- voice support is only available in the nightly builds, right? seems to be bit buggy for me - sometimes the voice are looping for some time.. which gets annoying.
- would you suggest in trying your builds over the nightly ones? the voice suppport is the only reason for me for now.
- is the model data compatible - can i "downgrade" without having to reset them all?
best regards
best regards
- joeclone
30 Oct 2019 00:26 #75339
by joeclone
Do you've cc2500 active in your hardware.h file?
Replied by joeclone on topic Deviation v5.0.0 build with latest protocols
Hey Orbital, what tx do u use? I've had trouble with spektrum sats not binding on my devo10 using this and the nightly versions of the firmware.OrbitalGolem wrote: Hi Vlad - many thanks for your support, it's appreciated. I'm running one of your builds from April/May of this year and fly Spektrum only. Do any of the recent builds contain changes that would improve Spektrum support? Trying to determine if I should upgrade.
- OrbitalGolem
30 Oct 2019 00:48 - 30 Oct 2019 00:49 #75340
by OrbitalGolem
Devo 8 and Devo 8s. No binding issues with the build from 3/5/2019, across Spektrum, Lemon, and Orange receivers. No idea what you mean by cc2500. Default settings.
Last edit: 30 Oct 2019 00:49 by OrbitalGolem.
- joeclone
30 Oct 2019 02:07 #75341
by joeclone
So you've no additional modules installed?
Time to create page: 0.388 seconds
Builds
- Deviation v5.0.0 build with latest protocols
