Deviation v5.0.0 build with latest protocols
30 Oct 2019 02:13 #75342 by OrbitalGolem
Replied by OrbitalGolem on topic Deviation v5.0.0 build with latest protocols
Stock Devo 8 and Devo 8s. No extra hardware is necessary to support Spektrum.
30 Oct 2019 09:00 #75345 by jpnews
Hello vlad_vy
I would like to know if I can use your latest firmware version (29-10-19) for the Jumper T8SG plus Carbon radio. On my radio Jumper voice is activated.
30 Oct 2019 11:14 #75346 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
No, v5.0.0 build has not voice support.
14 Dec 2019 09:31 #75581 by vlad_vy
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* More efficient screen updates on devo12, from PhracturedBlue
(14.12.2019)
File Attachment:
File Name: deviation-...2-14.zip
File Size:904 KB
File Attachment:
File Size:877 KB
08 Mar 2021 06:08 #77304 by D.Ricks
Replied by D.Ricks on topic Deviation v5.0.0 build with latest protocols
i might be in the wrong section for this question but here goes ... does anyone have the stock firmware for t8sg plus v3 ?
the firmware is labeled t8sg_v2-v5.0.0-0c4b4o any help would be greatly appreciated or even a link where to get this firmware
11 Sep 2021 23:31 #77552 by Wene001
Replied by Wene001 on topic Deviation v5.0.0 build with latest protocols
Hi vlad,
may i ask you for the v5.0 build with latest protocols? especially FrskyX v2.X
I have Devo12, Devo8, Devo6, F7_XMS and F12E_XMS.
Thanks for help.
Greetings from Austria
12 Sep 2021 05:43 #77553 by Birdman
Replied by Birdman on topic Deviation v5.0.0 build with latest protocols
Wene001 wrote: Hi vlad,
Thanks for help.
NOT FOR LOVE NOR MONEY
Deviation is dead. I contacted vlad and several others about adding the Height protocol to Devo 8, already reverse engineered and on MPM, even offered to pay them. vlad was only one to reply, no one is interested, "NOT FOR LOVE NOR MONEY" as the saying goes. Turned to OpenTX, has no touch screen, and EdgeTX is full of bugs, don't trust it. So at this time a huge step backwards.
12 Sep 2021 06:33 #77554 by Birdman
It is typical of open source projects. OpenTX is dying, that is why EdgeTX was started.
12 Sep 2021 06:44 #77555 by Wene001
Maybe there is a chance that vlad have the Build invironment still installed.
Frsky X v2.x is still in the nightlies, but i like the original 5.0skin and menues for touchscreen more than the nightly version.
So It would be great if Vlad could give us an final 5.0 Version with the already implemented protocols.
if not, its ok too.
Thank you vlad (specially for the XMS implementation), and all the others to be part of this cool projekt for years.
Sorry for my bad english
Greets Wene
18 Sep 2021 11:32 #77576 by belrik
Anyone here able to check the PR which was merged on 12 June 2021? It broke nightly builds.
23 Sep 2021 05:24 #77578 by djtrance
Replied by djtrance on topic Deviation v5.0.0 build with latest protocols
@vlad_vy
with this release I cannot bind with WLToys I have a plane and a car that it suppose to be work (I have a new 4in1 module) how can I check what it is wrong?
other thing it is that the page of scanned there is some strange símbolo, but if I press it .. they start scanning.
05 Jan 2022 14:22 #77642 by aerocarv
Replied by aerocarv on topic Deviation v5.0.0 build with latest protocols
Vlad, I have the Walkera F12 TX with video screen. It is a marvel of design and engineering. Many DevationTX members have asked if Deviation v5 can be installed on the F12. Or, can its RF board be replaced with a multi protocol unit? I have Deviationinstalled on a Devo10 and a F12E. I like it!
Could we get an update from you? And some encouragement.
01 Jan 2026 01:13 #78798 by luanhouse
Replied by luanhouse on topic Deviation v5.0.0 build with latest protocols
Is any hardware modification needed to bind Volantex by V761 on DEVO10 with this release?sorry for the stupid asking, but all over the Internet i can't find a clear introduction...
01 Jan 2026 10:27 #78801 by luanhouse
vlad_vy wrote: "Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Protocol e010 cc2500, from goebish
Add a new protocol for Eachine E010 using the CC2500 instead of NRF24L01
* Add frequency tuning to WFLY protocol, from goebish
Add frequency tuning option to WFLY protocol
* Read multiplexed PID values from telemetry data
For SilverWare, optional telemetry support was added to the Bayang protocol quite some time ago.
Recently, current PID settings were added to the telemetry data. This pull request makes them available via FadesA, FadesB, and FadesR. The change is backwards compatible and has no implications for older firmware which does not send these values.
The PID values are sent sequentially using just two bytes.
Details: https://www.rcgroups.com/forums/showpost.php?p=42032515&postcount=398
* Enable optimized dfu for all devo targets
* Add V761 protocol, from goebish
Protocol for Volantex V761-1 Trainstar Mini fixed wing
also works with Volantex Ranger 600 762-1
Channel 5: gyro on/off
Only 3 transmitter IDs/channels, selected with Fixed ID % 3.
https://www.deviationtx.com/forum/protocol-development/7798-volantex-v761-1-firestar-mini-protocol
* Add support for Flysky AC type telemetry, from hexfet
Adds additional sensor support
(23.08.2019)
Files deleted, see below...
02 Jan 2026 00:59 #78802 by hexfet
The V761 protocol uses the nRF24L01 radio module. So yes, the Devo10 requires that module to be installed to support V761.
15 Jan 2026 09:13 #78803 by luanhouse
hexfet wrote: The V761 protocol uses the nRF24L01 radio module. So yes, the Devo10 requires that module to be installed to support V761.
Thanks a lot! I found the 4 in 1 module and works well with V761 now with my D10!
It's pretty sad for me to entry forum this late, but still lucky to buy a second hand D10 and start fly with deviation before forum close.
15 Jan 2026 16:38 #78804 by OrbitalGolem
Agreed - wanted to extend a personal thanks to @PhracturedBlue, @hexfet, @vlad_vy, and all of the other contributors to Deviation over the years for this Herculean effort. I still use my Devo 8s almost every week, running a 5.0.0 version from 2019 with DSMX, and it keeps working with no issues, with the original UI. Started using Deviation at version 3.x. As a software developer I understand and appreciate the blood, sweat, tears, and perseverance that went into this code base. I should have migrated to OpenTX and EdgeTX, but Deviation is just fine. I finally bought a FrSky Tandem X18 for a few helis, but I still have all of the others bound to the Devo 8s. Actually bought several 8s and Devo 12s transmitters over the years as spares. The ability to use relatively cheap transmitter hardware, which was actually pretty well designed and implemented, was huge.
@PhracturedBlue - I believe you were the initial developer on this effort - you can be proud of what was created here. All my best wishes for your future endeavors.
15 Jan 2026 16:39 - 15 Jan 2026 16:41 #78806 by OrbitalGolem
HexFet/PhracturedBlue - not sure if I tagged you correctly in my message above. Many thanks again.
Last edit: 15 Jan 2026 16:41 by OrbitalGolem.
15 Feb 2026 16:41 #78823 by hexfet
Thank you!
Time to create page: 0.242 seconds
