Devo 12 layout for template
- Kdean
30 Jun 2013 01:50 #11603
by Kdean
Devo 12 layout for template was created by Kdean
This is a model.ini that has my submission for a simple template.
- Kdean
- Kdean
- Kdean
- cedric
12 Jul 2013 10:43 #12210
by cedric
Replied by cedric on topic Devo 12 layout for template
hi, i french sorry for my bad writing ^^
i need full screen in my devo12 3.0.0,and i take you model and copy in my library,i don't work.
i think abd it's logique too modified Tx.ini or other.
what is the method for full screen?
12 Jul 2013 10:50 #12211
Replied by FDR on topic Devo 12 layout for template
The v3.0.0 doesn't support the full screen on a DEVO 12.
In order to have full screen support you have to wait for the next release, or use the nightly builds if you please...
- cedric
12 Jul 2013 11:04 - 12 Jul 2013 11:08 #12213
by cedric
use the nightly build?
it's Beta version?
go in:
www.deviationtx.com/forum/7-development/...creen?start=80#12214
it's Beta version?
go in:
Last edit: 12 Jul 2013 11:08 by cedric.
12 Jul 2013 11:07 #12215
Yes.
...or rather Alpha...
- Kdean
13 Jul 2013 07:17 #12227
by Kdean
Replied by Kdean on topic Devo 12 layout for template
If you want to try the full screen before the official release, go to the nightly builds and download the dfu and fs for devo 12, and load them into your tx.
www.deviationtx.com/repository/Deviation...ases/Nightly-Builds/
I've been using version 3.0.0-8a4a0b and its been very soild. So far i've used it with my walkera V400D02 (2614v rx), Trex 450pro (2810pro rx and beastX), Trex500 (2801pro rx and beastX), and i'm currently programing a 600 size scale MD500 with devo 1002rx, beastX, and telemetry modual. And also a 40" balsa plane. I put gyros in the planes ailerons and programed flaps and brakes. Its also using a 2801pro rx.
- cedric
15 Jul 2013 15:36 #12253
by cedric
hi, i flah my devo 3.0.0 in deviation-devo12-v3.0.0-ddf6350 and flash libray 6350.dfu
copy my models in pc and copy FS in Devo12. ok just ir ^^
i modified Kean model29 in test my model18 attached.
i don't switch icon in action Fmode 0-1-2 exemple or other is not affiched.
Who is the problem?
Who is the problem?
- Kdean
15 Jul 2013 22:33 - 15 Jul 2013 22:34 #12256
by Kdean
I built this tenplate using nightly build 8a4a0b. I am holding off on udateing the firmware until the official release come out. There were alot of modifications to the gui in the latest nightly 6350, so there may be some comunication problems between thr two builds.
Have you tried to manualy reset the the toggle settings?
Last edit: 15 Jul 2013 22:34 by Kdean.
- cedric
16 Jul 2013 05:53 #12261
by cedric
no test reset toggle setting.
who find 8a4a0b? i chearch this version to late after work.
- Kdean
16 Jul 2013 06:23 #12262
by Kdean
After a new nightly is released, the older one is gone forever. Unless someone can post or email you their copy of the older dfu and fs. I dont have the ability to do that for you right now.
- Kdean
16 Jul 2013 06:31 #12263
by Kdean
After the next official release, i will rebuild this template using that version. I've been making slight adjustments to this template as i have been using it. I've made it more similar to my advanced layout to keep things consistant on the display with all my models. I'll will make a new layout thread for it here.
- cedric
16 Jul 2013 13:08 #12266
by cedric
So for now it is better that I stay in 6350, but I have come to understand how to take the 3.0.0 models the tinkering by adding the GUI and others, I'm not far from there I just need icons , the rest seems to work.
6350 or otherwise, but without using the GUI staff, I stay with the 6350 interface.
- cedric
16 Jul 2013 13:42 #12268
by cedric
then I just retested my config, I just lack the interface buttons do not light up when I manipulated but they still work, so it's just an interface language worries that I can not cut or misplaced in my model18
- cedric
17 Jul 2013 05:02 #12280
by cedric
i think to syntax error in my Model18.ini,who to see it?
17 Jul 2013 06:20 #12282
Replied by rbe2012 on topic Devo 12 layout for template
Your model18.ini has many line breaks inside, esp. in the toggle lines where the associated switch is in another line.
If this is not an issue due to uploading this will be the error...should be
Toggle=15,35,0,72,0,
HOLD
Toggle=75,35,0,130,66,
RUD DRToggle=15,35,0,72,0,HOLD
Toggle=75,35,0,130,66,RUD DR- cedric
17 Jul 2013 10:28 #12285
by cedric
hi,
i modified my model18.ini
hi touche to TOGGLE and BARGRAPH suite
Toggle=135,35,0,132,68,ELE DR
Toggle=195,35,0,71,0,GEAR
Toggle=253,35,0,65,129,MIX
Toggle=313,35,0,131,67,AIL DR
Toggle=373,35,0,64,128,FMODE
Toggle=433,35,0,73,0,TRN
Bargraph=250,180,TRN1
Bargraph=280,180,TRN1
Bargraph=345,180,TRN1
Bargraph=375,180,TRN1
Bargraph=405,180,TRN1
Bargraph=435,180,TRN1
Is good? test when i a moment to.
17 Jul 2013 11:41 #12286
Yes, looks much better. Give it a try.
Time to create page: 0.235 seconds
Custom Layouts
- Devo 12 layout for template
