Jumper T8SG V2 builds
17 May 2018 07:07 #69271 by Moeder
Replied by Moeder on topic Jumper T8SG V2 builds
I have started to really like the yellow :lol:
19 May 2018 11:58 #69316 by Binnekamp
Replied by Binnekamp on topic Jumper T8SG V2 builds
Hi everyone,
I am new to this forum so I don't know if this is the right topic for the reply.
I recently received my Jumper T8SG plus V2 and was testing it with the DSMx protocol, which apperrently uses the cyrf6936 part of the 4in1 transceiver.
I was able to bind the Inductrix tiny whoop, but had a lot of problems with the range being no more than about 6 meters with the output power set to 150mW.
I did some investigation on the Deviation forum and found out that the 4in1 transceiver uses the pins PE1 and PE2 to swith the rigth transmitter to the antenna according to the table below.
status PE1 PE2
A7105 RF signal to antenna 0 0
CC2500 RF signal to antenna 0 1
NRF24L01 RF signal to antenna 1 0
CYRF6936 RF signal to antenna 1 1
I decided to open up the transmitter and started measuring the levels of PE1 and PE2.
When powering up the radio (DSMx protocol) the first two seconds I saw a value of 3,3V on both the PE1 and PE2 pins, which according to the table is correct. However after the Jumper booted and the RF indicator LED at the front of the radio comes on, the value of PE1 dropped back to 0V and the value of PE2 stayed at 3.3V.
With this information I started testing some other protocols using a spectrum analyzer to measure the RF signals and found out that PE1 after the boot procedure of the radio always falls back to 0V, making both the NRF24L01 and the CYRF6936 radio parts and protocols useless.
Regards,
Tom
19 May 2018 12:37 #69318 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG V2 builds
PE1 PE2 lines is not software controlled, there is a proprietary chip on mainboard that control these lines.
19 May 2018 12:57 - 20 May 2018 12:38 #69319 by Binnekamp
I can imagine, but who or what is telling that chip what tx to select when a certain protocol is selected from the menu?
Because the right one is selected when powering on for about two seconds based on protocol selection.
Edit: Created a video describing the test to show what happens with the RF signal two seconds after starting the T8SG.
Also visible on the spectrum analyzer when using the "Bind" option.
Jumper T8SG Plus V2 0 4in1 TX Range Problems
Last edit: 20 May 2018 12:38 by Binnekamp.
23 May 2018 12:04 #69375 by PortosDoc
Replied by PortosDoc on topic Jumper T8SG V2 builds
For rewrite the filesystem for try this night builds how can doing? im noob of this... I'm sorry :silly: ;)
Thx for Your patience!
23 May 2018 12:13 #69376 by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG V2 builds
Stupid question, no problem to flash th V2+ with the classic Walkera Dfuse ?
23 May 2018 12:20 - 23 May 2018 12:22 #69377 by PortosDoc
Deviation v5.0.0 build with latest protocols : deviation-t8sg_v2_plus-v5.0.0-2018-05-08
I have used this with dfuse. The first time i have wrong the frimware and with a lucky i have resolve re-install this brand of firmware.
I have looking and find this other night build and i was try ... I have read i need use other flasher deviation upload 09. i try this flasher, but without success (the icon layer of icon very large and the menu is unreadable)... using the latest night build deviation-t8sg_v2_plus-v5.x.x-2018-05-14.
Vlad_vy says i have wrong filesystem maybe... Any suggestion?
Last edit: 23 May 2018 12:22 by PortosDoc.
23 May 2018 13:21 - 23 May 2018 13:23 #69378 by PortosDoc
Resolved
I have try to find into youtube. i have find one same upgrade for the devo 7.. I have used this.
I have reinstall the firmware. Enter in usb mode and cancel all with format. After i have copy all file the nightbuild(dfu and zip nope). After i have reflashed the firmware deviation tx night build 5.14. Now all work!
Thx anyway for the support!
P.s.
calibrate the stick and now work good
Last edit: 23 May 2018 13:23 by PortosDoc. Reason: Update
23 May 2018 14:55 #69382 by Ask1me
Replied by Ask1me on topic Jumper T8SG V2 builds
For upgrade latest firmware t8sg v2+,
Im using windows 10, what program should I install?
is it deviation uploader 0.9 or Dfuse USB upgrade tools 2.31?
23 May 2018 22:20 #69394 by PortosDoc
Dfuse USB upgrade tools. I gotta me too windows 10
27 May 2018 05:57 #69429 by flagadajones
Replied by flagadajones on topic Jumper T8SG V2 builds
hi,
could you add more trim for this target in target_defs.h
#define NUM_TRIMS 6
to
#define NUM_TRIMS 10
Regards
28 May 2018 13:12 #69445 by Moeder
@Vlad_vy: I don't know if you saw my comment in your PR, but why do we have
  CHANDEF(HOLD0)
  CHANDEF(HOLD1)
  CHANDEF(FMOD0)
  CHANDEF(FMOD1)
in T8SG builds? The switches are not labeled as such so it doesn't make sense to make these available in the build. They are probably leftovers from moving stuff over from the devo7e-256 (where they do make sense, as these are factory built-in switches and also labeled as such).
28 May 2018 14:20 #69446 by vlad_vy
I don't see sense to rework channel.c, tx_buttons.c and capabilities.h in order to delete HOLD and FMOD switches and "nostock" option.
28 May 2018 16:27 - 28 May 2018 16:27 #69448 by flagadajones
Hi @Vlad_vy,
i think (or it's my mistake) but there is a problem with buttons mapping (LEFT, RIGHT,UP,DOWN)
when i try to create a trim like this :
[trim5]
src=Virt4
pos=RIGHT      ====> Or  DOWN,etc...
step=193
value=-100,0,0
it always respond only on LEFT key press
thanks for your great job
Last edit: 28 May 2018 16:27 by flagadajones.
28 May 2018 18:34 #69449 by vlad_vy
I havn't problem with LEFT, RIGHT, UP, DOWN. I think "step" can't be more than 100. Probably you try to edit model.ini manually.
28 May 2018 19:41 - 28 May 2018 19:41 #69450 by flagadajones
@Vlad_vy,
step=193 is the value for momentary trim. edited with TX GUI
I join a full model for your test
in this model Timer1 is reset on Right press.
But when i test it not reset by right but by left press.
the test procedure :
1 : up THR to start timer
2 : press Right ==> nothing append
3 : press Left ==> timer is reset.
if you change pos value in trim5 to Down like this :
pos=Down
2 : press Right ==> timer is reset
then why timer is reset by LEFT key ?
thanks for your help
Last edit: 28 May 2018 19:41 by flagadajones.
29 May 2018 03:38 - 29 May 2018 03:40 #69453 by vlad_vy
If you use 128x64 GUI, on the main page by default LEFT reset timers, RIGHT stop timers. So, don't use custom LEFT and RIGHT on the main page. For color GUI, on the main page EXT button reset timers.
Last edit: 29 May 2018 03:40 by vlad_vy.
29 May 2018 04:27 #69455 by vlad_vy
Now you can download Jumper T8SG V2 builds from Nightly builds section.
29 May 2018 06:50 #69456 by flagadajones
ohh!! sorry i doesn't see that in the manual
23 Jul 2018 10:25 #69932 by xalex75
Replied by xalex75 on topic Jumper T8SG V2 builds
Hi.
Is the v2 now compatible with MJX (Bugs 3) protocol?
Time to create page: 0.147 seconds
