- Model Icons
- BW icons for DEVO 7E, 10, 12E
- Can't get the icon work... need help
- schwarzsurfer
26 Apr 2015 15:07 #31644
by schwarzsurfer
Can't get the icon work... need help was created by schwarzsurfer
what format and bit and so do I need for a b/w Icon for a Devo 10? I tried everything, but this **** doesn't work.
Can you help me? I added my first try of a destroyer, but it doesn't work and I don't know why...
Marian
Marian
- schwarzsurfer
26 Apr 2015 15:07 #31645
by schwarzsurfer
Replied by schwarzsurfer on topic Can't get the icon work... need help
erm... I don't know, why it is blue... on my computer it's ab/w bmp...
- TomPeer
26 Apr 2015 19:47 - 26 Apr 2015 19:48 #31658
by TomPeer
Replied by TomPeer on topic Can't get the icon work... need help
Last edit: 26 Apr 2015 19:48 by TomPeer.
- schwarzsurfer
26 Apr 2015 19:58 #31659
by schwarzsurfer
thanks, i will try it. what did you change?
- TomPeer
26 Apr 2015 20:01 #31660
by TomPeer
see topic: Instructions for making model icons
- schwarzsurfer
26 Apr 2015 20:03 #31661
by schwarzsurfer
Yes, I read it. But I thought these instructions were for color icons only?
- TomPeer
26 Apr 2015 20:04 #31663
by TomPeer
also for the b/w.
- RedSleds
26 Apr 2015 20:23 - 26 Apr 2015 20:29 #31666
by RedSleds
Replied by RedSleds on topic Can't get the icon work... need help
The image size was not the required 52x36 pixels.
Download my attachment, open it with GIMP 2.8
Plug in your DEVO 10 USB to computer and enter into USB mode by holding the ENT button and switching on the DEVO. The DEVO screen will have a large USB logo on it.
In GIMP program:
File > Export As > Change file type to "Windows BMP image (*.bmp)" if it isn't already > Select the Drive letter that is your DEVO radio > > select the modelico folder > Click "Export" > A window will pop up, expand compatability options and select the "do not write color space information" box, expand advanced options and select the "16 bits R5 G6 B5" box > Click Export
I do it this way, as I have not had good luck with drag and drop between my computer and the DEVO.
In GIMP program:
Last edit: 26 Apr 2015 20:29 by RedSleds.
- schwarzsurfer
26 Apr 2015 20:24 #31667
by schwarzsurfer
I can't find the advanced option dialoge in gimp... when I say "export to" a window opens and I can set the filename.bmp and say "export". but no othe options... where is the advanced button?
- schwarzsurfer
26 Apr 2015 20:27 - 26 Apr 2015 20:29 #31669
by schwarzsurfer
Thank you. I first had to set picture mode to RGB. Now the options dialog appears correctly. Now it works. I made a new destroyer icon
Last edit: 26 Apr 2015 20:29 by schwarzsurfer.
- TomPeer
26 Apr 2015 20:28 #31670
by TomPeer
the image was the right size. Work fine on my devo 10.
you get the options after you push the export button.
- RedSleds
26 Apr 2015 20:39 #31672
by RedSleds
That's weird, it was the right size. I guess it changed when I saved it from a different program, it came out 52 x 37 for some reason.
Anyway, glad it is all figured out now.
As a side note, I just tried drag and drop, and it worked. Not sure why some times it doesn't for me.
- Model Icons
Time to create page: 0.691 seconds
Model Icons
