- Custom Layouts
- How to show 3 position toggle icons in Devo 7E?
- Preet
18 Dec 2015 11:48 #41015
by Preet
How to show 3 position toggle icons in Devo 7E? was created by Preet
Hello.
How can i add a toggle for an added 3 position switch?
now i can only manage to show on/off (-100/100) toggle state, but the 3 postion switch has -100/0/100.
how can i tell deviation to show an icon in the middle postition?
and one more question: in the default.ini in layouts are some values i dont know...to be exact, the last one (128). what does this value say?
as far as i know the values are [horizontal position,vertical position,off icon, on icon,?,source]
Toggle=78,14,1,64,128,HOLD
Toggle=114,14,4,64,128,FMODE
Toggle=90,14,64,65,128,Ch6
Toggle=102,14,64,63,128,Ch7
Ch6 and Ch7 are my 3 position switches.
Greets Preet
Greets Preet
- Deal57
18 Dec 2015 13:39 - 18 Dec 2015 14:51 #41017
by Deal57
Replied by Deal57 on topic How to show 3 position toggle icons in Devo 7E?
The toggle icons are located on the media folder, and use the toggle1.bmp and toggle2.bmp files. You can add your own toggles in toggle3.bmp, and some time ago someone posted an extended toggle3.bmp for the 7e. That's where you'll find the addition toggle icons, I think.
In the 7e the switches should be named SWA and SWB for this section, I think.
Basically, the syntax of that line is:
"Toggle=[X-position],[Y-position],[toggle position1],[toggle position 2],[toggle position 3],[switchname]"
Here's the one I use for my Devo7e: Devo7e Toggle3.bmp message . If it appears that the link is broken, you can still right-click, save link .., and it will download the file.
Last edit: 18 Dec 2015 14:51 by Deal57. Reason: Add URL to toggle3.bmp extensions
- gatonini
22 Dec 2015 21:38 #41092
by gatonini
Replied by gatonini on topic How to show 3 position toggle icons in Devo 7E?
And where do you install this file to ?
- Deal57
22 Dec 2015 23:37 #41093
by Deal57
The toggle3.bmp file goes into the media folder on the 7e.
- Custom Layouts
Time to create page: 0.160 seconds
Custom Layouts
