Jumper T8SG V2 builds
09 May 2018 06:33 - 10 May 2018 06:56 #69119
Replied by vlad_vy on topic Jumper T8SG V2 builds
Can anybody test improved "voice" mux? With fast and slow change, and precise positioning in a set value.
* More reliable and sound only once "voice" mux
T8SG V2 Plus
File deleted, see below...
T8SG V2 Plus
Last edit: 10 May 2018 06:56 by vlad_vy.
- PortosDoc
09 May 2018 11:23 - 09 May 2018 11:34 #69135
by PortosDoc
Replied by PortosDoc on topic Jumper T8SG V2 builds
I got some problem with this release. the incorrect position display and font are very bigger... any suggestion?
Last edit: 09 May 2018 11:34 by PortosDoc.
09 May 2018 16:10 - 09 May 2018 16:11 #69139
Are you sure you previously use these builds based on nightly builds, not "Deviation v5.0.0 build with latest protocols"? They have different filesystems.
Try rewrite filesystem from firmware archive.
Last edit: 09 May 2018 16:11 by vlad_vy.
- Moeder
09 May 2018 19:23 #69147
by Moeder
Replied by Moeder on topic Jumper T8SG V2 builds
Hi Vlad,
tested the build above, works very precise and on either fast or slow changes - good to go master in my opinion! BTW no font troubles whatsoever, had the latest T8SG+ build and only flashed the dfu - of course using deviation-uploader 0.9 on a mac
10 May 2018 03:42 #69151
Thanks. Pull request placed.
10 May 2018 06:56 - 14 May 2018 04:37 #69154
Changes:
T8SG V2 and T8SG V2 Plus based on Nightly Builds:
Files deleted, see below...
Changes:
Last edit: 14 May 2018 04:37 by vlad_vy.
- PortosDoc
10 May 2018 13:29 #69161
by PortosDoc
Yep Tested... I have rewrite with deviation-t8sg_v2_plus-v5.0.0-2018-05-08. I have now all in the good layer....
- Ask1me
12 May 2018 11:24 #69189
by Ask1me
Replied by Ask1me on topic Jumper T8SG V2 builds
Thank You so much Vlad_vy for this builds, its save my jumper t8sg plus when having issues with usb logos on display..
Im already flash with your firmware, and wohoo.. its back normal again..
You save my day
You save my day
14 May 2018 04:39 - 29 May 2018 04:26 #69206
Changes:
* Don't identify as USBHID mouse (fixes USBHID on Mac OSX), from netmute
Files deleted, see Nightly builds...
Changes:
Last edit: 29 May 2018 04:26 by vlad_vy.
14 May 2018 04:48 - 22 May 2018 03:40 #69209
New DeviationUploader-0.9.0
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool#
Run using: java -jar DeviationUpload-0.9.0.jar
Last edit: 22 May 2018 03:40 by vlad_vy.
- theandrewmillett
14 May 2018 06:44 #69211
by theandrewmillett
Should I assume that a reworked bootloader has not yet been incorporated? After updated to today's nightly, it's still reporting as a Devo7e in DeviationUpload.
Replied by theandrewmillett on topic Jumper T8SG V2 builds
Works great! I just updated my T8SG v2 Plus with this from Windows 7.vlad_vy wrote: New DeviationUploader-0.9.0
www.deviationtx.com/downloads-new/catego...eviationuploader-0-9
- Ask1me
15 May 2018 06:45 #69229
by Ask1me
Please help me, im having problem with my gimbals, its notice with jitter issues, im using 4xAA batteries,
the gimbals issues : just with little touch only, CH1 (AIL) and CH4 (RUD) will go 100/-100 depend on my touch direction.. (have this problem about 2 days ago)
is there any suggestions masters?
15 May 2018 07:08 #69231
Try calibrate sticks along with AUX wheels. Also, what curve type at mixers used for AIL and RUD?
Try to use 2S LiPo and twist gimbal wires to eliminate jitter.
- Ask1me
15 May 2018 09:59 - 15 May 2018 10:02 #69235
by Ask1me
curve mixers for AIL and RUD type is set "1 to 1" , is this okay?
sorry for my noob question..
Last edit: 15 May 2018 10:02 by Ask1me.
15 May 2018 10:33 #69237
it's OK. Try to calibrate sticks along with AUX wheels.
- Ask1me
15 May 2018 14:45 #69241
by Ask1me
okay, i will try it, maybe with the latest firmware will help my problems too.. im flashing it tonight.. also do you have stock firmware for jumper t8sg plus?
i notice and already search, and i cant found those stock firmware in any files
thank you so much
thank you so much
15 May 2018 14:58 #69242
No, I havn't stock firmware, but it based on February 2018 nightly build.
- Moeder
16 May 2018 07:37 #69252
by Moeder
Vlad, can you make a PR for T8SG plus changes? These builds should be in nightlies downloads section so people don't get confused with the existing T8SG build.
Time to create page: 1.047 seconds
Builds
- Jumper T8SG V2 builds
