Monitor bargraph text colour?
23 Dec 2014 01:06 #27155 by RoGuE_StreaK
Monitor bargraph text colour? was created by RoGuE_StreaK
I haven't used my 6s in a while, about to get back into it and started working on a new theme to attempt to improve visibility in sunlight; dark background, high contrast bold text. I've figured out most of it, but can't find anywhere a config for the small black text attached to the Channel- and Input- Monitor screens?
There are a couple of other bits of text that don't seem affected by config changes, but the bargraph text is the main killer for me at the moment (have checked latest nightly in case)
23 Dec 2014 20:20 #27169 by Indigo
Replied by Indigo on topic Monitor bargraph text colour?
The font used there is called "micro".
To change it edit the [Font-micro] section in media/config.ini
Or to change another font to be the same edit which ever font section you want to change and set it to font=04b03
The default [Font-micro] section is this:
[Font-micro]
   font=04b03
   box_type=center
   font_color=ffffff
23 Dec 2014 22:44 #27174 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Monitor bargraph text colour?
Hi Indigo
My media/config.ini doesn't have a font-micro (neither 4.0.1 nor 4.0.1-92e1705). I tried adding it, both as Font-micro and font-micro, but no result.
There's a font-tiny, which doesn't specify a colour; I added a colour, but again no result.
23 Dec 2014 23:20 - 23 Dec 2014 23:33 #27177 by Indigo
Sorry, font-micro applies to Devo 10/7e. The 6s has no font-micro because that font would be too small on a screen which has double the resolution. The 6s like the 8 uses the font-tiny setting. If works for me on 4.0.1-92e1705 emulator build, eg. I set the color to red:
[font-tiny]
;Channel display
font=5x7
font_color=FF0000
; font=arial10narrow
box_type=center
The smallest bold font is 14bold so the best you can do is use:
font=14bold
Last edit: 23 Dec 2014 23:33 by Indigo.
23 Dec 2014 23:33 #27179 by RoGuE_StreaK
That's done it, thanks Indigo; I think I may have used a dash instead of an underscore in "font_color" when I tried font-tiny (too used to CSS)
24 Dec 2014 01:31 #27187 by RoGuE_StreaK
Here's a sample from the emu, need to get around to updating my 6s and see how it looks there. Background, config, and some replacement buttons
31 Dec 2014 17:30 - 31 Dec 2014 17:58 #27387 by Indigo
Last edit: 31 Dec 2014 17:58 by Indigo.
Time to create page: 0.219 seconds
