Reference nightly build Deviation v5.x.x
15 Dec 2019 14:37 #75589 by Fernandez
Replied by Fernandez on topic Reference nightly build Deviation v5.x.x
For me the versioning of Deviation is not clear, can we change a clear follow up versions id?
I personally like they way Betaflight deals. See attached.
-Development / test builds (generated multiple a day, each with different nr, basically our nightlies)
-Release candidates
-Official Releases
-Maintainance Release (Specifiic compilations/selections, f.i. to run some of the newer features on an old hardware)
18 Feb 2020 20:19 #75941 by Artus
Replied by Artus on topic Reference nightly build Deviation v5.x.x
I have flashed 2 frsky recievers with the newest firmware and now i am not able to bind.
I have tried all what i know - i have installed the latested file on my F12E
With non updatet receivers i have no problem with binding.
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
19 Feb 2020 04:11 #75949 by vlad_vy
Replied by vlad_vy on topic Reference nightly build Deviation v5.x.x
If you use Frsky firmware with ACCESS protocol, it's not supported by Deviation. Try flash Frsky firmware with ACCST protocol.
19 Feb 2020 08:32 - 19 Feb 2020 08:54 #75951 by Artus
Thank you for your answer :) i am glad that that you are here for so a long time. But i am not a DAU :) I know about the ACCES and ACCST
I have tried yesterday again.
R-XSR and XM+ i have used the 2.01 version downloaded on frsky page. I have controlled wether if have take a wrong version - but there was no mistake to find
I have flashed R-XSR 1.9 firmware and with this i was able to bind - similar to the XM+ there is a 1.7 firmware to find on the frsky page - also bindig possible
But with the 2.0X ACCST firmware i am not able to bind - testet twice i have tried FCC and LBT version.
Some weeks ago i want to bind my DEVO10 with an frsky R-XSR reciever on an QUAD it was not possible also - but i don't know with firmware there was flashed.
I have ordered 2 new XM reciever by banggood - they need in the moment a long time to deliver - but i think they come with the new firmware and i am not able to bind
Ok i have checked the frsky page again - there is an older version for the XM also :)
And i have read again the text on the frsky page. You have to update the Transmitter and the reciever .. and there is a small comment to read "some of the X9D may have compatibity issus - we do not recommend users to update"
Maybe there is a hint for all "open-source" users in future to use frsky recievers. Cause they are not glad that we not buying the frsky Transmitter.
Thank you Vlad_vy for your great assist in supporting F12E.
Last edit: 19 Feb 2020 08:54 by Artus.
19 Feb 2020 08:36 #75952 by Artus
By the way - another question - is it now possible to use nightly's ? - or better take your posted files ?
19 Feb 2020 09:14 #75953 by vlad_vy
You can try nightly builds.
19 Feb 2020 16:10 #75954 by vlad_vy
Deviation and Multiprotocol do not support Frsky ACCESS and ACCST V2.
Time to create page: 0.615 seconds
